Stepping my IX up for 91/E85, looking for final preparation suggestions
Old Jun 25, 2017 | 01:17 PM
  #106
2006EvoIXer's Avatar
Originally Posted by 4G63_EVO
Check your lines thats odd, have had my same boost gauge across 4 cars for like 5 years
Going home, i see boost when over 0. So it's not reading a vacuum. If i let off gas in gear, it will show -4. Then goes back to 0. Very weird
Old Jun 25, 2017 | 02:20 PM
  #107
4G63_EVO's Avatar
Odd, good luck with it! Maybe just a bad gauge or sensor
Old Jul 1, 2017 | 01:15 PM
  #108
I suspect its the sensor not sending the correct signal for vacuum. Sent it back so hopefully, I'll get a replacement by next week to reinstall.
Old Jul 1, 2017 | 11:57 PM
  #109
By the way, I did get to race a Hellcat. Got smoked baddddd.
10.469 sec 1/4 mile vs my mid 12's
Old Jul 9, 2017 | 06:47 AM
  #110
845evo9's Avatar
Old Jul 24, 2017 | 11:25 AM
  #111
Just got back from vacation yesterday. As a follow up, replacement sensor fixed boost gauge. It now reads -16 at idle and up to -22 when off throttle and in gear. I'm worried that I'll have to buy replacement sensors often since I see that sensors have been going out often. If it costs $75 each time, I'll probably just replace this unit to a mechanical gauge when this sensor takes a dump.
Old Jul 24, 2017 | 11:36 AM
  #112
4G63_EVO's Avatar
Might just be defect, like I said, ive had the same gauge across 4 cars over 5 years.. Same sensor
Old Aug 12, 2017 | 01:13 AM
  #113
WRC-LVR's Avatar
I use a mechanical boost gauge. have for 11 years. no issues at all. no sensor to go bad
Old Nov 29, 2017 | 03:31 PM
  #114
Went to Fontana drags November 5 and burnt up what's left of my stock clutch running 3 times. Best 60-ft time was 1.797.
I'm #7008. Other is a GTR.��
I beat Scat Pack.
Also beat stock 2006 Corvette. I let off gas when I saw 8000 rpm from clutch slipping, which was 50 feet before end of track. Doh!<br/>Barely made it home with clutch only holding 60 mph in any gear��<br/>
Old Nov 29, 2017 | 03:34 PM
  #115
Just got Exedy Twin Disk installed and had Evo 8 3rd and 4th gears installed while tranny was out.
Also, I broke down Sunday and bought S2 and 5041 springs...
Install and retune in January (planned).
Old Dec 3, 2017 | 04:27 AM
  #116
Steveevo9's Avatar
Well done, great read thanks mate. Can you follow up with the S2's please.
Old Dec 3, 2017 | 10:49 PM
  #117
I think they're on back order so I'll be waiting a while. I got HLA Pressure Regulator and ARP head studs. Both were easy to install.
I did my ARP different than others. I used screw driver to push paper towels down thread to soak up oil and then used the lube that came with kit. I hand tightened and removed to add more. Then i tightened to 50, 60, 70, and then 80 ft-lbs to each one. I used lube on bottom twice and bottom part of top half where washer and nut will lock. I will let it sit 24 hours and retorque 80 ft-lbs again before reinstalling the valve cover.
Here's the HLA PR installed.
Old Dec 3, 2017 | 10:56 PM
  #118
I also bought this valve spring micrometer to check each of my valve spring clearance to make sure I have 1.55". I'll probably put together something to compress each spring to measure thepressure each speing exerts. This way, I can match up the springs to the valve gaps.
Valve spring height micrometer.
GSC 5041 valve springs and titanium retainers
Old Dec 4, 2017 | 08:12 PM
  #119
I retorqued my ARP head studs at 80 ft-lbs again. Some actually turned a tiny bit! Interesting!
I'll check again tomorrow to see it bolts are fully stretched. I'm actually surprised.
Maybe enough oil was in thread to mess things up a bit?
Old Dec 4, 2017 | 11:06 PM
  #120
iD33's Avatar
Congrats on making the power. Judging by the parts I have a feeling we were tuned by the same person here in SoCal. I made similar numbers on a BBK Lite, GSC S1, 3" RRE Stealth turbo back, Mil-Spec 100 cell cat, AEM intake, AEM 320 fuel pump, and RC1200 injectors.
