The DTC Disable thread (P1235, P1241, P1238, etc)
Old Mar 29, 2012 | 11:55 PM
  #511
AWDralliart09's Avatar
Originally Posted by 03chi-town0Z
AWD, I got my OBD pin-8 logging working on the standalone just a couple days ago and it's well worth it (and much less work than the rear o2 tap, imo) now if only I could find a way to get that into EvoScan. I know most of the addresses transfer directly and you just change the "0x" to "23", but since the paramid=8 for the adc logging on standalone, I can't just put "8" in the request id when adding a new data item in EvoScan, right? Still new to this and oh-so lost.
Right... Lol kinda lost me there for a minute.. Haha see I was aware of the pin 8 in the extended (rich has a thread I believe), but I could not find that thread or any other info on that way, wanting to get logging before next weekend (track day). So I was going to attempt the o2 tap. I ether way I would love for someone to point out a good thread on what's best. I ethereal I'm down for advise.
Thanks chi-town
Old Mar 30, 2012 | 01:02 AM
  #512
richardjh's Avatar
Here you go...
https://www.evolutionm.net/forums/ev...ml#post9106692
https://www.evolutionm.net/forums/09...0-pin-8-a.html
Rich
Old Mar 30, 2012 | 11:31 PM
  #513
Rich, your the man! Thank you
Old May 14, 2012 | 10:28 PM
  #514
silverbullet08's Avatar
Just learning this software. Ive been getting the p1235 code as well, where do I paste these codes from tephra into my xml? Then is it done? or do I need to actually go into the tune and turn them off there? thanks for the help
Old May 15, 2012 | 05:48 AM
  #515
momostallion's Avatar
you can paste the xml snippet anywhere inside of the matching .xml file as long as you dont nest one tag inside of another. it is best practice to keep the DTC section grouped together.
the xml file is typically located in C:\Program Files\OpenECU\EcuFlashBeta\rommetadata\mitsubishi\ evo\
and yes, after you paste the snippet to your XML file and save, you have to open ECUFlash to change the values.
the xml file is just a list of addresses needed by ECUFlash to read your rom. you actually have to change values through ECUFlash.
and remember, always check to see if the before values match.
Old May 16, 2012 | 10:15 AM
  #516
Got it working
Old May 17, 2012 | 06:39 AM
  #517
TravisF's Avatar
Is there no way to disable the P0420 catalyst efficiency code on a 2008 without taking out the rear O2 sensor, disabling the heater, and disabling all of the other codes that go along with that?
Just saw disabling the 0139 takes care of 0420 on the 2010+ years but does it work on 2008 too?
Old May 17, 2012 | 01:52 PM
  #518
Golden's Avatar
On a 2008, disable these:
DTC P0139
DTC P0140
And set the Rear O2 bit to 0 in the ECU Options Set #2 bit.1.
That's it. No need to remove sensors.
Old May 17, 2012 | 02:56 PM
  #519
TravisF's Avatar
DTC P0139
DTC P0140
Doesn't the ECU Options #2 disable the heater though? If the sensor is still in the exhaust with no heater it will be destroyed
Old May 18, 2012 | 02:21 PM
  #520
Golden's Avatar
Yes.
Old May 18, 2012 | 08:30 PM
  #521
TravisF's Avatar
Yes.
So you basically told me to destroy my rear o2 sensor two posts up?
Old May 22, 2012 | 01:51 PM
  #522
LiX's Avatar
LiX
Any chance of disabling P0247 on 5268xxxx ROM? Please help.
Old May 23, 2012 | 12:10 PM
  #523
Golden's Avatar
Yep. If you read this thread from the start, it has you do it years ago.
Old May 28, 2012 | 10:35 AM
  #524
LiX's Avatar
LiX
Anyone willing to help?
Old Jun 3, 2012 | 03:24 AM
  #525
richardjh's Avatar
I just looked at Golden's definitions. It's defined for this ROM set.
Rich
