TSComptuned 700WHP+ FP Black dynojet #'s inside
I can have him make some, but no not that im aware of.
If you follow the setup / parts and the parts work together well it will go over 700. i have several 700~ fp black setups running around. The blueprint is quite easy to achieve 700 on the fp black these days.
isah sleepers car trapping 137.94 on regular street tires in hot temps is another one that can go over 700 fairly easy with boost. it was never ran in full kill mode before down the track. Its a shame it wont get to see what its really capable of with slicks and more boost since hes swapping to the 6466 very soon.
The parts on this build are extremely optimized. These are "elite boltons" to support this type of power. Then you have the e85 and the 2.3 for building boost and trq. One hell of a setup.
The boost control is whats making this setup be able to do what it did.
No port work on the head or anything! Also swapping the cams to S3 would give even higher gains. I think as this car sat, if you add S3 you will be looking at 750whp+ out of the twinscroll housing. Add stainless single scroll and maybe 780-800.
The dyno room was AC'ed also to 70F+, and zero humidity. That all helps.
SLVRNBLK's after we tuned it was around this cars power also.
I hate to respond so late and bump an old thread, but I wanted to respond to your post.
Can you overlay a bone stock Evo 9 onto the graph below?
ECU: Stock ECU + tephra v7 / sd / 4bar / ecuboost
Fuel: 85% ethanol
All Mechanical Work performed by AWD Motorsports.
Mods:
BR 2.3L
BR Double pumper
BR Mini Battery kit
BR 65mm throttle body
BR Ported Intake manifold
BR 3" TBE w/ three Magnaflows (lol)
FP Black Journal Bearing
GSC S2 cams
Toxic Fab exhaust manifold
MAP 3" recirc dump
Tial Q bov
FIC 2150cc inj
Spoolin Up COP
TSComp 4" intake pipe / filter
ETS 3.8" Garrett core FMIC
ETS 2.5" Upper & Lower Piping
All Pulls in 3rd gear:
Can you overlay onto the first graph on page 1?....CF: Standard Smoothing: 3
Fuel: 85% ethanol
Mods:
BR 2.3L
BR Double pumper
BR Mini Battery kit
GSC S2 cams
MAP 3" recirc dump
Tial Q bov
FIC 2150cc inj
Spoolin Up COP
Fuel: 85% ethanol
Mods:
BR 2.3L
BR Double pumper
BR Mini Battery kit
GSC S2 cams
MAP 3" recirc dump
Tial Q bov
FIC 2150cc inj
Spoolin Up COP
Fuel: 85% ethanol
Mods:
BR 2.3L
BR Double pumper
BR Mini Battery kit
GSC S2 cams
MAP 3" recirc dump
Tial Q bov
FIC 2150cc inj
Spoolin Up COP
tscompusa
Feb 17, 2017 11:45 AM
tscompusa
Jul 29, 2016 06:15 PM
tscompusa
Feb 27, 2015 05:45 PM
