Virtual Dyno - Standalone Software
Old Sep 1, 2010 | 06:36 AM
  #481
Jack_of_Trades's Avatar
Actually, that's me. Told you I have a sexy body lol.
Old Sep 1, 2010 | 10:43 AM
  #482
tunermt's Avatar
sweet tities!
Just added a few cars to the cars.xml file saved and good to go, pretty simple stuff for the most part i suppose. Thanks again to everyone and great work.
Old Sep 1, 2010 | 01:13 PM
  #483
BillSpec's Avatar
Anyone having issues with BOOST displaying in the graphs?
I am including "Engine Load", in the parameters that I export to the text file.
Perhaps the software looks for a "boost table" rather than "engine load"?
Or, I could be just going crazy
Other than that, this software is awsome dood
Love the profile option
Old Sep 1, 2010 | 02:49 PM
  #484
Raptord's Avatar
The software is looking for boost, not load. Boost needs to be logged for it to be able to graph it, it can't calculate it from load.
Is that what you meant?
Old Sep 1, 2010 | 03:00 PM
  #485
Z_Lancer_Man's Avatar
This may be a stupid question, but the HP and TQ that this tool reports, is it calculating it at the wheels or the crank?
Old Sep 1, 2010 | 03:11 PM
  #486
at the wheels. It's not possible to measure the actual crank HP without knowing the exact drivetrain losses your particular vehicle may have. You can however measure the power being applied to the wheels quite accurately though with datalog information.
Old Sep 1, 2010 | 03:13 PM
  #487
Originally Posted by Jack_of_Trades
at the wheels. It's not possible to measure the actual crank HP without knowing the exact drivetrain losses your particular vehicle may have. You can however measure the power being apied to the wheels quite accurately though.
Excellent - that's what I thought, but just wanted to be sure, so I wouldn't get my hopes up too high with my self tuning. I made an adjustment to my timing map yesterday and added 30 HP and 40 TQ. Just wanted to be sure it was real! Sure felt real
Old Sep 1, 2010 | 03:57 PM
  #488
Try not to make comparisons from different days if the weather conditions were 'drastically' different (like a 30 degree difference lol). Try to at least have the air temperature be within 5 degrees of the log from the previous day whenever it's possible. Air temps have the biggest impact on power fluctuations since colder air will gain HP.
Old Sep 1, 2010 | 04:35 PM
  #489
VGergo's Avatar
Hello,
Why I can not open my log ? I did it by Evoscan. The error said : E107: Input string was not in correct format . I can get other problem like in the picture with my settings. But never show anything in the graph
Downloaded a log from member here change the settings but got TPS trimming problem too.
my LOG : http://rapidshare.com/files/41654022...8_15.26.42.csv
Old Sep 1, 2010 | 05:02 PM
  #490
bbarnhill's Avatar
Originally Posted by VGergo
Hello,
If you arent logging TPS then you need to uncheck the AutoTPS trimming option. If you are logging TPS you need to see what WOT is and if its not 99 or greater you wont see any data points (If WOT is 87 as ive seen in some other logs set it to like 80 or so). It trims any data value out of the log that has a TPS less than what you select there. This gets rid of the idle portion at the beginning of the run and the coasting/decel portion of the run. Thats its purpose. The 'error' you are seeing on the screen isnt an error at all. Its just letting you know why you arent seeing any graph. I figured that was nicer to say to the user than to just see nothing.
Also looks like you are using commas instead of peroids for decimal points. Ummmmm ... use decimal points.
I also cant get the log to throw that error on me. Let me know if you are using a different log or something.
Let me know if you need more help.
Old Sep 1, 2010 | 09:26 PM
  #491
BillSpec's Avatar
I apologize for not being clear.
I am using this for a few AEM cars, and I dont show boost.
I select: Engine speed, afr, and engine load.
So what do I need to change to make this thing see "engine load" as boost?
Old Sep 2, 2010 | 12:27 AM
  #492
VGergo's Avatar
Hello
I'm logging TPS as you can see in the log, and my TPS setting in the VR is 90%, but i tried everything..
How to use decimal point ? :$ my evoscan logging with commas, when I would like to open my logged .csv to see normal column I have to choose "commas"
When I try to open my log the RPM trim setting is between 1-99999 ?!
Coud you send me a correct log what you can open ? Maybe than I will know the mistake.
Old Sep 2, 2010 | 05:56 AM
  #493
bbarnhill's Avatar
Engine load isnt boost. It looks for a boost column and not load. If you wanted to graph load under boost you could just put it under the custom column names in options.
Old Sep 2, 2010 | 06:24 AM
  #494
Mellon Racing's Avatar
I think the confusion here is because aem ems calls boost "load" whereas the same isn't true with evoscan
Old Sep 2, 2010 | 06:38 AM
  #495
bbarnhill's Avatar
if this is the case I need to add that column. Let me know.
