mounting the SMC alky controller
Old Jul 20, 2005 | 04:55 AM
Derek888's Avatar
Besides the coin tray is there any other places to mount it? If you have any pics of it at a different location lets see them.
Old Jul 20, 2005 | 05:49 AM
gsujeff55's Avatar
i considered mounting it on the inside side of the console. you sound like you want it where you can see it at all times though....its going to look outa place most anywhere i think...maybe the stock DIN if you still have it
Old Jul 20, 2005 | 06:00 AM
Ivan_C's Avatar
I mounted mine into the radio relocation panel, right below the radio. It blends in pretty well and is still highly visible. I'll take a pic after work.
Ivan
Old Jul 20, 2005 | 06:19 AM
DynoFlash's Avatar
Ivan
That is the best spot!
Old Jul 20, 2005 | 08:47 AM
GOKOU's Avatar
Ivan
I have the MIT gauges there so I guess that spot is out of the ???. I need to think of somewhere else
Old Jul 20, 2005 | 09:05 AM
Derek888's Avatar
Ivan
I think that is a good spot since I also have the relocation kit. Did you use double sided tape? I was thinking of drilling 2 holes on each side and use zip ties.
Old Jul 20, 2005 | 09:29 AM
Ivan_C's Avatar
You should be able to, I have the radio relocated to that location.
Nope, it's actually cut into the relocation panel. It slides in under the radio and is held in with pressure from the radio itself. I had to trim some of the hidden dash plastic for it to clear. All that is seen from the interior is the face with the leds and test button.
I wouldn't see why this couldn't be done with the stock cubby hole or the factory gauges. Though might need to figure out a rear support. Could be something as simple as a bent piece of aluminum and tape.
Ivan
Old Jul 20, 2005 | 09:37 AM
Derek888's Avatar
I have the relocation kit so the only way mine will fit is right under it and above the ash tray.
still interested in seeing how yours look
Old Jul 20, 2005 | 02:41 PM
Ivan_C's Avatar
Ok, here are the pics as promised.
Pic 1
Pic 2
Ivan
Old Jul 20, 2005 | 10:11 PM
Derek888's Avatar
Pic 1
Pic 2
Ivan
thanks for the pic.
Old Jul 21, 2005 | 03:35 AM
evovette's Avatar
I put my controller in the ash tray, I'll grab some pics today
Baltzer
Northwest Region
Mar 31, 2011 05:23 PM
vegasevo9
Jan 3, 2009 07:04 PM
SeanC
14
Oct 24, 2008 03:49 PM
dsm25psi
May 15, 2008 11:47 AM
MyRoN
04-06 Lancer Ralliart How To Requests / Questions / Tips
Feb 11, 2008 09:33 PM
