FP 71HTA / S2's / E85 / 459 & 402 @ 24PSI / RRE "Sam" Tuned
Old Nov 8, 2018 | 04:10 AM
  #121
Project_Broke's Avatar
I held 28-29 lbs on my HTA71 until I toasted the turbine due to a pretty massive leak.
It's not unheard of.
Old Nov 8, 2018 | 04:39 AM
  #122
Terror Rising's Avatar
I didn't boost leak check it right before the dyno, but every time I remove any IC piping it gets checked when going back together. I have an old Evo 8 variant of the turbo (4 yrs?) and an 18psi actuator and still on MAF. Also of note, I think if that pull started before 3250 RPM it probably would have moved spool a little to the left. When I used to tune it I would always start at maximum 3000 RPM
Old Nov 8, 2018 | 05:02 AM
  #123
cerevo's Avatar
The torque seems really low too, with s2s and an Evo 8 I make a lot more power a lot sooner
My spark plug gap is at .020 I think and still blows out at less than 26psi. The head is ported though so I could just be flowing that much more air, or it could be a bad port job and can't get the exhaust out fast enough?
There no port work done to the turbo, and it's an FP race manifold
Old Nov 8, 2018 | 06:35 AM
  #124
2006EvoIXer's Avatar
If you have a good set of oem coils, try switching it and see if problem is still there.
Old Nov 8, 2018 | 06:39 AM
  #125
I see that now. Your pull started later than most, so it shifted curve a bit to the right.
Old Nov 8, 2018 | 10:29 AM
  #126
kaj's Avatar
kaj
Originally Posted by 2006EvoIXer
And have 10.8 housing. I'm not sure how he got 9.8 to fit. I only see 71hta for IX on FP site.
For a while, FP sold a version with the smaller turbine housing. I had one. Mine was based off the 6.5 TME turbo. Downside was less peak power, bright side was crazy spool with the smaller housing and titanium exh wheel. I prefer my current setup, though.
^^ Yep. It can be catastrophic.
If you are not using OEM coil packs, I'd recommend swapping back. If you are, maybe they are tired (unlikely, but possible). Any way to swap on another set to test? I'm told porting our heads do more damage than good, but I have no personal experience.
I always start at 2500rpm. Starting at 3250 could explain things. Lighter load and that means only it only took 950rpm to get to 20psi. I assume that would affect the torque curve, too.
On the bright side, with that Evo 8 hot side, you should see crazy fast spool, so that's pretty nice.
Old Nov 13, 2018 | 12:54 AM
  #127
Also, the current 71hta is actually a 68mm. Didn't they offer a real 71mm in their earlier versions?
Old Nov 22, 2018 | 06:07 AM
  #128
Gtimportfanatic's Avatar
5 Year Member
after seeing these results i'm not sure how i feel lol, my car is on 93oct about 26psi tapers to 23 up top taking it to 7500, i'm on a street tune but i've laid waste to cars that are between 400-450whp rwd cars, even beat a 530whp E93. if you guys are touching 480whp on e85 i think i'm probably around 400whp then haha. i'll get mine dynotuned to see if we can add some more timing and a little more boost.
Old Nov 22, 2018 | 08:36 AM
  #129
You probably have a fat low/mid range powerband like ours on E85. 93 octane is nice bump from 91 but our tunes keep boost to 22 psi on 91 for safety. How do you like your M2 cams? I have a MIVEC set sitting in living room I'm planning to sell. Not sure what they're worth...$200?
Old Nov 22, 2018 | 10:14 AM
  #130
Wicked_X's Avatar
What kinda timing are you guys running on this turbo? On E of course
Old Nov 22, 2018 | 01:35 PM
  #131
5 Year Member
l love them, they idle smooth and apparently make decent power, i see full boost around 3000rpm if not sooner! I’ve never really looked into pricing on them as i bought my car with them but coming from Hondas, $200 for cams is a steallll hahah (cams for my civic were $750 used)
Old Nov 22, 2018 | 01:36 PM
  #132
I recall seeing 8 degrees at peak boost (28psi) in my logs.
Old Nov 22, 2018 | 01:39 PM
  #133
kaj's Avatar
kaj
do you have a graph of that?
Old Nov 22, 2018 | 05:55 PM
  #134
I recall seeing 8 degrees up top in my logs.
Sorry, when I said up top, I was referring to 28psi boost. I fixed earlier post.
Old Nov 23, 2018 | 01:37 AM
  #135
Wicked_X's Avatar
Yea, would like to see that graph! 4th gear?
