TephraMod V7
Old Mar 27, 2016 | 08:46 PM
  #3316
ecktt's Avatar
Originally Posted by saadme
Got it thanks!
Just wondering, is there a speed density and live map version of 9055001?
Thanks!
I have a beta somewhere but never got the chance to test it. I can only assume that there is a more final version out there.
Old Mar 30, 2016 | 02:19 AM
  #3317
seiya99's Avatar
Hi, looking for evo7 Tephra v7 rom with SD
Will make a donation for the Rom.
Thanks
Old Apr 5, 2016 | 08:53 AM
  #3318
fabiangt79's Avatar
Can someone send me a rom for JDM evo 8 ECU with speed density?
Thanks
Old Apr 10, 2016 | 02:34 AM
  #3319
saadme's Avatar
Nice any info, or can you send the beta?
How does live map work anyway, can't find much info about it.
Is there one for Evo 9s?
Old Apr 13, 2016 | 07:39 AM
  #3320
itsali's Avatar
I've searched high and low, and can't find the answer - I hope someone can help me!
Trying to set up load based boost control on tephramod v7 with gs 3port.
Can anyone verify the corrrect addresses for the below, romid 96260709?
Global Boost Control Type
Variable for Boost Control – Enter “xxxxxx” for Load based or “xxxxxx” for PSI based boost control
Boost Error RAM Address – Enter “xxxxxx” for Load based or “xxxxxx” for PSI based boost control
Load Error RAM Address – Enter “xxxxxx” for Load based or “xxxxxx” for PSI based boost control
MUT8A – Enter “xxxxxx” for Load based or “xxxxxx” for PSI Based boost control
MUT8B – Enter “xxxxxx” for Load based or “xxxxxx” for PSI based boost control
Direct Boost
SHLR ->SHLL for EBC – Enter “xxxxxx” for Load based or “xxxxxx” for PSI based boost control
Old Apr 13, 2016 | 06:06 PM
  #3321
4g64turbo's Avatar
Does anybody know the proper settings to change to account for a stroker engine running speed density? (2.3)
Old Apr 14, 2016 | 12:46 AM
  #3322
Biggy VIII's Avatar
Displacement doesnt realy matters in this type of SD realization. Just start tuning ve tables to archieve load that you need.
Old Apr 15, 2016 | 08:27 PM
  #3323
ae92rolla91's Avatar
i am trying to get tephramod to work on my 03 jdm evo 8 gsr i have map 93660005 and i am trying to use tephra mod 96530706. the issue i have is i can get it to start but not idle it stalls as soon as it fires up. one thing i have noticed is that my original mad is in celsius and tehphra mod is in fahrenheit. the iscv control relys on this does anyone have a conversion or a work around for this issue. any guide or help will be appreciated as i cant wait to get all the options finally running
Old Apr 23, 2016 | 04:33 AM
  #3324
3gturbo's Avatar
Thats a definition issue. The display your seeing is the conversion of the data from the ecu into whatever your definition is. So change the definitions to Fahrenheit. Ceddy did the same thing with the 2g eclipse rom simple to change it though.
Old Apr 24, 2016 | 08:48 PM
  #3325
6spdlegend's Avatar
The links on the first post are dead- I'm looking for 88590715-TephraMod-V7.zip
can anyone help? please
Old Apr 24, 2016 | 09:24 PM
  #3326
CDrinkH2O's Avatar
http://lmgtfy.com/?q=88590715-TephraMod-V7
Old Apr 25, 2016 | 09:00 PM
  #3327
6spdlegend's Avatar
Originally Posted by cdrinkh2o
Yeah I found the mirror right after posting- but thanks lol.
Old May 4, 2016 | 02:52 PM
  #3328
badwheel's Avatar
I am preparing to switch over to the Tephramod and the link to the big map translator seems to be broken (see below). Is there a copy stored anywhere else? I would prefer to avoid the manual conversion method.
(https://www.evolutionm.net/forums/7597112-post3.html
Old May 7, 2016 | 05:37 PM
  #3329
raulhp's Avatar
Hi to all
I hope someone could explain what is happening.
I have a Tephra v7 version por Euro evo 9, i can't use the USD version because the Check light is on for the fuel tank evap (euro car hasn't)
Well, i have the ROM 88580714, but when i tuned it and load on the ECU, then i can't recover this ROM or when i opened my saved Map from my laptop. when i read the ecu or reopen the map in the laptop, the ROM is a EDM 88840016
i tried in several EVO 9 and always is the same, i can use the tephra file for the first time, but when i save it with other name or try to recover from the ECU, Ecuflash changes the ROM to EDM 88840016, so any Tephra options are not available, but the car still has all tephra features.
I loaded all the Tephra definitions again on the rommetadata, removed all evo9 XML, but always is the same. If i want change something...i need built a new map from the ROM 88580714 scratch!!!!
Old May 29, 2016 | 08:23 AM
  #3330
Zakie@TIC's Avatar
Jdm evo9 89280002
I'm experimenting the TephraV7 ROM 88591715 on a friends race car running a 34mm restrictor as per our racing rules. I'm also attaching the file which I started the car with just incase I have changed something which I shouldn't.
My issue is after a few minutes of engine running it throws a engine check light and on scanning it says "J2534 init error ERR_FAILED" and it keeps coming back immediately after erasing. It also makes the ABS and ACD lights to blink, I wonder if both these issues are related. I have Merlins map loaded on the ACD ecu.
Some input on this issue will be greatly appreciated.
Zakie
Sri Lanka
