emission state inspection cal id
I suspect you can even do this on the 9 using 88590015/6. @Kaj you should try it and get the 9er's out of trouble.
Changing the Immob code and hex don't affect CVN1 for 96940011. You can even run the recompile force pass settings without affecting the CVN1. Try them, try them and you may!
I know the roms are unmodified except for the immobilizer so I might just set the monitors and get it smogged to see what happens.
This one is the rom taken from the wiki.
2005 Evo 8 GSR stock rom
So after reading through all this thread, does anybody knows what year Evo's does this actually affect? Some say the 2005 9's but nothing for the 2003-4 because the ecu didn't collect enough data or something.
So all North American Evos.
CARB was just doing a "test phase" for this before. Come Monday, they are all in.
CARB go all in on modified ECUs
Somewhat on topic: Has anyone been able to get the mitsubishi flashing tools to work? I paid the 20 bucks to get access, but couldn't make it work with my openport 2.0. According to their site it should https://www.tactrix.com/index.php?op...2534&Itemid=41 . So if anyone has gotten it to work, could you share your setup?
lets see... from the numbers they provide... they expect to find 5-10 vehicles per day that have "modified" tunes.
so thats (high side)... 200 vehicles per month.
and they state they check 1 million per month.
so they expect to get a .02% failure rate for tune
what a bunch of morons... and waste of money.
MEET KEVIN FOR GOVERNOR
