MAP EF-series Turbochargers results thread
Old Mar 3, 2014 | 08:31 AM
  #1426
ChrisCarey's Avatar
Originally Posted by GreenAWD
Any chance of a ball bearing version on these ever coming out?!?!
It has been discussed and some testing has taken place, but we're still a ways off from a release of any sort. We will not be releasing anything until it has been tested and proven.
Old Mar 4, 2014 | 09:34 AM
  #1427
ILuvJDM's Avatar
Originally Posted by tscompusa
120 trap is about 420whp dynojet. so you were either losing mph due to driving or just the car is making alittle less power now maybe vs when the graph was built.
I had another guy that made about 460whp and trapped 126. everyones different, but a 120 trap should have gotten you a 11 with a good pass.
That 12.16 @ 112mph would have been an easy 11 sec pass if you hadn't gotten out of it.
whatever you did to get your 60ft that good do it again next time out
Yep I agree. I need to contact you for a retune now that I'm in texas and not Kansas. I do think 11s are in reach without cams
I've been wondering when the best time to tune the car is, in reference to the outside temperature? Is it an issue having the car tuned in 40℉ weather when the temps in texas get to 110℉ in the summer?
Old Apr 18, 2014 | 07:03 PM
  #1428
rs03evo's Avatar
planning to get base tune done tomorrow on a unknown set of cams so i can finish up my break-in.. My R2 Cams, springs, retainers and AEM cam gears should be going in soon for some final numbers...
Old Apr 21, 2014 | 08:14 AM
  #1429
ChrisCarey's Avatar
Looking forward to it
Old Apr 29, 2014 | 02:02 AM
  #1430
rs03evo's Avatar
new update... A local tuner told me he wouldn't tune me because i had a walbro 400; luckily for me, i have a buddy who has no issues with tuning a Walbro 400... should be putting in the R2 cams in Friday possible Saturday and from there getting tuned shortly after....Can't Wait!
Old Apr 29, 2014 | 06:10 AM
  #1431
Raptord's Avatar
Did he give a reason?
Old Apr 29, 2014 | 11:26 AM
  #1432
rs03evo's Avatar
he basically said they have idle issues and he prefers double pumpers.. I've talk to many other tuners and they said there is no real issue just inexperienced..
Old Apr 29, 2014 | 12:02 PM
  #1433
murlo26's Avatar
The only issue at idle with a 450 is maybe that the base fuel pressure is high. Nothing a person can't tune around.
A single pump is always better than a double pumper, less points of failure.
Old May 3, 2014 | 03:07 PM
  #1434
rs03evo's Avatar
R2s are in... working out some small issues and I'll be getting ready for a 91 tune for now...
Just a taste..
Old May 10, 2014 | 08:45 PM
  #1435
rs03evo's Avatar
should have results on 91 oct. by monday!
Old May 12, 2014 | 08:12 PM
  #1436
Uscbryan's Avatar
Hey guys,
I think I will be ordering the EF3 and AMS downpipe by the end of the week. I do have a question though since I am fairly new to upgrading turbos. I read that the AS cover is not needed with the proper BOV. I'm assuming I should upgrade my BOV from stock and if so what do you guys recommend?
I am currently at 397 HP/371 on a dynapack
Pretty much all the basic bolt ons including E and 1200cc injectors
ETS Intake, upper and lower IC piping
AMS IC
RRE 3 port
UR exhaust and test pipe
I forget the fuel pump. It's the one RRE gives as part of the E85 upgrade
I am hoping to get around 450 to 470HP while keeping the Torque under 400.
Thanks
Old May 13, 2014 | 08:52 AM
  #1437
evoforstevo's Avatar
Originally Posted by Uscbryan
Hey guys,
Thanks
With those power goals, you should pm evotuner on here about picking up his EF2.5 He made great numbers (over 500 on a built motor) and i love my ef2.5. His is really low miles and a great price.
EF3 might be over kill for you.
https://www.evolutionm.net/forums/sa...ac-sensor.html
Old May 13, 2014 | 09:53 AM
  #1438
Uscbryan's Avatar
Well my short term goal is as much HP as possable out of the stock block while keeping it somewhat safe.
Long term is rebuild and around 600hp.
Thanks
Old May 13, 2014 | 11:50 AM
  #1439
kaj's Avatar
kaj
Hey guys....I read that the AS cover is not needed with the proper BOV. I'm assuming I should upgrade my BOV from stock and if so what do you guys recommend?
I'm a firm believer in only upgrading when you need to. I run 25-27psi with my stock BOV. I did crush it a bit, however.
What is "AS"?
Old May 13, 2014 | 01:58 PM
  #1440
Uscbryan's Avatar
Thanks. I ended up ordering the EF3 and AMS DP today and they told me I don't need a BOV at this point.
Sorry AS = Anti Surge
What is "AS"?
