TephraMod V7
Old May 4, 2010 | 05:55 PM
  #1756
tephra's Avatar
what is MUT43?
does your RPM_SPEED_RATIO_AVERAGE log properly? ie ~2000 for 1st.... ~25 for 6th?
Old May 4, 2010 | 05:58 PM
  #1757
tnt1106's Avatar
Originally Posted by tephra
what is MUT43?
MUT 43 = 8449
And yes rpm/speed seems to be correct, jsut its not using the gear it should for that value (ie 54 rpm/spd= 3rd gear)
Old May 4, 2010 | 06:00 PM
  #1758
tephra's Avatar
what does your "RPM/Speed to Gear" table look like?
It's in the TephraMOD-V7 category..
Old May 4, 2010 | 06:02 PM
  #1759
tnt1106's Avatar
RPM/SPD Gear
3 6
28 5
41 4
54 3
73 2
104 1
1802 0
(same settings used in V6 with gear based and worked great)
Old May 4, 2010 | 06:03 PM
  #1760
tephra's Avatar
do you have a 5 speed box?
email me your ROM... the code in the stock V7 ROM looks like it should work correctly...
Old May 4, 2010 | 06:05 PM
  #1761
tnt1106's Avatar
Yes I do have 5 speed. Email on way. Thank you.
Old May 4, 2010 | 06:12 PM
  #1762
tephra's Avatar
check your scaling on the gear table... particularily the RPMPerKPH..
are you doing the calculation in miles per hour or kph?
Old May 5, 2010 | 06:23 AM
  #1763
tnt1106's Avatar
ECUflash is set rpm/ mph
evoscan is rpm/ kph.
so even if evoscan logged it wrong wouldn't it still function correctly in the rom?
EDIT: I see where the error is Thank you Dave! (scaling was RPMperMPH)
(Is the the proper scaling for "Gear" side (right column) unit8 (scaling for my V6 rom) or RPMperMPH Gear? (scaling in current rom)
Old May 5, 2010 | 06:25 AM
  #1764
smithrcing17's Avatar
i love my tephra =]
Old May 5, 2010 | 06:28 AM
  #1765
tephra's Avatar
both scalings need to match - otherwise your inputting wrong data...
Old May 5, 2010 | 08:01 AM
  #1766
tnt1106's Avatar
Thought so. Thank you as always Tephra! otw
Old May 6, 2010 | 12:27 PM
  #1767
VGergo's Avatar
hello
If i'm just flash on the "Option 2 94170715 (v7 + Mods Omni 4 Bar MAP)" without any map copy than my evo will run on the stock boost fuel and ignition map ?
Old May 6, 2010 | 05:26 PM
  #1768
widge's Avatar
Hey Guys,
I want to flash 96530706 to my E8 but its a 5 speed will this be ok?
Old May 6, 2010 | 06:52 PM
  #1769
darkmitsu's Avatar
hey guys when running v7 how do you disable the knock sensor , because i'm running a 4g64 on speed density and the 4g64 I have does not have a knock sensor on it , and I dont plan on installing one... I read somewhere that periphry 0 bit 7 is the one you change but it listed as something else , in the 965xxxxxxx rom...
Old May 9, 2010 | 05:38 AM
  #1770
And's Avatar
And
SORT THIS NOW is there an error in the XML files for the 96531706 roms? as I've down loaded the rom fresh and the SD RPM VE data looks very odd, here is an image of what i'm on about
the address values are MAP 337C and rpm 65f6
thanks
Andy
