MAP EF-series Turbochargers results thread
So far so good tho. Very happy with the ef3 so far
Can someone help me out? Please don't flame me. I picked up an EF3. Is the turbo fed oil from the head? My tuner has no history with this turbo and I got it used and have no clue. Thanks in advance
I got it used...so no accessories, hence you can see my dilemma. I have no clue about install so I can really help him out. So I thought I'd ask. And it's for an Evo 8.
Gaahhhhh! If you have an Evo IX you can run the factory line from the head. If you have an 8 you need the install kit (goes from oil filter housing or you buy the the install kit with the revised Evo IX oil feed line)
Pick one
http://www.maperformance.com/map-tur...i-evo-8-9.html
http://www.maperformance.com/maperfo...o8ins-kit.html
Also please tell me your using a tuner who has tuned Evos before? The fact he doesnt know anything about MAPs turbos is not inspiring.
Pick one
So I took my car to the track this weekend and ran 3 passes. Car was originally tuned in Kansas and has not been retuned in Texas, but here was the VD sheet from when it was originally tuned. It probably makes a bit less power now because it was pretty cold during the tuning (34*F)
1st run 1.86 60-ft, 12.34 @ 120.5mph
2nd run 1.58 60-ft, 12.16 @ 112mph (got knock at top of 4th and let off the gas)
3rd run 1.84 60-ft, 12.43 @ 119.4mph
I really wish the 2nd run would have been clean, but I had to lift when my CEL flashed. I nailed the launch and hit every gear change just right.... I was really hoping for an 11sec run, but regardless I would have been kicked out because at SAR you need a 6-point cage for 11.99 and faster. The other 2 runs I kind of bogged the launch, but it's still much better than when I went on my 18" wheels and couldn't do better than a 13.1 because I was spinning... This was on stock BBS 17" wheels with BF goodridge tires I think, basically just normal street tires at 25psi
390/357 at 7125/4859rpm
'06 MR
91oct
Injen IC piping/air intake/LICP
BR air filter (the older one)
AMS FMIC
MAP 2.5
FIC 1050s
3" BR TBE/no cat/3" Cherry Bomb muffler in place of cat
Greddy easycam (264)
Grimmspeed MBC
'06 MR
91oct
AMS FMIC
MAP 2.5
FIC 1050s
Grimmspeed MBC
i don't understand how you didn't easily run an 11.XX.
I had another guy that made about 460whp and trapped 126. everyones different, but a 120 trap should have gotten you a 11 with a good pass.
That 12.16 @ 112mph would have been an easy 11 sec pass if you hadn't gotten out of it.
whatever you did to get your 60ft that good do it again next time out
