MAP EF-series Turbochargers results thread
Old Jun 18, 2013 | 02:20 PM
  #1351
Craig King's Avatar
Originally Posted by bitterchild
you gained 70 whp peak over a 9.8 evo8 turbo from an EF3? There's gotta be more to that story, even on STM's heartbreaker mustang.
I will make an official thread later tonight with my dyno graph, but yes, almost a 70hp gain at the wheels with an EF3.
I mentioned this a few posts back, but you probably missed my whole EF3 build list. It wasn't just an EF3 I upgraded to from the stock Evo 8 setup.
In a nutshell, I installed:
EF3 w/anti-surge housing ..... previously Evo 8 turbo
Buschur Ported & Coated manifold ....... previously stock manifold
MAPerformance 02 dump housing ........ previously stock 02 housing
FIC 1050 injectors ....... previously stock 550s
Removed EGR system
GReddy diverter valve .... previously a stock Evo 9 valve
Running almost 30psi, up from 24psi I was making on the stock setup.
So, it was a big upgrade. I went from 330hp/299tq to 396hp/343tq on the STM dyno. Roughly 70hp and 40tq.
EDIT> And yes, this was on 93octane.
Old Jun 18, 2013 | 03:41 PM
  #1352
Raptord's Avatar
I think bitterchild was implying that seems like a low gain, not a high one.
Old Jun 18, 2013 | 04:05 PM
  #1353
Ramonski's Avatar
this....
Old Jun 18, 2013 | 04:53 PM
  #1354
DisgustipatedM3's Avatar
Removed EGR system
That's a pretty low gain, tbh. Should be more like a 100-130 whp gain. On my Evo 8 stock 10.5 turbo to the EF2.5 I went from 370 whp to 450 whp, and it's still not the max that I'm going for on this turbo/fuel setup. Maybe it's because it's such a low reading dyno...?
Old Jun 18, 2013 | 05:40 PM
  #1355
ILuvJDM's Avatar
I did a ton of stuff at once, basically went from stock with a tune to almost full bolt on and got about 120whp with the EF3
Old Jun 19, 2013 | 01:02 AM
  #1356
Originally Posted by mean4g63
Ef2.5 results so far.... 1 spools 25 psi @4000, 1 spools at 4100, and another at 4400. The avg non-ported shroud EF3 seems to spool around 4300 ish give or take. So I think its safe to say it's "about" 200 RPM faster. I stand by what I said before. If you are still on the "spool like an EF2 & FP Green" hype train still you are sadly mistaken.
Ready to eat crow? Here, have a plateful.
Here's tonight's run with 3 half-turns of preload vs the previous dyno I posted up with zero preload.
Attachment 333919
It made 8-9 psi more at 3900 RPM (19 psi at 3900 RPM with zero preload, 28 psi at 3900 RPM with 3 half turns)
So who still thinks the EF2.5 spools lazily? Look at that difference in torque/spool...
Zero preload @ 4078 RPM = 266 wtq
3 half turns of preload @ 4078 RPM = 326 wtq
I will test 4-6 half turns of preload and see if I can get it to spool even faster (within safety margins, of course.) But these results are even better than I expected considering 3 half turns is very light preload!
Old Jun 19, 2013 | 01:28 AM
  #1357
Here is my EF2.5 as of right now vs. my Evo 8 10.5 stock turbo via Virtual Dyno, done on the same road, same time of night:
Attachment 333918
Old Jun 19, 2013 | 07:35 AM
  #1358
Jeff_Jeske's Avatar
That is much improved! Looks like it spools faster than my EF2.
Old Jun 19, 2013 | 09:26 AM
  #1359
Your EF2 needs more preload and your MIVEC needs to be adjusted. An EF2 on an Evo 9 should spool about the same as the stock turbo. You should be outspooling me by 500-600 RPM.
Old Jun 19, 2013 | 12:12 PM
  #1360
Craig King's Avatar
You guys must not be familiar with STM's Mustang Dyno.
Remember, this was a real dyno. Not simulated dynojet numbers. I'm also not trying to squeeze every last horsepower out of this setup - it was a fairly conservative tune.
Old Jun 19, 2013 | 01:08 PM
  #1361
You realize a mechanical dyno is just a rolling simulated calculation too, correct? And that it doesn't simulate the load/aero/airflow realistically like a road/virtual dyno does?
Virtual Dyno has been proven to be within 1-3% of mechanical dynos when calibrated correctly. Mine is calibrated correctly on the same perfectly flat, smoothly paved, neutral grade road.
If anything, you should be throwing up Virtual Dyno numbers too so that you can get your own results with real airflow and load that the car encounters.
That being said, if you're 396 whp on STM's dyno, I am going to estimate you are at 450 whp on an average dynojet, which is very impressive for 93 octane! And also in line with what I'd expect from doing a big upgrade like EF3, intake manifold, etc. So on second thought, your numbers aren't that low at all.
Old Jun 20, 2013 | 05:19 PM
  #1362
ILuvJDM's Avatar
well the point of my post was that your numbers seem reasonable... not low. I was trying to add more data to the assumptions
I made 120whp more with tons of stuff done at once. Basically every part between the exhaust ports and the intake ports on the head was changed at once...
Old Jun 23, 2013 | 03:45 PM
  #1363
Craig King's Avatar
Does anyone know what size the compressor wheel is on an EF3 turbo?
Old Jun 24, 2013 | 06:27 AM
  #1364
jimbo210's Avatar
76mm
Old Jun 24, 2013 | 07:19 AM
  #1365
ChrisCarey's Avatar
55.5mm inducer and 76mm exducer
