Virtual Dyno - Standalone Software
Old May 20, 2011 | 12:43 AM
  #1066
yrkesman's Avatar
Originally Posted by RSMike
I have a Link G4 standalone ecu (www.linkecu.com)
I can convert my log files (*.llg) into CSV files.
I'm using Time, RPM, TPS (and other) columns (boost and AFR unticked).
It's coming up with "E101: Not all columns needed for calculations found."
Could you please help out?
I can send you the logs etc in CSV format with whatever you want in them.
Cheers, Mike
Do you use decimal point or decimal dot in your windows?
Old May 20, 2011 | 06:11 AM
  #1067
bbarnhill's Avatar
Since it auto detects the type of log and displays that as well, send me a copy of a log thats exported so I can start collecting column names for that particular logger. Do the column names change somehow between yalls loggers? Do you set your column names to export? I guess most of those would be answered by the logs.
Send me a couple of logs to bradbarnhill at hotmail com
Thanks,
Old May 20, 2011 | 09:47 PM
  #1068
hediki12's Avatar
a cool feature in another release would be avg hp and tq in power band (5k-8k) or what ever the you select your power band to be depending on what the car is used for .
also any plans on implementing a 1/4mile analyzer ?
Old May 20, 2011 | 10:22 PM
  #1069
bbarnhill's Avatar
Yeah I actually have the code in there for a 1/4 and 1/8 mile estimate but it needs some verification before releasing that. Id hate to release it now and it be in accurate. Its hard to estimate it off of just peak numbers. I think the formulas need tweaked a bit. Dont worry thats in the works. It just may be in next release instead of this release. Just depends on if I can get it working by then.
Old May 21, 2011 | 09:42 AM
  #1070
hediki12's Avatar
nice
umm do you or any one know how the 2byte rpm works with this? for evos thatll rev past 8k of course
Old May 21, 2011 | 09:08 PM
  #1071
bbarnhill's Avatar
I think mellon may know ...
Old May 25, 2011 | 04:33 AM
  #1072
gialla's Avatar
Using 2byte rpm, working fine
Old May 25, 2011 | 04:43 AM
  #1073
hediki12's Avatar
thank you
Old May 25, 2011 | 05:49 AM
  #1074
Raptord's Avatar
2byte rpm works just fine.
Old May 25, 2011 | 05:50 AM
  #1075
bbarnhill's Avatar
Dont scare me like that
Old Jun 2, 2011 | 12:52 PM
  #1076
bbarnhill's Avatar
1.1.0 released today
Old Jun 2, 2011 | 03:19 PM
  #1077
nonschlont's Avatar
Hey Brad,
Congrats on the new release!
Just installed 1.1. I got a few errors upon loading up of the program, as well as a couple errors upon loading the log...
I loaded up the log, set the smoothing to 3, and log seems to be reading fine, accept the "ramp up" (spool) to full tq is kinda different...
heres a SS
1.1
1.0.7
Old Jun 2, 2011 | 03:43 PM
  #1078
wizzo 8's Avatar
Is it because one is set to smoothing 3 and the other to 5?
Old Jun 2, 2011 | 03:51 PM
  #1079
tscompusa2's Avatar
remember that smoothing 3 is more like smoothing 8 compared to 1.0.7 brad changed the smoothing quite a bit. normally peak tq never occurs before peak boost atleast on a manual controller with no boost creep occurring.
Old Jun 2, 2011 | 04:00 PM
  #1080
bbarnhill's Avatar
the smoothing was changed due to a problem with drop offs at the end of runs. It had to do with the way RPM and Time were smoothed prior to HP/TQ calculations were done. It has been a bug in there since the beginning. I would love to know what errors were popping up when you first installed it so may be I could correct it. Please make note of the error number and the error message.
