The DTC Disable thread (P1235, P1241, P1238, etc)
Old Nov 17, 2009 | 08:20 PM
  #226
SiC's Avatar
SiC
Originally Posted by FTY Motorsports
ya i just left it the same for the one from 0010 so if i change all those values would i be able to flash it again or will i still be locked out.
It will more than likely still be locked. Does the radiator fan turn on as soon as you turn the key to the ON position?
Old Nov 18, 2009 | 12:45 AM
  #227
FTY Motorsports's Avatar
yes it goes into the **** it does as you are normally flashing it when the key is on the fans all the lights come on etc.
Old Nov 18, 2009 | 03:18 AM
  #228
SiC's Avatar
SiC
Sounds like it's stuck in the programing state, the only way I know to recover from that (after you turned the key off) is to reset it on the bench.
Old Nov 18, 2009 | 09:20 AM
  #229
GST Motorsports's Avatar
You can try opening another rom in EcuFlash when it's doing that. Then under "ECU" select exit programming mode.
I've "unbricked" a Works flashed ECU that way. They brick themselves if you even try to read the Rom.
- Bryan
Old Nov 18, 2009 | 10:01 AM
  #230
i'll give that a try ^ but if that fails how do i reset it on the bench jon from hb speed wont return my calls
Old Nov 21, 2009 | 02:07 AM
  #231
Fourdoor's Avatar
So, how are people reading codes? I just look at the check engine light and say "that sucks" and move on
Any way to block the common codes on 55590006 (2010 Ralliart) would be wonderful!
Keith
Old Nov 21, 2009 | 03:21 AM
  #232
SiC's Avatar
SiC
Keith
Should be the following:
633e8
633de
549f8
549f4
549f6
And please note that these are the first five and DOES NOT include the P0247 Disable. DO NOT change any digits if the numbers do not match.
Old Nov 21, 2009 | 12:00 PM
  #233
still stuck in programming mode.... anyone have some instructions on how to bench flash this thing so i can fix it.
Old Nov 21, 2009 | 12:22 PM
  #234
LVSBB6's Avatar
Will there be a P1870 disabled solution?
Old Nov 21, 2009 | 03:35 PM
  #235
SiC's Avatar
SiC
I wish I could help but I really don't know how to bench them. I had to send one to Colby to unbrick one.
Old Nov 21, 2009 | 04:53 PM
  #236
well i pulled out the ecu and called my friend who used to tune my car back in the day he is a developer independently and he said Road race can bench them so im gonna take it over there monday
Old Nov 22, 2009 | 12:03 PM
  #237
criptballer's Avatar
any news on a P0140 disable code? i tried doing the CEL disable code from the other thread but i still get that code. i have disabled all the codes from this thread and i have an extender bung but i still get this damn code!
Old Nov 22, 2009 | 01:15 PM
  #238
SiC's Avatar
SiC
Did you remove the O2 sensor and unplug it from the harness
Old Nov 22, 2009 | 01:45 PM
  #239
..... didn't know i was suppose to do that..... awkward......
the harness underneath the passenger seat right?
Old Nov 22, 2009 | 01:51 PM
  #240
Clipse3GT's Avatar
If you turn off the rear O2 it will get damaged because the heater is not working any longer so then you will have a expensive paper weight.
