EVO IX Dyno Thread
Old Aug 10, 2006 | 03:13 PM
  #136
JDMevoBOOST's Avatar
So are u guys saying any 3" dp sill lose low end responsiveness???? I guess if theres anything thats cheap to change later on it would be the dp....120-175 bucks for a new one
Old Aug 10, 2006 | 05:15 PM
  #137
ST's Avatar
ST
More precise info after getting dyno sheet:
baseline tbe:
211.7whp @ 5750 rpm
232.8wtq @3750 rpm
dyno tuned tbe:
289.5whp @ 6000rpm
310.3wtq @ 4000rpm
damn baseline numbers sucked so bad =/
Brian aka Razorlab explained it best probably:
"Ok. I think I see the problem here now that I have had a full night sleep. You had a TBE on the car untuned for the baseline run right? The IX's actually lose power most of the time from doing this. Usually the IX sees the increased airflow because of the increase flow of the exhaust and lowers boost among other things."
Old Aug 10, 2006 | 07:35 PM
  #138
Peteypab2133's Avatar
Well guys, i just got home from Buschur racing...
My very first pull un-tune:
306 AWHP and 308lb (dan knows i didnt know how much boost i was pushin)
Next pull boost turned down:
290/300
Final pull with 104/93 octane mix (about 3 gallons each)
325/330
Said my IX felt very strong... Got video footage/graphs to be uploaded tomorrow sometime..
Wish he printed me all my graphs, just got 2 of my 4 total pulls.
Mods as follows:
manifold
02 housing
TBE
MBC
air filter
Nick claims it wouldve been somewhere around 370 to 380 AWHP if i were on a dyno jet... Im planning on getting a Dyno run somewhere just for bragging rights if ya know what i mean..
Old Aug 11, 2006 | 04:17 PM
  #139
ROK EVO's Avatar
I had my IX tuned yesterday. The tuner dynotuned the car, using ecuflash on 'Dynodynamics'. Mods are; TBE (no cat), airfilter. It made 280wtq & 270whp @ 21psi on 93oct after the tune. Stock IX's baseline at 210~215whp with 205wtq on this particular dyno. I will post the dynosheets including afr & boost graphs soon. The car is noticeably faster and strong in all 'rpm' ranges after the tune.
Old Aug 11, 2006 | 05:16 PM
  #140
91TB78's Avatar
Nice numbers ROK
Old Aug 11, 2006 | 05:51 PM
  #141
3000ways's Avatar
290/300
325/330
Mods as follows:
manifold
02 housing
TBE
MBC
air filter
Woooo, wait a second, you made 325WHP on Buschur's Mustang with those mods, damn that's got to be one of the highest I've ever seen, I mean WOW! Congrats on such a strong IX.
Old Aug 11, 2006 | 06:22 PM
  #142
boostedwrx's Avatar
He has a few mods though... manifold, 02 and race gas! Pump would probably be a few lower.
Old Aug 24, 2006 | 06:44 AM
  #143
3000ways's Avatar
bump
Old Aug 25, 2006 | 12:49 AM
  #144
1badgsex's Avatar
just got tuned by ivey first pull untuned 334 hp not sure what the boost was at then final tune was 353hp and 361tq at 22psi and 93 pump and that was in a 99 degrees shop, the car is out of fuel sean said and the intake i had on the car was hurting me so i swapped back to stocker for now, iam going back shortly with 660's and probally a buschur intake ill post the new #s as soon as i get retuned
Old Aug 25, 2006 | 12:58 AM
  #145
AZ EVO IX MR's Avatar
Mynes Mustang dyno Ecuflash 91 pump: 292 hp 301 tq
104 race gas: 337 hp 368 tq
Middle of day in good old hot AZ
Old Aug 25, 2006 | 03:53 PM
  #146
RenoEvo's Avatar
Thats about 370whp on a dynojet which is the norm for a stg.1 IX on race gas. His car seems to be just a little bit stronger than others because his runs were done at about 97 octane rather than 100 or 104
Old Aug 26, 2006 | 05:31 PM
  #147
Max-Q's Avatar
Evo IX MR tuned by AMS - 354 whp/ 341 wtq on a Dynojet dyno
Mods:
Helix dp
Helix test pipe
TurboXS cat back
Hallman Pro MBC
AMS licp
AMS fmic
Walbro 255
Buschur cone air filter
one step colder plugs gapped @ .025
93 oct
Old Aug 28, 2006 | 01:31 PM
  #148
Thats what Al told me also... It wasnt straight 104 octane, it was about 2.5 gallons added to almost half tank that was already there...
There wasnt even a seperate map made, just upped the boost..
Old Nov 20, 2006 | 11:44 AM
  #149
bboypuertoroc's Avatar
Veteran: Army
Dyno'd at Rad Motorsports (RMS) in Hawaii... dyno is a AWD Dynojet, correction is SAE.
Mods are in sig.
First run was 306 awhp and 304 awtq... boost line popped off where they tapped in for the MAP reading at 19psi.
Second run was 335/320. MAP sensor read 25psi (Autometer read just over 23psi...). Encountered knock up high (8 counts at one point).
Third run... turned down boost and put down 336/321. Hit 24.4psi and had at most 2 counts of knock. Also, for all the runs, my A/F below 5500 was around 10:1. After that, it was around 11.5:1 (this was read at the tailpipe)... time to fine tune my flash.
Old Nov 20, 2006 | 04:25 PM
  #150
High_PSI's Avatar
Yeah I bet you can get 113-114MPH with more tuning.
