Finally, 20G-9 dyno #'s!
Old Feb 7, 2006 | 08:53 AM
  #121
TTP Engineering's Avatar
Originally Posted by Ted B
I made no contradiction. The volume of flow is independent of pressure, and differs sharply at 4krpm than at 8krpm. This is (or should be) self explanatory.
What's the difference in torque between 32psi and 34psi?
. . . how about 30psi and 34psi?
If it's 50 ft/lbs, then we have something to discuss. If it's 10 ft/lbs, it's moot.
How about 35-45ft-lbs? Let me know when you test this. As far as I can estimate, this should be close. The torque curve on the dyno sheet is (or should be) self explanatory.
Old Feb 7, 2006 | 08:59 AM
  #122
Ted B's Avatar
I'll perform some testing two weeks from today, and I'll post a thorough report. It'll be done with a 20G-9, but I suspect the trends should be similar.
Old Feb 8, 2006 | 06:55 AM
  #123
Jrod@Buschur's Avatar
The graph shows exactly what it should, you are partly correct TTP. The high boost spike of 34 psi at low RPM's is fine and will increase torque greatly. What Ted's point was is trying to hold that 34 psi out to 8,000 rpm does not have the same effect, making him correct too.
I can see from the datalog you posted that the boost falls off quite a bit. Hard to tell how much though from your log.
You will also notice that the car you posted the graph from looses 200 ft lbs of torque from 4500 to 7500. That HP curve looks nice though. How much boost did that car have at 7500 rpm?
David Buschur
www.buschurracing.com
Old Feb 8, 2006 | 07:17 AM
  #124
David Buschur
Well it pretty much a moot point as you cannot force a turbo to hold boost with a high V/E motor at high RPM. You can help it a little with a stiff WGA and either pull the WG line or run your boost controller at 100% duty cycle. After full tilt, it is gonna give you all it has and if your V/E is too great, its going to suck it dry early on. My point was that 34psi was off the map and still made good tq (outside of efficiency range).
If Dave did not try to get the same out of his turbo, there would be no need for his 26psi minimum actuator he was using.
Much like your shop, we lost a computer also. Our laptop. That log is from Oct 2005. We replaced the computer about Nov 12. From memory I think it ended up tapering to 22-24psi.
If the discussion is over running 30-34psi at 8000rpms, then there is nothing to talk about. I think Ted's point was outside of the efficiency range, there is no point in running it there and no returns but premature wear. My point was to say "look, here is more power and tq".
An important aspect to look at is to hold higher psi in the upper rpms, you need that boost spike to carry you over so they basically come together in a package, not one without the other.
Old Feb 8, 2006 | 08:56 AM
  #125
David Buschur's Avatar
I actually made that post, we had another computer crash here so Jarrod and I are sharing mine. He's big guy, makes my legs fall asleep if he sits on my lap too long! haha
Anyway TTP, I got the opposite from Ted's post, maybe he can chime back in on what he meant.
Making 34 psi at 3,000 rpm doesn't necessarily put the turbo out of it's efficiency range but the same turbo trying to make that much boost at 8,000 rpm will. The engine doesn't consume as much air at 3,000 rpm as it does at 8,000 obviously, atleast in most cases.
Also don't agree on your boost theory. Using the right boost controller you could set up the turbo to hold a flat high boost level from 3,000 rpm to 7,000 rpm with no spike in the boost pressure at all. I have logs if you'd like to see them.
David Buschur
Old Feb 8, 2006 | 09:06 AM
  #126
David Buschur
We both have experience with 280's. The notion of trying to get a 16g to "make that much boost" (34psi) is not physically remotely possible even with the WG welded shut and those cams.
I would like to see the logs and find out what boost controller you are referring to. I would be surprised to find you run 23-24psi peak and 23-24psi @ 8000rpms with 280s.
I can see if I can find my logs also.
Old Feb 11, 2006 | 09:52 AM
  #127
sspeed's Avatar
Not to hijack this discussion, but are there any numbers yet for 20G-9 on 91 or 93 with only the "common mods" (TBE,Cams,Flash/ECU,LICP)? I tried a search with no luck.
Old Feb 11, 2006 | 10:12 AM
  #128
Turd Squirter's Avatar
Originally Posted by Turd Squirter
David...I think myself and a few others would be much more apt to seriously consider the 20G IX if you maybe show us how it performs on a BPU (including cams too) Evo running 93 octane. Your RS is cool but way over the top for most of us. Evoonyoass has a cool setup but the meth, alky, C16, etc is probably a little more than the average Evo owner is looking to do also.
I'm making a big assumption, but I believe most people looking towards a bigger snail have a TBE, some sort of software, an intake, some 272/272 cams and that's about it. And I know it's a lot to ask, but California Evo owners would also really love to see what kind of numbers this new turbo could do on our beloved 91 octane urine with a mild street tune.
Just a suggestion.
+2
Old Feb 11, 2006 | 02:28 PM
  #129
DragNRacing's Avatar
Old Feb 11, 2006 | 06:56 PM
  #130
Evil EV0's Avatar
+2
Make that +3
Im looking for something as most us out here in CA are to make decent power on our 91 I will be getting the WORKS water injection kit when it comes out so I might run water/meth once in a while, but most of the time would be on water with 91 octane. With my mods and a 20G and water injection, I would be happy with 375-400 whp if thats possible
Old Feb 11, 2006 | 08:26 PM
  #131
tobz's Avatar
+4
+4
  #132
tobz's Avatar
+4
+4
Old Feb 12, 2006 | 04:02 AM
  #133
EVO8LTW's Avatar
Why do you guys keep bumping this for 20g numbers on a mildly modded car? Why would you want to put this on a mildly modded car when there are less expensive ways to add just as much power? Buschur has already posted that it would be "silly" to put a 20G on a car with less than Stage 4 mods.
Old Feb 12, 2006 | 07:53 AM
  #134
fsugatorbait's Avatar
Mildly modified to some means I/TBE/cams/supporting mods/tune- just a difference in vernacular.
Old Feb 12, 2006 | 10:14 AM
  #135
sspeed's Avatar
See what was posted above. With the exception of a new FMIC what we are talking about IS a stage 4.
