FP 71HTA / S2's / E85 / 459 & 402 @ 24PSI / RRE "Sam" Tuned
Old Apr 2, 2018 | 07:36 PM
  #76
V.8MR's Avatar
Originally Posted by 2006EvoIXer
This turbo isn't a twin scroll. I love how twin scroll works and won't trade that on my evo.
It is a twin scroll. Uses the OEM turbine housing/manifold and stock CHRA.
Old Apr 2, 2018 | 07:51 PM
  #77
2006EvoIXer's Avatar
are you talking about the T4 borg Warner s366 turbo or the HTA71?
Old Apr 2, 2018 | 08:14 PM
  #78
V.8MR's Avatar
71hta
Old Apr 2, 2018 | 08:28 PM
  #79
71hta
Yes, that is a twin scroll.
Old Oct 26, 2018 | 01:46 PM
  #80
cerevo's Avatar
Gents
Just watched Sam at RRE tune-up my ride this afternoon. The tune went w/out a hitch. No hiccups on 91 & then went to E85
The limiting factor that didnt get it to 480WHP were the injectors (RC1000's)
Pleased to have lowered my max boost down to 24PSI from the previous tune at 27PSI
Bringing it home tomorrow & will be doing an engine detail & re-installing all the other bits I removed before delivering it to RRE
Overall, very pleased w/the the finite details RRE gave to all the rework done (60K service done, 71HTA install, FP Intake / S2's w/springs & the TOON)
The dark blue line is the 91 run
Just curious if you have a plot of your boost curve?
Old Oct 26, 2018 | 02:34 PM
  #81
I dont, Sorry. I just got the minimal plots from RRE (im sure i could have gotten it, but wasnt smart enough to ask)
Looks like you & i have a similar set-up
Old Oct 26, 2018 | 03:20 PM
  #82
Here's mine maxing out my 71HTA with a HFC.
Old Oct 26, 2018 | 03:44 PM
  #83
I believe Joe's 91 tune has boost set to 22psi to redline. And the E85 tune probably has boost set to 26 psi and tapering to 22 at redline.
Old Oct 28, 2018 | 09:37 PM
  #84
Wicked_X's Avatar
486 on 28 psi??? Damn! Mine is in the mail
Old Oct 28, 2018 | 11:47 PM
  #85
***My head has a mild port and +1mm oversized intake and exhaust valves. Plus, I have S2 cams. On stock valves and no port, it should be similar to Joe's setup.
Old Oct 28, 2018 | 11:55 PM
  #86
Here is mine on stock valves and no port with about the same boost curve:
Old Oct 28, 2018 | 11:58 PM
  #87
Now that I think about it, you can get close to 480 because Joe has oem O2 housing and I'm always on a HFC. If you run O2 housing and test pipe, you should be able to squeeze out another 10-15 whp.
Old Oct 29, 2018 | 12:00 AM
  #88
Wicked_X's Avatar
Well I'll be on stock head and cams for now, so I will probably run 30 psi to accommodate for the lack of supporting mods
Hoping for around 450, we will see!
Old Oct 29, 2018 | 12:04 AM
  #89
Wicked_X's Avatar
I will be on test pipe and a map o2 housing!
Old Oct 29, 2018 | 12:31 AM
  #90
Sorry, with stock cams, O2 housing, and HFC, this is what I got (430):
