TephraMod V7
Old Jan 1, 2016 | 04:10 AM
  #3286
evo8426's Avatar
Originally Posted by Sascha
I run a 03 Evo VIII GSR in Europe (no Import, so it is EDM), with 5 Speed Gearbox and have never used Tephra, wich ROM is the correct for me?
I donīt wanīt to go on Speed Density, if that make a difference.
Thank you guys!
Tephra listed this in post number two, "96530006 is the universal Evo VIII Rom."
Old Jan 1, 2016 | 04:14 AM
  #3287
3gturbo's Avatar
The ROM with all the goodies is 96530706 will work for your car.
Old Jan 1, 2016 | 05:00 AM
  #3288
Sascha's Avatar
Thank you, so Option 2 - Thanks to l2r99gst 96532706 (v7 + Live Map + MAF)should work fine??
Old Jan 1, 2016 | 06:12 AM
  #3289
evo8426's Avatar
Thank you, so Option 2 - Thanks to l2r99gst 96532706 (v7 + Live Map + MAF)should work fine.
I would go with option 1 personally, keep it simple.
Old Jan 2, 2016 | 06:37 PM
  #3290
dinosaur54's Avatar
big map links?
Hi. Have the links to "big map translator" and "big map smoother" been broken or shut off. Clicking on them takes me to blank page at globalshare. Thought they sounded worth trying, but could just fill in maps manually I suppose. My thanks to everyone who shared their knowledge and experience. Exciting for an old dog to take his car skills to a new level. and to all!!!
Old Jan 3, 2016 | 05:16 AM
  #3291
3gturbo's Avatar
Originally Posted by dinosaur54
hi. Have the links to "big map translator" and "big map smoother" been broken or shut off. Clicking on them takes me to blank page at globalshare. Thought they sounded worth trying, but could just fill in maps manually i suppose. My thanks to everyone who shared their knowledge and experience. Exciting for an old dog to take his car skills to a new level. and To all!!!
Big Maps smoothing.zip
Old Jan 3, 2016 | 05:39 PM
  #3292
dinosaur54's Avatar
Thank you 3g. Time to learn my puter skills(excel) to the next level
Old Jan 6, 2016 | 02:35 PM
  #3293
merlin.oz's Avatar
Tephramod 9626 is a better rom to use than 9653 as it is much simpler, has no rear o2 and less emissions code.
Old Jan 6, 2016 | 04:17 PM
  #3294
evo8426's Avatar
And requires him to send a donation which he may never even figure out how to tune himself, plus waiting time for a response.
Old Jan 16, 2016 | 04:28 PM
  #3295
essej's Avatar
When switching over to tephra I get the car to crank over but it wont start! I've been searching around and all I see is people saying it's the immobilizer hex..
I've tried changing the value and the same problem persists. Here I have attached is the rom I currently have on the car and the tephra rom I'm trying to flash. What's wrong? It seems like I do have a immobilizer problem but I changed the values to match exactly like the current one.
I've tried both the evo ix tephra rom's and they both just crank over (v7+mods and speed density). I am trying to switch over to speed density. Also, I haven't yet changed the init code but I'm pretty sure I'm not supposed to touch that as I followed step 5 on https://www.evolutionm.net/forums/ev...hramod-v7.html
Edit:
I've downloaded ecuflash 1.44 and checked the immobilizer and it shows to be different. However, the version ecuflash (1.29a) I'm using only works with my cable (tactrix 1.3m) and the codes are the exact same. What do I do?
File Type: bin
File Type: bin
Old Jan 16, 2016 | 05:39 PM
  #3296
ronaldo9's Avatar
Can you try to disable the immobilizer to see if it will start?
Old Jan 16, 2016 | 07:30 PM
  #3297
essej's Avatar
I can try but I wouldn't want to have that as my solution. Is it setting the immobilizer to 0x0000?
Old Jan 17, 2016 | 11:36 AM
  #3298
ronaldo9's Avatar
Can you try a non speed density rom to simply things? Make sure you don't need to alter some settings in the speed density rom if that is what you want to use. My car required 0x0058 for the immobilizer hex. And setting the immobilizer to 0x0000 will not work, I believe you have to go into the periphery bits to disable it.
Old Jan 17, 2016 | 06:14 PM
  #3299
essej's Avatar
Yup! I disabled it and the same thing happens. I have no idea why its not starting. I've tried my other key (not programmed) on the original rom and it has the same symptoms as the reflash.
Old Jan 18, 2016 | 05:10 AM
  #3300
Floppyz's Avatar
Merlin,
where is possible to download 9626 with tephra options for try if it works good in EDM evo8's?
I can only have a 9626 stock, but it could be great to check NLTS, CEL on Knock, drop boost on high knock, map switchin ect...
tks
