MAP EF-series Turbochargers results thread
Old Oct 30, 2012 | 01:00 PM
  #976
Kracka's Avatar
Originally Posted by cursedsm
We are talking reg people not Curt Brown's #s hahaha. I do believe Chris said that there was an ef2 that made over 500 as well.
No matter how you cut it, those numbers are not realistic for the vast majority of owners, there's more efficient turbos for goals of 500+ designed to do just that.
Old Oct 30, 2012 | 01:38 PM
  #977
ChrisCarey's Avatar
The EF2 is not larger than the 71HTA Green, in fact if I am to believe that "71" is the exducer measurement then the EF2 comp wheel is 2mm smaller. On E85 the EF2 is capable of 500whp with the right combination of parts, but that is at its limits. I comfortably ran my Evo X EF2 at 470whp Dynojet on a daily basis for quite some time.
Old Oct 30, 2012 | 01:49 PM
  #978
mean4g63's Avatar
498 WHP is the highest EF2 and that was on an Evo X. the EF2 seems closer to the BBK Full. when comparing turbos with upgraded turbine wheels....
Old Oct 30, 2012 | 01:51 PM
  #979
mean4g63's Avatar
the Green is 73 exducer...so are you saying the EF2 has a 71MM or a 69MM exducer?
Old Oct 30, 2012 | 02:48 PM
  #980
mrfred's Avatar
Curt Brown did 600 whp on a DJ, but nevertheless, I got a bit carried away in the whp numbers. I can find five Evos with HTA Greens that have done 520-530 whp - Lucas English, Liqquid, MRevo916, drb, and jwdp54. Yes, its kill mode or close to it, but that's what everyone shows unless they are worried about exploding stock internals. Anyhow, this is an EF thread...
Old Oct 30, 2012 | 06:46 PM
  #981
CurseDSM's Avatar
Agreed I just have to bust your ***** once and a while I knew the ef2 would do 500 but don't know much about them being I do not run one.
Old Nov 25, 2012 | 10:14 AM
  #982
Ludo's Avatar
Hi Chris,
Ludo GL Racing in France:
Evo VIII GSR 260
Engine stock
Map Turbo EF2
Kelford cams 264°
Exhaust full 3"
K&N intake
Grimmspeed 3 port
OEM Evo MR Blow Off
ETS Intercooler 3.5"
Map GL Racing full E85 23psi for finish 20psi
Old Nov 26, 2012 | 06:37 AM
  #983
Craig King's Avatar
What intake are guys running with the 3" anti-surge housing on the EF3s and still running the MAF?
Old Nov 26, 2012 | 06:47 AM
  #984
SlavaGC8's Avatar
Agh cant wait to run my ef2. I got another ef2 for my rsti as well, map had a good deal on those this weekend.
Old Nov 26, 2012 | 06:53 AM
  #985
Kidloco51's Avatar
I run a JMF 3" intake w/maf and perrin filter. I believe you have to run a 3.25" to 3" coupler on the anti-surge housing (I think the housing is a tad bigger than 3")
Old Nov 26, 2012 | 07:07 AM
  #986
Craig King's Avatar
Cool, thanks for the feedback.
I'm curious about the turbo inlet size - the MAP website says it is a 3" anti-surge inlet. If it was a true 3" OD, then the JMF intake should work without a 3.25" coupler. However, if the anti-surge housing is 3.25", then you could run the FP 84mm intake and not need the 3.25" coupler.
Old Nov 26, 2012 | 07:15 AM
  #987
Kidloco51's Avatar
I am almost 100% positive it is a tad bigger than 3". Maybe Chris from MAP can chime in.
Old Nov 26, 2012 | 07:48 AM
  #988
ChrisCarey's Avatar
To the best of my knowledge a 3" coupler will work for the compressor inlet.
Old Nov 26, 2012 | 08:23 AM
  #989
CurseDSM's Avatar
I use a 4 inch intake that goes down to 3 inch
Old Nov 26, 2012 | 08:45 AM
  #990
Craig King's Avatar
Is there a particular intake you recommend for the 3" anti-surge housing? Will the FP 84mm intake work with the 3" anti-surge cover on the EF3?
Ordered my EF3 today.
