MAP EF-series Turbochargers results thread
Old May 8, 2012 | 12:03 PM
  #676
Kracka's Avatar
Originally Posted by j255c
Not trying to knock this turbo at all because it was what i was considering for my car. But dont these numbers seem somewhat low for 31psi on an EF3 consider stock IX turbos on e85 at 30 psi make around 410whp on e85?
There is a huge difference in graphs other than looking at just peak numbers; frankly, the peak value means very little, what you're looking for is overall area under the curve. You also need to keep in mind he tracks the car, any intelligent owner and/or tuner will tune a track car much more conservatively than a street car since it will see extended WOT/boost conditions.
Old May 8, 2012 | 01:23 PM
  #677
wanguru's Avatar
Old May 9, 2012 | 03:14 AM
  #678
jdm-vr4's Avatar
Got my EF2 Delivered today and camt wait to put it in and start tuning the car.
My car is currently getting head work so once its finished it'll be results time.
Mods on the car
8mr Jspec, EF2, GSC S2, Ported head with 1mm valves, Cam gears, TBE+test pipe, 3port, Intake, Intercooler + piping, FIC1050, E-Flex fuel @approx 75%, Stock bottom end.
Old May 9, 2012 | 05:18 AM
  #679
seanr8368's Avatar
I'd like to post mine, but due to boost creep and still trying to fix the problem, trying new ts wastegate tomorrow , which hopefully will fix problem.
Old May 9, 2012 | 07:28 AM
  #680
wanguru's Avatar
Keep us posted please. Anyone else using the new TurboSmart actuators? Heard they are on back order...
Old May 9, 2012 | 07:40 AM
  #681
ChrisCarey's Avatar
Turbosmart's individually packed actuators aren't readily available, but the ones for use in our turbo program are ready to rock
Old May 9, 2012 | 09:10 AM
  #682
TommiM's Avatar
That EF3 looks awesome. I just ordered a clutch and flywheel from you (MAP) and after reading this thread I think I have decided to get an EF3 ordered up here soon. I want one.
Old May 9, 2012 | 09:16 AM
  #683
ChrisCarey's Avatar
Sounds good to me, thank you for your business!
Old May 9, 2012 | 10:44 AM
  #684
TommiM's Avatar
Order placed, cant wait to see it! Next up is your stage 1 2.3 shortblock. I have my core in a pallet waiting to get sent.
Old May 9, 2012 | 05:31 PM
  #685
Charlie87's Avatar
Im hoping to have my EF3 and built motor tuned soon! Wont be expecting massive numbers as the car will be tuned for circuit racing. It needs to last 6-7 15 minute sessions flat out day in, day out so we shall see what this is capable of hehe
Mods are as follows:
MAP EF3 (ported comp housing, ported exhaust housing, anti surge)
MAP Howards I beam rods
MAP H11 headstuds
Wiseco 10.0CR 1400HD pistons
GSC S2 cams
Stage 1 ported head with Brian Crower 1mm oversized valves
E85
(standard 6 speed gearbox boo!)
Motor, gearbox and t case will be going in this weekend and then off to tuning asap
Old May 10, 2012 | 05:01 AM
  #686
Levar's Avatar
Veteran: Army
MAP H11 headstuds
GSC S2 cams
E85
This looks very promising, my friend.
Old May 10, 2012 | 05:06 AM
  #687
Levar's Avatar
Veteran: Army
Megatron has finally arrived home. The trip home was pretty pleasant and I could only think about all of the hard work that has gone into my build. There are still some tweaks of the tune that need to be made. I will say that even on pump/91, the EF4 is pretty quick with the 2.4LR.
https://www.evolutionm.net/forums/al...r-map-ef4.html
Old May 10, 2012 | 05:29 AM
  #688
TommiM's Avatar
Is this the actuator that comes with the EF3, and will mine come with the turbosmart actuator or did I need to specify?
Old May 10, 2012 | 05:56 AM
  #689
Levar's Avatar
Veteran: Army
No, my friend. There is no need to specify as they come standard.
Old May 10, 2012 | 06:43 AM
  #690
getsideways's Avatar
All these pictures YAY!
