FULL RACE TWIN SCROLL 30R results and data
Old Dec 9, 2007 | 11:20 AM
  #61
Ted B's Avatar
A few notes to consider:
- This is a 93 octane reflash, and the car is running less boost (24.X) than it did at the track. There is more power left in it (as evident by the 126mph trap speeds).
- These cams are retuned to give a bit more emphasis on the top side of things. If he wanted absolute best spool, he would have installed them at 0/0. As anyone can see, it spools quickly. A glance at the video reveals one thing that isn't recorded on a dyno - time to rpm. Things begin happening quickly from only about 3k rpm.
- A changeover to a 1.06 A/R TS T3 and a bump in boost pressure (26-28 psi) will give another 20-30whp with the same 93 octane fuel, and loses only ~100-150 rpm in spool (as Drifto noted on his car). With evodan2004 demonstrating 126 mph traps using this quick-spooling .78 A/R TS hotside, I would be hard-pressed to recommend anything else for this particular turbo for street and with 93 octane.
What this illustrates is how streetworthy and versatile a twin scroll 3076R setup is as compared to the regular open housing configurations. I've said this only a dozen times before, and I'll say it again, one has to actually drive this setup to fully appreciate how responsive the big turbo is with TS.
  #62
EvoDan2004's Avatar
ok lots of pics posted.
Old Dec 9, 2007 | 11:29 AM
  #63
yellowEVO21's Avatar
Originally Posted by evodan2004
you 99% will. just give me time lol
I'd kill to see a ts 35r with the hta done to it, haha.
Old Dec 9, 2007 | 12:09 PM
  #64
EvoDan2004's Avatar
i have a few things ill be doing... this will/might be one of them . depends how things go
Old Dec 9, 2007 | 02:25 PM
  #65
DS-03evo's Avatar
Did you have to get the coil on plug...because you were blowing out spark, or get it for down the road when running high boost?
I see you roll with the gold foil also...
Looks sweet!!
Old Dec 9, 2007 | 02:33 PM
  #66
crcain's Avatar
Did you do the videos, datalogs, and dyno runs on the same map?
Old Dec 9, 2007 | 03:03 PM
  #67
EvoDan2004's Avatar
yes
Old Dec 9, 2007 | 03:11 PM
  #68
crcain's Avatar
How much more boost did you run at the track then on the dyno exactly?
Were you watching the boost controller on your passes?
In the part of the map above your "pump gas boost level" are these cells tuned for pump or race? Meaning would you det if you hit these cells on pump? If you wouldn't det in these cells, why do you not run them on the dyno?
Old Dec 9, 2007 | 03:16 PM
  #69
EvoDan2004's Avatar
i cant watch my boost controller because its under my hood while im driving.
THE CAR IS TUNED FOR 93OCT 24/25PSI yes the car knocks BAD when i go over 26 psi...
Old Dec 9, 2007 | 03:22 PM
  #70
kreionic's Avatar
Dan has a map sensor, so when he is talking about boost its not guess work. This set up has never been tuned on race gas. When he went to the track he added a few gallons of 100 oct and went to 26/27 psi on the pump gas map. No timing or a/f changes
For the dyno PSI look at the logs he posted
Old Dec 9, 2007 | 03:38 PM
  #71
crcain's Avatar
Hi.. sorry I meant boost _guage_ not controller. Did you datalog at the track and check your boost or eyeball it with the guage?
And if a car knocks on pump at boost level X, and you run boost level X at the track because you have some race fuel in the car, then your running a race fuel map in my book.
Old Dec 9, 2007 | 03:45 PM
  #72
TougeTuned00's Avatar
Hey whats goin on Dan congrats on the numbers and whats this I hear of you goin for the ts 35r instead of the 40r.
Old Dec 9, 2007 | 03:49 PM
  #73
EvoDan2004's Avatar
hey. who are you from my home town??? lol. im doing a 35r now. im sure a 40r will come in time. probly 600miles after the 35r like i did with the 30r. the 30r turbo only has about 700miles on it and its coming off. haha
Old Dec 9, 2007 | 04:13 PM
  #74
HaVoC RR's Avatar
lol
Old Dec 9, 2007 | 04:21 PM
  #75
EvoDan2004's Avatar
yes i logged my car while i drag race. 27PSfnI. twenty seven pee S eye......
i dont play guessing games.
fine im running a race gas map. i really dont give a crap what you think. dude your really pissing me the hell off. read the damn threads and info. holy crap.
