MAP EF-series Turbochargers results thread
Old May 5, 2013 | 07:02 PM
  #1306
evotuner04's Avatar
15 Year MemberLikedLoved
Ive made 475whp at 26psi (e85) on my old ef3 stock block. I'd imagine with some more boost and timing it would've easily seen 520whp. Considering my ef2.5 is making 500 on a dynojet
Old May 6, 2013 | 01:37 PM
  #1307
Ramonski's Avatar
I would love to see 500 on a dynojet. I cant wait to get my 2.5 and see what I can do on e85.
Old May 15, 2013 | 02:28 PM
  #1308
jimbo210's Avatar
Currently waiting for my IX to get out of the shop. Waiting is the hardest thing to do lol Below will be my mod list..
MAP Ef3 (ported)
S2 cams
Speed density
Ets turbo manifold (1.5”)
MAP o2 dump
ETS 3in fmic
Fic 850s
3in tbe cat delete
Gs 3port ebc
Dw 255 pump
Stock block, peak boost around 27 falling to 25 I believe. Im looking for 440whp+ on dynojet. 93 octane. Ill post graphs soon hopefully.
Old May 15, 2013 | 03:33 PM
  #1309
Ramonski's Avatar
James, cant wait for both of our cars to be done so we can compare my 2.5 with your ef3 should be fun
Old Jun 1, 2013 | 10:32 AM
  #1310
Craig King's Avatar
MAP Ef3 (ported)
S2 cams
Speed density
MAP o2 dump
ETS 3in fmic
Fic 850s
3in tbe cat delete
Gs 3port ebc
Dw 255 pump
Those 850s are going to be what holds you back. I think 1050's are the injector of choice on 93 for the EF3. That's what I'm running.
Old Jun 1, 2013 | 10:51 AM
  #1311
Ramonski's Avatar
Yeah I forgot that he was running smaller injectors. I dont think he was planning on upgrading from a smaller turbo for a while but then went all out lol
Old Jun 1, 2013 | 11:22 AM
  #1312
CurseDSM's Avatar
850s should be ok for pump gas. I agree with you though they will be a little on the small size but should make you some decent power.
Old Jun 1, 2013 | 12:10 PM
  #1313
Ramonski's Avatar
I had a tuner say that my 1000's and a walbro wouldn't make much more power on e85 than 93. Is that true?
Old Jun 2, 2013 | 05:11 AM
  #1314
Craig King's Avatar
Big power on E85 starts when you start running 1450, 1650, 2150cc injectors. With those larger injectors, you will make more power on E85.
EDIT: In other news, I made my appointment to have STM retune my car in a couple weeks after I install my EF3.
Old Jun 2, 2013 | 06:58 AM
  #1315
jimbo210's Avatar
What are your other mods? My setup is very similar to the first post in this thread. Except for s2's and speed density. Peak boost will be 26psi.
Old Jun 2, 2013 | 07:20 PM
  #1316
Craig King's Avatar
2003 Stock block
CBRD FMIC
CBRD Upper IC kit
AMS-clone Lower IC pipe
Walboro 255
MAPerformance EF3 w/3" anti-surge compressor
MAPerformance 3" MAF intake
MAPerformance 02 dump housing
Buschur Ported & Coated Manifold
Hallman MBC
FIC 1050cc's
Full 3" Turbo-back
Kelford 272s
Hoping for something around 400hp on STM's dyno in 2 weeks.
Old Jun 5, 2013 | 08:23 PM
  #1317
Jeff_Jeske's Avatar
This thread needs an EF2 update so ...... here you go.
Today I had a chance to throw the car on RS Motors mustang dyno. We ran a baseline with my back road tune and then Ron did some tweaking.
My VD numbers were 429whp and that pull and be viewed in the bottom of this post. Today that tune was the equivalent of 375whp on the RS Motors stingy mustang dyno.
Anyway after some adjustments today's mustang dyno pull also resulted in 429WHP but that is a 55whp gain over the previous tune. Other than a bump of midrange timing the only modification that was performed was the crushing of my stock EVO9 metal DV and that made all the difference in the world. So much in fact that the original pull was made with the duty cycle set maxed at 100 and the last pull works its way up from peak torque at 80 thru 90.
I haven't had the chance to perform another VD pull but I'm expecting to see numbers that align better with the marketing material LOL!
Keep in mind my evo has stock cams, stock O2 and stock intake pipe with MAF.
Old Jun 5, 2013 | 09:46 PM
  #1318
batty200's Avatar
Very nice gains. Did you notice any increase in compressor surge due to crushed bov?
Old Jun 5, 2013 | 10:23 PM
  #1319
tscompusa's Avatar
your old VD with smoothing 2 is inflated.
send me that log and i will show you what it really made if you'd like. im gonna guess about 400whp in my vd.
sending you a pm.
Old Jun 6, 2013 | 03:53 AM
  #1320
jimbo210's Avatar
Mods?
