Patch: Force OBD Inspection Pass (acamus, mrfred)
Old Dec 8, 2010 | 05:06 PM
  #196
BISHILVR's Avatar
So we should be able to find these same tables in the 2g ecu then knowing what to look for right?
Old Dec 9, 2010 | 07:43 AM
  #197
HornstarBU's Avatar
Perhaps....you can also put an Evo ECU in the 2g as well though, right? Don't take my word, but I think that's been done. Then, not only do you get this one piece....you'd have a whole plethora of stuff that Evo's also get! Lancer ppl like myself can flash the evo rom right onto our ECU, wouldn't it be nice if it were that easy for you guys as well (no idea here...just spitballin')
As for EGR guy, you could remove it, pass the car, then put it back....or fix it, or keep it removed. I'd prefer the later 2 suggestions, at least clean it while you have it out, that may fix the issue!~
Old Dec 9, 2010 | 04:27 PM
  #198
BISHILVR's Avatar
Well, the dsm 98-99 ecu is flash based and uses the same hardware/software and protocol to flash with, so almost everything the evo ecu does the dsm ecu will do but without any monkeying around with custom harness's or mivec errors from no mivec and I dont even know about the security system features on the evo ecu's but from what I've read it seems like they are always an issue even for the evo guys, not sure what would happen if I would try it on a dsm? I know its been done, but just not sure how much bother it is.
Old Dec 15, 2010 | 04:22 PM
  #199
kthackst's Avatar
yeah this would be nice to have for 2gs...
Old Jan 31, 2011 | 05:16 PM
  #200
neonglh's Avatar
I just checked through the 14 pages, and didn't see it. Can someone upload the code for a 96420008 rom please. That would be great!
--mark
Old Feb 1, 2011 | 09:23 PM
  #201
BISHILVR's Avatar
Lets work on it then!
Old Mar 3, 2011 | 06:00 AM
  #202
kthackst's Avatar
Patch for 2g dsms. It's a little different. Thank you Acamus! You are a gentleman and a scholar.
http://www.dsmtuners.com/forums/tuni...#post152493561
Old Mar 6, 2011 | 06:50 PM
  #203
maplemaf's Avatar
Originally Posted by lowlife
ok...so i've been following the video tutorial to a "T" and cannot get past the part of saving the newly pasted tables. i have ecuflash closed...nothing but notepad open, but when i go to save file, it gives me the following error: Access is Denied!
what am i doing wrong??
I am running Windows 7 and my ROM file is 88590015
same thing for me ???
Old Mar 6, 2011 | 08:10 PM
  #204
Bobster22388's Avatar
Windows 7 likes to lock all the files and make them read only. If you right-click on the file your trying to edit on its location on the hard-drive. You can click properties and then advanced at the bottom and you can change the permissions for the file.
Old Mar 7, 2011 | 06:54 PM
  #205
maplemaf's Avatar
thanks i change to administrator
Old Mar 16, 2011 | 11:29 AM
  #206
neonglh's Avatar
--mark
Any luck for a bump here
Old Apr 14, 2011 | 12:37 PM
  #207
FJF's Avatar
FJF
Guys, I haven't read the entire thread, just installed the patch and reflashed the car. I'm kind of in a bind. Went to get an inspection and the readiness monitors weren't on. My fault. Do I need to drive the car for a number of miles or is it good to go right now? Thanks!! A two word answer is fine.
Edit: Reading the thread, the monitors should be "ready" immediately after installing the patch. Does this mean that I can go and get the sticker right now, given the above? A yes or no is fine.
Old Apr 14, 2011 | 02:32 PM
  #208
golruss's Avatar
You have to open your rom and set them to pass.
Old Apr 14, 2011 | 02:46 PM
  #209
FJF's Avatar
FJF
Thanks for the reply. I've done that. Back to my question. Anyone, yes or no?
Edit: To be clear, I went to have my car inspected and the monitors were not ready, or something to that effect. I forget the exact wording. I've installed the patch and reflashed the car. I have no inspection sticker, so I'd much rather drive the 1/4 mile to the service station and get the sticker, instead of having to drive whatever is necessary to reset/ready (?) the monitors and take the chance of getting pulled over. As I've installed the patch, do I still need to drive a given distance?
Old Apr 24, 2011 | 07:38 AM
  #210
Piro Fyre's Avatar
I've followed up on the video multiple times and copy/pasted multiple times and I'm still not getting these "tables" or anything that relates to OBDII. I have the 94170008 ID and so I edited it. Copy/pasted the codes via notepad and saved them. Just to make sure it was saved, I opened the file again and it's there. Open up EcuFlash and open my original map from my car and it's still not there. What did I forget? I went over the video over and over and I didn't miss much of anything.
