emission state inspection cal id
Old Dec 27, 2020 | 09:47 AM
  #166
Biggiesacks's Avatar
Originally Posted by razorlab
For the Evo 10, the first 8 digits of the CID is the ECU part #
Example from mine: 1860C0450001
Also, if you cross reference the ECU Part # and the full CID, you can get the factory CVN #:
I probably should have asked this a while back.... Where did you get this table from? I'm trying to find something similar for the earlier years.
Old Dec 27, 2020 | 12:45 PM
  #167
CDrinkH2O's Avatar
Came from EPA docs here : epa.gov
Pg.93
Old Dec 27, 2020 | 01:48 PM
  #168
Pg.96
Thanks! Looking through it they don't seem to have anything for the 2003-2004 as far as applications. 2005 shows an application, but it isn't found when you try clicking on it.
https://iaspub.epa.gov/otaqpub/displ...id=9510&flag=1
2006 seems to be the oldest model they actually have the "ECM" data on (Page 112)
https://iaspub.epa.gov/otaqpub/displ...id=4163&flag=1
Old Dec 27, 2020 | 01:56 PM
  #169
CDrinkH2O's Avatar
The one you want is here: 2005 Model Year Evo CALIDs Pg. 112
Old Dec 27, 2020 | 05:02 PM
  #170
Thanks again Your link is sending me to 2006 stuff but clearly the info is out there so I'll try and step up my searching. Any idea on the 03-04 stuff?
Old Dec 27, 2020 | 05:05 PM
  #171
kaj's Avatar
kaj
Isn't that because the 2006 is the only car that has an ecu that's shows all the info? I'm under the impression they are only flagging IXs right now.
Old Dec 27, 2020 | 05:20 PM
  #172
I think the info we have is that it was in 2005 that OEMs were required to start providing this information. I don't know if any 05's or older have been flagged for "ECU Tampering" yet though.
This should be the correct link for the 2005 Info pg. 123
https://iaspub.epa.gov/otaqpub/displ...id=4143&flag=1
Old Dec 30, 2020 | 05:46 AM
  #173
So I have failed to locate any EPA application docs for the 2003-2004 MY, does anyone know what the stock 94170015 rom CVN should be? I tried using the mitsubishi J2534 software to flash it onto a spare ECU but also failed with errors.
Old Jan 27, 2021 | 10:23 PM
  #174
Fsae_Alum's Avatar
Does anybody know if getting your ACD tuned changes the Cal ID or will get you flagged? I wouldn't think so but I don't want to assume incorrectly on this. Never can tell what the CARB ***** are looking into now days and they do stupid things like making it illegal to swap transmissions in Cali (6sp to 5sp or vice versa).
Old Jan 27, 2021 | 11:09 PM
  #175
kaj's Avatar
kaj
It's a separate ecu, so should be fine, but who knows, these days?
Old Jan 27, 2021 | 11:46 PM
  #176
Fox_IX's Avatar
No, it's completely separate from the ECU. Even if it wasn't, I don't believe it's even regulated by CARB.
Old May 29, 2021 | 01:28 PM
  #177
CDrinkH2O's Avatar
2005 USDM EVO 8
ROM: 96940011 (stock)
CALID: 1860A118AA
CVN1: 2822E4BF
CVN2: B73ED77C
CVN3: 099C6542
Confirmed passes California ARB smog test today 29 May 2021!
Old May 29, 2021 | 03:06 PM
  #178
kaj's Avatar
kaj
You guys with 8s are lucky.
Old May 30, 2021 | 01:55 PM
  #179
deylag's Avatar
2005 USDM EVO 8
CALID: 1860A118AA
CVN1: 2822E4BF
CVN2: B73ED77C
CVN3: 099C6542
Yea I am about to load in the stock 2005 rom too. I had to change the immobilizer code and hex to match my previous tuned rom. Based on the info here this should change the CAL ID but I think I can get it reflashed at the stealership through the recall.
Old May 30, 2021 | 01:56 PM
  #180
deylag's Avatar
Am I missing something? 2005 and 2006 ECUs log the VIN number so is there another difference between the years?
