**Need Help setting up V7???** Here is your answer
Old May 31, 2011 | 12:39 PM
  #376
Diego 10's Avatar
This evening I try the same rom with immo disabled in periphery...the car starts well and it seems drive well too,the only thing is that i saw a little differences on turbo pressure and some oscillations during full throttle...(talk about stock map) do you see something like this dparrish??
Old May 31, 2011 | 01:41 PM
  #377
Diego 10's Avatar
Sorry another thing...this is my ecuflash v7 screen turbo boost dual solenoid and some other maps are not able to be changed....
Attached Thumbnails **Need Help setting up V7???**  Here is your answer-ecuflash.jpg
Old May 31, 2011 | 06:33 PM
  #378
dparrish's Avatar
I had seen similar things when I first moved to 96530706 from my 9626 stock ROM. It was just a matter of tuning it. You can't just drop in a new ROM and expect it to run the same. There are quite a lot of tables to modify.
Specifically, I think fixing injector scaling and injector battery voltage latency compensation fixed my "oscillations" and copying across (and smoothing) my fuel and ignition maps as well as fixing the WGDC map fixed the turbo pressure.
Old Jun 1, 2011 | 02:42 PM
  #379
kevo31's Avatar
Originally Posted by todd6027
Is valet mode enabled ???
The flash is the only thing i did to it when it wouldnt start, when i go back to my stock rom it runs fine. I checked the valet mode and its not enabled, any other ideas??
Old Jun 1, 2011 | 02:58 PM
  #380
todd6027's Avatar
does it run for a sec then cut out ??? Is enable auto-valet on fresh ignition set to 1 ?
Old Jun 2, 2011 | 02:12 AM
  #381
Diego 10's Avatar
Thanks dparrish now i try to set up all the things!!!
Someone can help us to set the immo hex and start the car without disable the immo in ecu periphery?
Thanks
Old Jun 5, 2011 | 09:29 AM
  #382
kevo31's Avatar
Yeah it runs for a sec or 2 then kindof sputters out, it seems like if i give it some gas to try to keep it running it will run for a few more secs. Enable auto-valet on fresh ignition is set to 0
I also tried 94170715 and it does the same thing
Old Jun 5, 2011 | 10:31 AM
  #383
todd6027's Avatar
enable valet mode and auto-valet on fresh ignition and try again , ign on press and hold down the accelerator pedal till eng flashes slowly let off then start
Old Jun 5, 2011 | 11:51 AM
  #384
kevo31's Avatar
Just tried flashing the 96530706 v7 to my car for the first time with the warmer weather and the care started and ran fine for about 15 secs then died, then tried enabling the valet mode like you said and it did the same. Tried the 94170015 v7 and it started and ran fine, so it seems to have something to do with the temp
Old Jun 6, 2011 | 10:04 AM
  #385
kevo31's Avatar
I got in to run fine now, i deleted the rom and the xml definitions and downloaded it again and it works fine now lol Between 94170715 v7 and 96530706 v7 would one be better then the other to use on a usdm evo 8???
Old Jun 6, 2011 | 01:34 PM
  #386
todd6027's Avatar
toss a coin
Old Jun 6, 2011 | 03:36 PM
  #387
kevo31's Avatar
toss a coin
haha good enough for me. thanks for all your help, its greatly appreciated
Old Jun 6, 2011 | 03:59 PM
  #388
todd6027's Avatar
Old Jun 8, 2011 | 03:15 PM
  #389
Diego 10's Avatar
I guys I have some problem with 2 byte load...evoscan reads unbelievable values...up to 3 thousand...I check on V7 main topic but i don't understand how to set ecuflash and evoscan to read correct...anyone can help me please?
Thanks so much
Old Jun 8, 2011 | 11:49 PM
  #390
And's Avatar
And
2 byte isn't set up in the v7 roms you have to use the 1byte
