how high can I rev my engine with these mods?
Old Jul 4, 2005 | 08:57 AM
Derek888's Avatar
I will have a full race head with ported intake, exhaust, 1mm oversized
Ferrea racing valves, crower valve springs and retainers, hks 272/272
cams and cam gears. How high can I rev the engine with these mods or is it the 2.0 stroker kit that can make the engine rev higher?
Old Jul 4, 2005 | 01:38 PM
EVIL_EVO_VIII's Avatar
U should be able to rev to 9k. I have a friend with the head done and 280 cams and he revs real close to 9k.
Old Jul 4, 2005 | 01:42 PM
JSYEVO's Avatar
9k?! thats like s2000 range, pretty high, but will you be making power all the way up to there?
BSREVOLUTION's Avatar
yeah, you probably could rev up to 9000rpms. but are you on a stock turbo, if so that little thing is going to get very stressed.
Old Jul 4, 2005 | 01:44 PM
Curt@MrLed's Avatar
Former Vendor
unless you have a bigger turbo its redundant to rev that high.. plus i wouldnt recommend it on a stock bottom end.. and why do you want to rev that high...
Old Jul 4, 2005 | 01:59 PM
EVO8LTW's Avatar
Your valvesprings may be up to 9000 rpm but I'd be concerned about spinning up the stock rods that hard. A stroker kit is actually not the way to go for higher revs because of increased piston speed and worse rod/piston geometry from the longer stroke.
Old Jul 4, 2005 | 08:55 PM
Devbo's Avatar
had a budy blow his stuff up doing that.. lol
Old Jul 4, 2005 | 08:57 PM
en1gma19's Avatar
The valvetrain will handle 9k but the rod bolts won't
Old Jul 4, 2005 | 10:19 PM
Derek888's Avatar
Well if the stock turbo can hold 26psi with alky, I dont see why reving it to 9k is gonna do any harm. I guess the bottom end would have to be built in order to rev it that high
Old Jul 4, 2005 | 10:21 PM
Warrtalon's Avatar
It isn't efficient at 26psi, and that doesn't have anything to do with going to 9k rpm anyway. The stock turbo runs out of breath well before you get to 9k rpm, so it would be a waste, not to mention dangerous.
Old Jul 4, 2005 | 10:24 PM
zlancer's Avatar
theres no need for it...a higher revving engine doesn't mean your going to make more power. you just need to run your car on a dyno. then you'll know your exact powerband and when you need to shift and such. also yeah sure...you engine might be able to rev to 9,000 rpm...but how many times it can do that should be the question.
Old Jul 4, 2005 | 10:25 PM
TRDHarrier's Avatar
do u have head studs????
Old Jul 4, 2005 | 11:18 PM
fre's Avatar
fre
My friend revs his talon to 9500 no problem. He has some better internals though. I would say 8500 wouldnt give you any trouble. I rev to 8000 all the time and I have nothing done to the valvetrain or bottom end. And until today I didn't have head studs either. With 28 psi though I don't trust the stock bolts anymore.
Old Jul 4, 2005 | 11:45 PM
Derek888's Avatar
yes I have headstuds
Old Jul 5, 2005 | 03:20 AM
plokivos's Avatar
yeh i don't see the point either.
unless you have bigger capacity turbo, you really don't need to rev that high. Your stock turbo is long out of its efficiency range at around 6000 rpm.
you don't have that sorta compression ratio that s2k or other n/a cars have like nsx.
you could rec upto 9000rpm though. i don't know how long it'll last though.
ecktt
May 27, 2015 01:25 AM
TACH_MOTOR_WORK
EvoX 'For Sale' Engine Internals and Drivetrain
36
Mar 9, 2014 02:47 PM
ablan029
21
Apr 20, 2009 06:50 PM
gotboostawd
14
Apr 1, 2009 02:19 PM
arptunner
Lancer-Mirage Compatibility Forum
26
Jan 17, 2008 04:10 AM
