96530706 + DMA +LiveMap + SD - working
Old Nov 23, 2009 | 02:29 PM
  #286
ziad's Avatar
lol... looks like i am talking to myself, but basically moved the DEAD location back to its original, from A800. fixed the problem. nothing else needs to be changed. and the start location remains the same.
Old Nov 23, 2009 | 03:25 PM
  #287
l2r99gst's Avatar
lol
You're probably talking to me...but I haven't touched anything with LiveMap or my car or EcuFlash in quite some time. Just haven't had the time to do anything lately.
I'm not ignoring you though...just reading and keeping mental notes.
Old Nov 24, 2009 | 12:56 AM
  #288
ziad's Avatar
hehe. i was joking.
anyway yeah moving the DEAD back to the original location ie FFFF-841E works like a charm. which is very strange. cuz leaving it at a800 resets it.... mut table is fine as a800 holds FFFF anyway (all this is for my car/ecu) but should hold fine for other people running 9653.
Old Dec 1, 2009 | 03:30 AM
  #289
ziad's Avatar
hey eric or any1 else using this rom... does your stationary rev limit work... i have mine set at 4250 rpm and it just revs out longer
Old Dec 1, 2009 | 06:15 AM
  #290
l2r99gst's Avatar
Honestly, I don't remember the last time that I have checked it. I never launch my car. I can check it today though. The last I did check, though, it worked fine.
Old Dec 1, 2009 | 07:50 AM
  #291
03whitegsr's Avatar
Does the xml have the right address for the stationary limiter?
In my stock 94170008 and then the 94170015 ROMs, the factory value was the same as the 7600 RPM rev limiter.
On 96530006, it is 0. I noticed it and had meant to look at the addresses and make sure it was right, just never got around to it.
Old Dec 1, 2009 | 04:21 PM
  #292
ziad's Avatar
my address is 2b4a, the rev limit was set at 5000 for the rom that i am using. i tried the same address in a base 9653 and its got 0 there... strange
Old Dec 2, 2009 | 09:19 AM
  #293
03whitegsr's Avatar
Yeah, strange.
2b4a matches the ROM address in 94170015 as well and the tables below about 4000 are usually in the same location between the two ROMs.
I still have mine set to 0 so I haven't tried to see if it works.
Old Mar 26, 2010 | 06:59 AM
  #294
nabilsx's Avatar
Originally Posted by usaevo8
Hi
Has there been any progress with this issue, Im currently running the SD on my '03 and experience the 2k stutter consistently in gears 2-5 cruising and specially noticeable at light acceleration. I will post a log when I have something
do you have a wideband installed on the car? if not, have u checked the spark plugs for AFR status? I have the Omni 3bar on my EVO8, and I am running the 96531706 before I had the wide band it used to stutter at 2K RPM, when I installed the UEGO I saw that the AFR was going below 10 at that point, if that is the case then u will have to work on the SD MAP sensor VE and Calibration
SD RPM VE
my issues are like 90% solved now.
PEACE
NAB
Old Mar 26, 2010 | 07:32 AM
  #295
And's Avatar
And
does anyone know if I can use a 9 manifold temp sensor (MD326170) instead of the GM one to do the SD conversion using the SpoolinUp SD harness? are there any scalings that need changing?
Thanks
Andy
Bewstzalot
Jul 7, 2017 01:35 PM
EvilEvolution8
Apr 16, 2016 11:47 PM
dr_jing
Apr 9, 2016 10:35 PM
foxbat
Oct 1, 2015 02:48 AM
WRC-LVR
Sep 23, 2013 08:40 PM
