View Poll Results: Did Mitsubishi screw up on the clutch?
Yes, You screwed the pooch
483
61.69%
No, The clutch is fine.
300
38.31%
Voters: 783. You may not vote on this poll
Did Mitsu screw up on the clutch
Old Nov 29, 2006 | 04:14 PM
  #466
sonicnofadz's Avatar
I think many of the failures (maybe not all of them) are due to drag racing. The Evo was never meant to deal with launch after launch of drivetrain abuse like so many typical idiot American drivers will subject their car to. Any powerful AWD manual transmission sports car will naturally eat the stock clutch after repeated abuse.
Old Nov 29, 2006 | 04:16 PM
  #467
Originally Posted by EVO8904
I DESTROYED my clutch in the first month, hahaha. I wanted to see how much abuse it could take. It lasted though 41 LAUNCHES within 25 days. I had the money saved up for a new clutch so I did not care. I had a ceramic disk Daken clutch put on for $1200 with all parts and labor and it has been holding for 7 months and feels as strong as the first day...
Your transfer case must hate you.
Old Nov 29, 2006 | 04:56 PM
  #468
EVO8904's Avatar
I think it likes it...
Old Dec 8, 2006 | 10:34 PM
  #469
RED DEMON's Avatar
My 03 has 49k on the clock and i still have the FACTORY installed original stock clutch. This is wit roughly 350whp but i can tell the clutch is at the end of its life. I just today ordered an Exedy twin HD; thought i would treat myself to a nice new clutch since i got so many miles outta the stocker!
I am damn surprised that i got that many miles out of it, especially with the abuse i put it through (autox, drag, launches, highway onramps). I think it all depends on the driving style and VERY much on how you launch and how you release the clutch pedal.
Old Dec 8, 2006 | 10:47 PM
  #470
Pure Playaer's Avatar
isnt it the same exact clutch in the 14k lancer?
i think thats some bs.
Old Dec 9, 2006 | 05:36 AM
  #471
LVIIIR's Avatar
I replaced the clutch on my 03 Evo after 19k, as far as my 06 evo 9 i have just shy of 27k and the thing holds strong, 03 evo was stock the whole time while i have been modded for about 400 whp on my 9 for about 15k!!!
Old Apr 8, 2007 | 02:34 PM
  #472
slamedsrad600's Avatar
just got my 2003 unmodified evo at 22k throw out bearing was makin a lil racket whey clutch was out. at 2738 miles started sliping now in the shop at 28089 miles clutch is bein replaced hunk of ****! should have keep my sti!! lol
Old Apr 8, 2007 | 02:43 PM
  #473
Liqquid's Avatar
Mine was good till 11000 miles.... then I dropped in a set of 280's and I could feel the clutch starting to slip at peak torque... actually, the data logs showed it too
So I replaced it before it really failed, but it was going to soon enough
Old Apr 8, 2007 | 05:41 PM
  #474
evil4g63's Avatar
i heard that the stock clutch from mitsu was only rated for a max of 250 lbs of torque and it makes more than that bone stock. an upgrade should be one of the first mods especially if anyone plans on adding power, which what evo owner isnt gonna add power
Old Apr 8, 2007 | 05:47 PM
  #475
fyu2x's Avatar
just blew mine at 15k miles, i think. My car does not accelerate after like 2k or 3 k rpms. so after reading everyones posts i think it is the clutch, SOB cant believe this, so early brand new car.
this is my first stick shift and i did grind, launch, missed gears all that bad stuff.
im gettin an ACT street clutch and is a flywheel necessary to add too? let me know thanks
Old Apr 8, 2007 | 05:49 PM
  #476
fyu2x's Avatar
hey LIQQUID, who installed ur clutch and how long and how much did it cost? i am lookin for someone to do it asap. thanks
Old Apr 8, 2007 | 05:50 PM
  #477
jrsimon27's Avatar
yep it is^^^^^
  #478
fyu2x's Avatar
hey LVIIIR, who replaced ur clutch? how long and how much? thanks
Old Apr 8, 2007 | 05:52 PM
  #479
Evo IX MR's Avatar
Almost 18,000 miles w/ over 30 launches and lots of ripping. Constant heel-toeing and high rev matching. My buddy Dustin has a little over 18,000 miles and probably over 100 launches and his clutch still holds and doesn't slip (and he has about 340whp). My clutch squeaks when I push it in when its cold out (i think my throwout bearing is a little messed up because I had the same problem with my Integra)...this might make the clutch go out a little faster but shouldn't make too much of a difference.
Old Apr 8, 2007 | 06:10 PM
  #480
Liqquid's Avatar
No, it is most def. NOT necessary... even ACTman will tell you that
You MUST have a fresh, flat surface to set the new clutch on, so if you are going to keep your stock flywheel as I did, you need to take it to a machine shop and have it ground... mine was covered in heat spots, they took .020" off and it cost me 30 bucks.
I kept the stock one as I like some weight on the flywheel, when you go to a lighter wheel, you loose some inertia, making the car harder to daily drive in my opinion. I went with a stage 2 Exedy clutch, so it was going to be harsh enough already without a lightweight flywheel adding to it.
For road racing, I know its a differant story... rev matching is easier, I've been told.
