After Tephra Map car don't start
Old Apr 9, 2021 | 09:50 AM
Lancer_Evo_8's Avatar
Hey Biggiesacks, when you say you think its just a XML.... its a good option to try with e other Tephra File?
Because i have 3 different XML. Acutally i tried with the 105 KB File
Old Apr 9, 2021 | 10:02 AM
Biggiesacks's Avatar
If you change the ROM ID of the tephra ROM to the stock ROM ID it will open in ECUFLASH with the stock XML. You can compare them that way if you like. Some things obviously won't be right, but only things that tephra has modded. So the immobilizer stuff etc. will be the comparable.
Old Apr 11, 2021 | 09:10 AM
Slowly it makes me crazy
I tried today to Flash with three different Tephra Files (all in the attachments). But the engine still don't start. Just crank
I also tried to disable the immobilizer in the FAA Periphery, still just engine crank.
I also tried to set the immobilizer to FFFF like they say in Merlins How To Do....., still just engine crank.
So there has to be something wrong in all three tephra Files? I think thats weird.....
Maybe somebody know tephra good enough to check it in the attachments....oder with team viewer? Or oder solution
File Type: xml
Old Apr 20, 2021 | 10:28 PM
Finally Problem solved
I was using the wrong tephra file
n2oiroc
AEM EMS
Apr 13, 2013 07:24 AM
clockworktoy
Dec 11, 2011 12:20 AM
StevenStarke
Jan 5, 2008 11:20 AM
Vostok 7
Sep 19, 2007 11:29 PM
Steve@NoLimitmotors
AEM EMS
Jul 15, 2007 10:10 PM
