**Need Help setting up V7???** Here is your answer
Old Nov 8, 2012 | 05:06 PM
  #481
AutoXer's Avatar
If I load my old ROM (attached) the clicking around atmospheric pressure goes away. I want to use the other ROM, but the clicking drives me nuts. Could this have something to do with the 4 Bar MAP sensor that I'm using?
Old Nov 10, 2012 | 08:46 AM
  #482
el.guerrero's Avatar
88590715 on edm gsr
I have problem flashing 88590715 on my edm car.
First i try with 88590015 cause is a stock rom,and my car cranck but it immediatly die.
what happens???
i read somewhere that some pin on ecu like fuel pump can be different.
Is it true???
My stock rom is 88840006.
Thanks for replyes
Old Nov 30, 2012 | 04:29 PM
  #483
FATDAT7's Avatar
Hi Guys,
I have just installed the 88580714 V7 ROM into my AUDM Evo IX, original ROM 88580013. It is great love the extra features!
I have a couple of things I can’t figure out.
I have removed my rear oxygen sensor and replaced with an Innovate MTX-l Wideband wired into the ECU. I am getting a rear O2 sensor heater Check engine light (error code PO141). After installing V7 the light still come on when starting the car. The rear oxygen sensor simulator is activated and Bit1 on FAA is also activated. I there something else I need to change?
Also my car now drops into open loop far easier than previously. I have checked tables Open loop load 1 & 2 and Open loop throttle 1 & 2 and they both match up to the original rom. What else can cause this? It also seems to take a lot longer to go back into closed loop when coming to idle . It can be sitting on an AFR of 12 at idle for a minute or so before going back into closed loop.
Old Jan 17, 2013 | 01:39 AM
  #484
markyang83's Avatar
88570008 to 88590715
The 88590715 works on my JDM 88570008.
Two issues:
1. the engine light will always stays on once the engine restart. The only way to fix it is to flash the ecu again. However the rom image has to be changed a bit,doen't matter what to change as long as its diffirent to the image stored in the ecu.
2. the ICS no longer working, the ICS green light will not comes on when switch to auto. It controls the Alt Map though. I can tell by loging my Timing ADV.
By the way the evosan shows fault: j2534 read error-16
Help please.
Many thanks
Mark
Old Jan 17, 2013 | 06:29 AM
  #485
evo8426's Avatar
The clicking you are hearing is coming from the Grimmspeed, the valve is opening and closing. The solution I have seen posted was to put foam or rubber between the Grimmspeed and the chassis to keep the noise down.
Old Jan 23, 2013 | 10:03 PM
  #486
hattackk's Avatar
Is it required to load the 9417XXXX rom(included with the download) or can you edit your original 9417XXXX.xml to add the V7 features?
Old Jan 25, 2013 | 07:18 AM
  #487
Dragracer187's Avatar
Originally Posted by FATDAT7
Hi Guys,
bump for answers
Old Feb 10, 2013 | 05:37 PM
  #488
noobers8's Avatar
coverted from 94170008 to 94170715v7 and everything seems good except the baro,vss,injector codes keep coming up. is this common and is there a fix for this?
Old Feb 12, 2013 | 10:18 AM
  #489
Daily'dEvo's Avatar
So when I download the ROM files from the V7 thread, there is no rom file in it. It's just an XML and a .bin
Am I missing something here or do I just suck?
Old Feb 12, 2013 | 10:34 AM
  #490
And's Avatar
And
The bin file is the rom ;-)
Old Feb 12, 2013 | 08:45 PM
  #491
detroit pistins's Avatar
Quickie: can I fully remove the stock BCS after switching to V7? am running an MBC and could use the weight reduction..lol
If so, is there a bit to turn it off to avoid any potentials cel's? I dont remember seeing it in the tephra bits table.
Thx
Old Feb 13, 2013 | 03:43 AM
  #492
domyz's Avatar
I just want to post the link to the v7 guide we've made. It's not over but still it's quite advanced.
https://www.evolutionm.net/forums/ev...hramod-v7.html
Maybe it could answer some random questions asked in this thread.
Old Feb 14, 2013 | 12:20 AM
  #493
stunt2's Avatar
hey guys, I have a question about 1byte to 2byte load factor in rom
does it matter for car operation what load factor would be there in rom or it just matters only for logging purposes/evoscan ?
Old Feb 14, 2013 | 12:56 PM
  #494
noobers8's Avatar
****update**** the codes seem to happen right after a flash, the codes will vary sometimes it thows inj,egr,fuel pump,baro,vss and im sure im fogetting a couple . thinking about just going back to the original rom since it works without codes?
Old Feb 14, 2013 | 04:38 PM
  #495
ReaperX's Avatar
Stunt, the load factor matters for logging purposes as it takes 2-byte and divides it by the factor in the rom, and then evoscan multiplies the 1byte by that factor to show load.
noobers, are you using the base 9417 V7 or would ou by chance accidentally using one setup for the omni 4-bar? Have you tried using the other VIII V7 rom?
