new live map app
Old Dec 23, 2010 | 04:18 PM
  #256
ziad's Avatar
ok a quick update, i have the new version available to download. auto tune is disabled in it currently (but it is out to testers) so hopefully in a few weeks i will have an updated one with that too
also and i am being upfront, this app is time limited till 1st June 2011. After that date this version will not work. This so that people update to the latest version. I do not have any intention to charge money for my work.
saying that i wont mind a donation of a coffee or two if u like the program. or if someone can do a good instruction manual that would be absolutely appreciated.
Old Dec 23, 2010 | 05:19 PM
  #257
drifterific's Avatar
Ziad will this work with speed density roms or just maf? Thanks.
Old Dec 23, 2010 | 05:28 PM
  #258
ziad's Avatar
as long as you have a DMA rom it will work.
currently the only V7 rom is 9653 (SD and non SD). the others are all v510. to use this program ur rom has to be dma enabled. if it isint then download one of the ones that are available.
Old Dec 23, 2010 | 07:13 PM
  #259
golruss's Avatar
Its asking for a password to install, whats the password please?
Old Dec 23, 2010 | 08:41 PM
  #260
sounds good. Im running 9653 so I will try this out.
EDIT: Also do we still need OP1.3 cables or is this now compatible with OP2.0 cables Thanks.
Old Dec 24, 2010 | 04:25 AM
  #261
philr8's Avatar
You need OP 1.3
Old Dec 24, 2010 | 03:28 PM
  #262
gktuning's Avatar
Setup Wizard EvoLiveMap 0.3.2.0 asking for a password to install, what is the password please?
P.S. sorry, my English very bad.
I thank for magnificent work Ziad!
Old Dec 25, 2010 | 01:40 AM
  #263
Andy_8's Avatar
Need a password for install. ???
My car was live tuned on the last version and looking forward to trying this new one.
Old Dec 29, 2010 | 01:41 AM
  #264
ziad's Avatar
sorry away on xmas holidays
setup password=elmbeta
i will reupload a new setup file without the password tomorrow
Old Dec 31, 2010 | 06:21 AM
  #265
Creamo3's Avatar
Just downloaded and will be testing this out; thanks for all your work
Old Jan 3, 2011 | 07:29 AM
  #266
nitai3g's Avatar
hey ziad how exactly does the auto tune work?
Old Jan 3, 2011 | 12:34 PM
  #267
ziad's Avatar
auto tune is not enabled in this version. but basically you have a target map. then do a few runs after every 100% throttle application (pull) the program computes the cells its going to change and the new AFR there. then writes it to ram.
its not perfect but comes pretty close, and u still need to do a bit of smoothing and interpolation.
Old Jan 4, 2011 | 09:07 PM
  #268
fjo_newport's Avatar
Just an FYI you need to change a few parameters in the altmap vectors to get live mapping to work (at least for 96532706). Fortunately there is a XML def for it and it is labeled well. I've attached a pic to illustrate what I am talking about.
This table just points to what maps you are using, so I have my alt-maps set to RAM were the livemap program can make changes. If left stock as when the hex file was downloaded they point to ROM so any changes made don't actually effect the car.
EDIT: These changes need to be made in ECUFLASH not livemap. so this is a general FYI as it was not obvious when it was not working for me.
Old Jan 4, 2011 | 11:14 PM
  #269
ziad's Avatar
yep correct...... hopefully in the next version that wont be a necessary... i am looking being able to make a normal rom into a dma rom from the program so the new rom can be flashed onto ur car via ecuflash.
obviously wont be for all roms
after that i think i will get the donation bar out like everyone else
Old Jan 5, 2011 | 08:51 AM
  #270
golruss's Avatar
Definately deserves donation for the hard work.
