Why you need to do an EGR delete
Old Mar 9, 2015 | 05:14 PM
  #76
sssr20det510's Avatar
Just did this now my factory boost gauge does not work. Now to figure out what line was the gauge line.
Old Mar 10, 2015 | 12:28 AM
  #77
kaj's Avatar
kaj
Move the reference line for the boost gauge.
Old Mar 17, 2015 | 09:29 AM
  #78
pshooter's Avatar
So in blocking off the EGR (I plugged the head) What do I need to do with the solenoid? Can I remove it completely or does it need to stay plugged in? Does it sense Vacuum / pressure?
Just want to know what to do with the hardware while the engines out.
Old Mar 17, 2015 | 09:49 AM
  #79
firmk20's Avatar
$25 dollars for 25 whp craziest thing I've ever heard off! would take that anyday of the week!
Old Mar 17, 2015 | 10:40 AM
  #80
Mecheng1993's Avatar
Probably won't net every car 25WHP. This may have been an extreme example.
Old Mar 17, 2015 | 10:44 AM
  #81
evo8426's Avatar
Pull it and put it in a spare parts box in case you need it for emissions.
Old Mar 18, 2015 | 07:58 AM
  #82
kaj's Avatar
kaj
i'm leaving mine. i live in CA and have to pass visual inspection. it doesn't bother me to have it on the car.
i agree with the post above: that number sounds pretty high. so many variables. i did it to keep temps in the IM down, keep things cleaner, etc. i can't imagine the extra heat does any good for any of the sensors on the IM.
i plugged mine at the port in the head with the NPT fitting. we'll see how it goes.
Old May 13, 2015 | 12:22 PM
  #83
JCevo805's Avatar
no retune ?why not delete then 👌
Old May 14, 2015 | 10:27 AM
  #84
JohnBradley's Avatar
Not all cars are going to have an EGR that leaked as bad as this one. Some may not see big gains, some will. The fact that 1400-1500* air is making its way into the intake manifold thru a leaking EGR, the exhaust is diluting the fresh air, and contaminating the charge, would lead me to believe EVERY car will see a gain.
If its leaking
Also it seems that all of the ones above 85-90k miles that have come in leak to some degree.
Old Jul 19, 2015 | 02:22 PM
  #85
Erik@MIL.SPEC's Avatar
So, has anyone tapped the EGR hole in the exhaust port for cylinder #4?
Was thinking that I could have my head guy use some aluminum to fill it up (much like a combustion chamber repair). Thoughts?
Old Jul 19, 2015 | 07:58 PM
  #86
LetsGetThisDone's Avatar
You can tap it and plug it with a pipe plug. I'm sure just welding it up would work fine too..
Old Jul 19, 2015 | 08:30 PM
  #87
Lightsaber's Avatar
Can I speculate that a similar gain can happen to an Evo X with a leaky EGR? I also need to figure out a way to keep the OBDII free of codes if block the EGR.
Old Jul 19, 2015 | 08:36 PM
  #88
Lightsaber's Avatar
Answering my own question, the Evo X does not have an EGR actually, because it has the exhaust valve MIVEC system to compensate for it, which is different from the IX. Link: http://www.evoxforums.com/forums/showthread.php?t=75234
Old Jul 20, 2015 | 08:07 AM
  #89
JoshMS6's Avatar
So I've seen a couple people say you don't need a tune and a couple say you do. If I have a completely stock Evo IX no tune or anything will I still be ok to take off the sensor and put the plate on the IM no problems? New to the platform and still learning before I start modding hardcore. Thanks guys!
Old Jul 21, 2015 | 08:59 AM
  #90
It will need a tune, otherwise you will get a CEL for the EGR delete.
