MAP EF-series Turbochargers results thread
Old Jun 24, 2013 | 07:24 AM
  #1366
Craig King's Avatar
Cool, thanks jimbo & Chris. I probably should've just opened my EF3 up before I installed it, but this was easier.
On a side note, I've had my EF3 on my car for a week now - I'm loving every mile of it.
Old Jun 27, 2013 | 12:08 AM
  #1367
Canexican's Avatar
MAP EF4 with a CB 2.3 10.5:1 motor FTW!
Been a long time coming, but these are just the beginning numbers.
Heres the specs:
Curt Brown Spec 2.3ltr motor 10.5:1
Curt Brown built head, Kelford 280 cams
MAP EF4
C16
Single Walbro 255lph, 1450cc inj., Stock fuel rail LOL
31 PSI in 3rd gear
Tuned by Jay@TPG Tuning
VERY low reading Mustang Dyno
There was a pull after this netting 612whp SAE Corrected. This is more than 650 on a Dynojet.
Will be running this in a 2500-2600ish lb car with slicks tomorrow. Keep you guys posted.
Old Jul 7, 2013 | 02:13 PM
  #1368
evotuner04's Avatar
15 Year MemberLikedLoved
How are you only running a single walbro 255?
Old Jul 7, 2013 | 04:59 PM
  #1369
Boosted Tuning's Avatar
Because its C16 and not E85. A single wally with race gas can support 600-700hp.
Old Jul 7, 2013 | 05:12 PM
  #1370
mrfred's Avatar
Heres the specs:
MAP EF4
C16
31 PSI in 3rd gear
I think I may have asked you this before, but are you still on the 6-speed? I highly doubt it, but figure I should ask.
Old Jul 8, 2013 | 05:55 AM
  #1371
evo8426's Avatar
Heres the specs:
MAP EF4
C16
31 PSI in 3rd gear
What weight was used on the dyno, 2600 or the typical 3600 most use on dyno days?
Old Jul 8, 2013 | 09:06 PM
  #1372
Canexican's Avatar
Yep. Will eventually go to E85/E98, but still have to do a complete fuel overhaul.
HELL NO. That junk melted down at 60k miles. Been on a Shep 5spd with stock final drive for over 30k miles now.
That's a good question. I'm really not sure. All I know is it reads lower than pretty much everyone else.
*Update: Went to Import Faceoff and got a whole 3 passes in before weather ended my day. Conditions were typically terrible for Pittsburgh this time of year: 90 degrees with 90% humidity. Track elevation 1300ft. I bogged off the line all three times and couldn't do any better than a 1.8 60ft. Best pass was an embarrassing 11.30@134 with granny shifting and I hit fuel cut before the traps - probably would have trapped 137.
Car rips and I'm still confident it will do solid 9s with a 1.4-1.5 60ft. I just need to knock the rust off as it was my first pass on this setup and first time driving the car in a year and a half. To be continued...
Old Jul 10, 2013 | 11:35 PM
  #1373
rs03evo's Avatar
What size is the compressor intake on the EF4??
Old Jul 11, 2013 | 11:47 PM
  #1374
Canexican's Avatar
Well, it went faster!
https://www.evolutionm.net/forums/dr...4-144-7-a.html
Old Jul 12, 2013 | 01:00 AM
  #1375
tscompusa's Avatar
that mph is dead on with hp on a mustang vs your cars weight. now you just have to learn the ef4 like you did the stock turbo to get your 9 second pass. nice job so far though. 144 is really moving on a stock frame turbo off the shelf 9 second pass is in your near future it looks like.
Old Jul 12, 2013 | 02:44 AM
  #1376
Evoloved's Avatar
Excellent job Sir, that track must have been hooking the truck ran as quick as it could per his mph awesome runs
Old Jul 12, 2013 | 08:05 AM
  #1377
ChrisCarey's Avatar
Looks like this needs to be updated!
https://www.evolutionm.net/forums/dr...os-2013-a.html
Old Jul 12, 2013 | 05:29 PM
  #1378
ILuvJDM's Avatar
well I finally signed a lease on a house which means I can actually start driving my car again instead of having it just sit in a storage unit. I need to eventually get to a track to get some times with my EF3, but I'll wait until the weather cools off. Not much fun going down the track at 100*F
good to see some numbers from other people
Old Jul 12, 2013 | 09:09 PM
  #1379
Canexican's Avatar
Well, on the 10.2 pass, I cut a 1.71 60ft due to over inflation of the tires and spinning/lifting out of the hole. We dropped the psi down to 18 and on the next pass I cut a 1.47 60ft...slammed second like a boss, .2 seconds faster at the 330 mark...then 3rd decided that I was going too fast for it's liking and said NO.
So, that was the single digit pass right there. I think my 3rd gear is messed up. Won't go into gear at high rpm. Ordering underhood and base shifter bushings to see if it will alleviate the problem, but I don't have high hopes. Clio tells me I have a second tranny build in my future.
Going to also try short shifting 3rd next time. Was VERY frustrated and settling with the 10.2 was bittersweet knowing that the 9 second pass was only two shifts away. I'll figure out how to squeek a 9 second pass in there one way or another...it's definitely got the cojones to do it!
Old Jul 19, 2013 | 05:56 PM
  #1380
Canexican's Avatar
Well, it went a little faster. Still won't be satisfied until I get that 9 second pass, but we're getting there. Looks like I'm going to need a refreshed tranny after all . https://www.evolutionm.net/forums/dr...n-quicker.html
