FP Zero/Zephyr Dyno Results Thread
Old Oct 26, 2015 | 05:37 PM
  #271
jacked cobra's Avatar
Any update
Old Nov 13, 2015 | 09:44 PM
  #272
Yella8's Avatar
Nothing? ?
Old Nov 20, 2015 | 11:28 AM
  #273
Sikilla's Avatar
Upgrading to a Zero from a JB Black, going to max it out and see no issue with making over 800.
Made 690 on the black
Made 755hp 560tq on the Zero on 44psi- Dynojet
Motor is 10.5.1 2.0
Gsc S3 cams
Stock port head/intake man/ TB
Stock port Fp race mani
E85 of course
Haltech Elite- Crispeed tuned AG Autosports
Old Jan 4, 2016 | 10:15 AM
  #274
Sikilla's Avatar
bump for results
Old Jan 4, 2016 | 04:36 PM
  #275
lostsoulsevo's Avatar
Motor is 10.5.1 2.0
Gsc S3 cams
E85 of course
What's your fuel system?
Old Jan 4, 2016 | 04:47 PM
  #276
Sikilla's Avatar
FIC 2150/ ams rail, fuel lab fpr, double pumper walbro 450 hp e85 pumps
Old Jan 5, 2016 | 08:44 AM
  #277
m.al-hassawi's Avatar
Motor is 10.5.1 2.0
Gsc S3 cams
E85 of course
Thats really impressive well done 👍🏼👍🏼
Do you have a dyno gragh we can see?
Whats ur max RPM ?
When u r reach ur full boost on what RPM?
Old Jan 5, 2016 | 09:27 AM
  #278
J_Heath's Avatar
Recently did some mods to the Evo IX 2.4L long Rod FP Zero car my buddy Mohammed owns. Switched from a MAP Rev3 intake manifold that was also sent to Curt Brown for more porting and polishing with a larger TB flange welded on for a cast Magnus manifold. Also HKS 4.11 final drive.
Also a few other misc changes. Car made 835/650 before. The problem was too much torque way too soon and the car would destroy drivetrain parts at the track. With the changes the powerband has shifted to help eliminate that issue and should make a few more ponies up top. I'm thinking 850awhp and torque to be around the same but come in later in the powerband.
I'm also in the process of building mine as well. 2.4L long rod with 9:5.1 pistons, manley turbo tuff rods, Curt Brown head, GSC R2 cams, twin disc clutch, and a few other upgrades. I still plan on just running 93 pump gas with water/meth (VP methonal). Should net 650-700awhp as long as the pump or injectors don't run out. We'll see!
Old Jan 5, 2016 | 12:15 PM
  #279
tscompusa's Avatar
my customer who produced the graphs above with the fp black switched to a fp zero, so this will be a good comparison care between the two turbos as well.
His highest pull on the black was 707/652tq (46psi+ spike)
With the orange/lime curve the car went 135.70 in 1/4.
I'll share the comparison for the thread once its available with any other data requested.
This is the MHI twinscroll black not SS. The car will be of course using the new SS housing with the Zero, so numbers should be pretty nicely improved on the top end.
Old Jan 6, 2016 | 11:03 PM
  #280
tscompusa's Avatar
The customer I posted above we did some testing today at 85% content with pretty conservative values so far. Peak of 37psi and hold 36psi up top.
I will share the final numbers once we extract them, but for now this will be a little teaser result.
The vehicle has some things vibrating / downpipe hitting tcase that's triggering the knock sensor off, so I have postponed further tuning until these audible background noises are addressed so we can safely tune the vehicle to its true potential.
This vehicles running FiTronic, but right now we are locked in E85 mode only.
Its a Olsen 2.3L 10.5:1, FP Zero, 2150cc, Curt brown ported everything, 4.11 FD.
Old Jan 7, 2016 | 06:01 PM
  #281
ZanarkO's Avatar
Jesus thats alot of TQ, bet that car is a monster
Old Jan 8, 2016 | 08:50 AM
  #282
lancerrally45's Avatar
Looks like Tom limited it at 600tq. Was there a reason for this Tom?
Old Jan 8, 2016 | 10:13 AM
  #283
el.guerrero's Avatar
Is turbo leaking oil?
thanks
Old Jan 11, 2016 | 03:15 PM
  #284
thanks
Yes it leaks
Old Jan 12, 2016 | 10:17 AM
  #285
_des_'s Avatar
Originally Posted by jacked cobra
Yes it leaks
hmmmm. It seems like the leaking is a very common issue.
