Disabling EGR and fuel pressure solenoids
Old Nov 26, 2009 | 10:01 PM
  #181
mrfred's Avatar
Originally Posted by SeanV
Thx MrFred.
I have two cars here, EDM Evo9's using the stock ROM 88840016, and they both have Magnus intakes on.
I am going to try the above on them to see if I can get rid of the EGR/EVAP error codes.
Can you please confirm that the "1041" address is correct for the 88840016 ROM.
Thx.
Its at 0x103D in the 88840016.
Old Dec 1, 2009 | 11:09 PM
  #182
ace33joe's Avatar
So did everyone fix the cold start idle problem using mrfred's complete EGR shut off bit?
If I understood it correctly, EGR is operating for all temperatures if not disabled? Then if EGR is disabled, do I have to either disable warm up ignition retard completely (using periphery bit or zeroing out the control map) or change the low coolant ignition retard map by the amount of EGR ignition advance not to have "too much ignition retard" during the warm up?
Old Dec 3, 2009 | 04:14 PM
  #183
fostytou's Avatar
EvoM Community Team
This has been answered repeatedly.
The EGR builds duty cycle as coolant temp increases.
Some people report problems related to disabling this periphery bit, while others do not. I believe there is a thread dedicated to this issue that will likely be of more help to you. The only way to see if it is a problem for you is to test and see. If it is, there are things you can do to help.
That said, you should not disable the periphery bit because it may control more than just the EGR enable/disable. MrFred has posted another bit that will only change operation of the EGR. This is the bit that should be used and will not cause cold start issues.
Old Dec 3, 2009 | 05:38 PM
  #184
ace33joe's Avatar
Thanks for the reply. Your posts help me a lot.
I know this has been discussed at this thread:
https://www.evolutionm.net/forums/ec...rt-help-2.html
But I didn't see any follow-ups about the result, therefore, I asked the question here.
I will definitely try mrfred's bit after I clean my intake manifold and install 4 bar map sensor. I hope this will keep my intake manifold clean and reduce some knocks during early boost build up.
Old Feb 18, 2010 | 12:44 AM
  #185
SeanV's Avatar
Originally Posted by knochgoon24
So what would the ERG System Enable/Disable address be for 90550001?
ok, after some more disassem of the EGR routines, I have found that Periphery 0 (FAA) bit11 does not actually shut off the EGR system until the coolant temp passes ~68C. Its ok to use if you plan on ripping out all the EGR stuff. However, it turns out that there is a byte length value that completely disables the EGR system and is a better choice to use.
For USDM Evo 8 94170008-15 and EDM Evo 8 96530006 use:
<table name="EGR System Enable/Disable" category="Emissions EGR" address="103D" type="1D" level="2" scaling="uint8"/>
For USDM Evo 8 96420007-11, 96940011, and USDM Evo 9 88590013-15 use:
<table name="EGR System Enable/Disable" category="Emissions EGR" address="1041" type="1D" level="2" scaling="uint8"/>
A value of "0" disables the EGR system and sets the EGR duty to 0% all the time. "1" enables the EGR system.
Oct 4, 2009 - Fixed to show that the EDM Evo 8 96530006 address is 103D instead of 1041.
Thx MrFred...
Any chance you have the address for the 90550001 Evo7 Rom?
Thx
Old Jul 11, 2010 | 02:08 PM
  #186
tscompusa2's Avatar
Originally Posted by Evoryder
Couple shots of my engine bay minus the FPR/EVAP/EGR
(CLICK FOR BIGGER PICS)
I just had the one big cap come off of my intake mani that you used a fuel line clamp on.. man i love your ideas, cause they work. This is the second big leak issue you helped me with now.. the other one was the omni4bar map oring.. thanks!
Old Jul 11, 2010 | 03:13 PM
  #187
nonschlont's Avatar
I noticed in this pic ^, that on the TB, the 2 connections that are capped off... Do they need to be individually capped off, or can I have a hose that runs from 1 side to the other? Cause on my set up, theres one lil hose that routes to the other connection...
Note: I only have the EGR deleted
Edit: Looks like fosty answered my question already (post #133) Looks like I need to get some vac. caps...
Old Jul 11, 2010 | 08:21 PM
  #188
volks-traitor's Avatar
i've found that the crappy vacuum caps from the parts stores degrade extremely fast. try the colored vinyl ones. the natural rubber can't take the heat and pressure.
Old Jul 12, 2010 | 05:25 AM
  #189
tscompusa2's Avatar
You can loop those. I have mine looped with a short vac hose.
Old Jul 12, 2010 | 05:27 AM
  #190
tscompusa2's Avatar
Theres no way the ones I got are gonna blow.. the rubber is so thick.. and im almost positive its the same one in the picture. I did exactly what he did.. Used the cap and the fuel line clamp.. its not going anywhere.............. that rubber is THICK. the colored thin caps blow............. i had one blow on me.
Old Jul 12, 2010 | 05:30 AM
  #191
tscompusa2's Avatar
oh ****.. i guess that explains an issue i have ..... barely making 600whp on a dynojet at 39psi.. i have those looped. so thats a big boost leak? LOL. I didnt know it went to the EGR.. my egr is blocked off but still.. i will individually cap them off today i guess. I dont see how it can be a big leak tho, cause i can pressure test to over 33psi or until the tester pops off and when i let it bleed down from 33psi it takes 1-2minutes to bleed down to 0psi.
Old Jul 12, 2010 | 10:41 AM
  #192
Fast_Freddie's Avatar
Veteran: Navy
There is no way that is a boost leak if you have a vaccum line looping the two nipples off the TB. One comes out of the TB then right back in... how does this affect the EGR or cause a boost leak???
Old Jul 12, 2010 | 11:38 AM
  #193
nonschlont's Avatar
I dont quite understand it either... Maybe Fosty, or evoryder can chime in on it...
Ive felt like there was some minor lil leak somewhere, (and date it back to, right ~ that time) and havent been able to figure out what/where it is, and I dont think its my imagination... Its worth a shot...
Old Jul 13, 2010 | 07:24 PM
  #194
R0b's Avatar
R0b
its been asked but i cant seem to find the answer.
Whats the correct way to disable all these solenoids for 90550001 or 98640014 without doing it via the periphery codes?
Thanks
Old Jul 13, 2010 | 08:50 PM
  #195
Evoryder's Avatar
Do not loop the nipples. It's NOT a boost leak, it's a vacuum leak after the throttle plate. Won't affect power. It will affect driveability and idle conditions.
Attached Thumbnails Disabling EGR and fuel pressure solenoids-do_not_loop_egr-copy.jpg
