new live map app
Old Mar 19, 2012 | 03:45 PM
  #451
07EvoIX's Avatar
hey ziad, with the LC1, would it also work using serial directly? currently i just connect it directly to serial without using a converter.
cheers
Old Mar 20, 2012 | 01:13 PM
  #452
ziad's Avatar
got their protocol.. its a lot simpler then LC1. Eric i will need ur help to test out a small app first. i will send u an email in a week or two but it all depends if i can fix this blue screen issue...
fadee, it should, its just a normal com port... but i am intrested/surprised u got a laptop that actually has a serial port???
Old Mar 20, 2012 | 01:29 PM
  #453
Raptord's Avatar
Great to hear! Will be standing by for your email.
Old Mar 20, 2012 | 02:50 PM
  #454
07EvoIX's Avatar
HP ProBook 6555b laptop
though it runs Win7 so my Belkin serial-USB wont work on it as there are no drivers
cheers
Old Mar 24, 2012 | 11:26 AM
  #455
burgers22's Avatar
I have 90556701 SD loaded, logging the and live map is fine.
But there is an issue with loading the VE table to the live mapping. I have selected 90556701DMA ROM and live xml. When selecting the Enable VE option from ECU definitions tab, EML give me the error, "no VE table found, create a VE table" The VE table actually exists in Donners original 90556701 xml, but it looks like ELM is deleting VE section of the xml.
Left xml in EML settings folder, right donner's origional
Attached Thumbnails new live map app-vetablegone.jpg   new live map app-sdfail.jpg
Old Mar 24, 2012 | 01:27 PM
  #456
donner's Avatar
Just tested reading VE map with live on the bench ecu and it worked (also map tracing as function of map worked) but not perfectly, there is something strange when I select Enable SD and program gives some error message. This happens also with 9653 3d VE version which is more commonly used with live and prooven to work as we used it a lot last summer (not with Enable SD function though as IIRC it was not available last summer yet). For me it did not remove anything from xml but like said some error essage was given.
Did you try to tune VE (and other tables) with live and it worked fine and problem is just tracing (that is what Enable SD does)?
Old Mar 25, 2012 | 01:07 AM
  #457
burgers22's Avatar
Well this is odd, reloaded the xml this morning and selected the VE enable and all is OK. I'll test the VE tracing later.
Old Mar 25, 2012 | 03:11 PM
  #458
ziad's Avatar
that is strange... i dont have a SD rom so testing this stuff is next to impossible for me. but once external WB support is done i will test this. yes i remember donner mentioning that map tracing error but i havent had a look at that sorry., i forgot all about it.
Old Mar 26, 2012 | 12:04 PM
  #459
burgers22's Avatar
No worries ziad. I can confirm the VE read is displaying some odd figures but the rest of the live tracing is going pretty well.
Old Mar 26, 2012 | 01:51 PM
  #460
ziad's Avatar
looks like the next update will be a big one
so might be a couple of weeks till i get everything working reasonably good enough to give it to u all (beta testers)
Old Mar 27, 2012 | 08:43 PM
  #461
ziad's Avatar
ok serial WB is working (just doing some testing, haha) thanks to eric the code for ZT2 will be working. but as i expected the refresh rate isint as fast.
i get 41lines/sec currently and the LC1 via serial refreshed 11 times. and ZT2 will be even more slower. hence for a permanent install the analogue to ecu is the better option IMHO.
can someone email me a SD log (to test SD map tracing) please also the romID as well.
Old Mar 28, 2012 | 11:56 AM
  #462
And's Avatar
And
hi ziad i've emailed you some logs
rom is 96536706
Andy
Old Mar 28, 2012 | 12:47 PM
  #463
ziad's Avatar
andy when u read the VE table does it have corruption or does it display as it should??
Old Mar 28, 2012 | 12:53 PM
  #464
And's Avatar
And
i read it this morning and didn't notice any corruption, i'll do a more line by line check in the morning though, although I believe the last time I looked it was fine
the tracing part just stays in the top left corner though
Andy
Old Mar 28, 2012 | 04:49 PM
  #465
ziad's Avatar
Andy in ur case mate, can u retry VE tracing. but first goto "ECU DEFINATION" tab in settings and click "Enable SD"
i just tested and it seems to work for me. can people explain what the problem was? i have run two different files from two people through ELM.
what VE tracing requires is:
Enable SD (checked)
MAP (request in kpa)
Sample log:
sample map trace output:
