FULL RACE TWIN SCROLL 30R results and data
Old Dec 9, 2007 | 08:33 PM
  #91
High_PSI's Avatar
12.0+ A/F kinda lean on 93, you think?
Old Dec 9, 2007 | 08:37 PM
  #92
crcain's Avatar
Originally Posted by scorke
Uh, no because your car would knock at a lower boost level if your running race gas timing on pump gas regardless of boost pretty much.
Your book is unique to the world
Scorke
Thanks for clarification of what the world's position is lol.
My point is, which I suspect you comprehend already, is that for 95% of the quarter mile the time was done in load cells which would knock on pump. I don't know how those cells are mapped, but I can only go by the fact you couldn't run it on pump.
Also as an aside, I don't understand why a tuner would make a map that knocks at 27 psi on pump, but no knock at 25. Why not map the car so it doesn't knock at 30 psi?
Old Dec 9, 2007 | 09:06 PM
  #93
scorke's Avatar
You tune a map that knocks at 27 psi and not at 25 because thats how you get the best out of a motor in terms of safety and power.
You can tune a motor to take 30 psi on pump (some can), however you do this by making the motor very boost friendly (internally, mechanically, and tune wise( very low timing amongst other things).
Why doesn't everybody run maximum boost on ****ty octane? Because its dangerous and doesnt make as much power, or make it as safely as doing it on high octane.
I know you understand a lot but your logic seems to be flawed.
Your Race gas map is more aggressive than your Pump gas map because it can be, due to the octane. If you were to run the same boost and timing with pump gas as you do on race gas you might gain a little power but I am sure it would be much more prone to knock.
Scorke
Old Dec 10, 2007 | 04:23 AM
  #94
HaVoC RR's Avatar
Originally Posted by evodan2004
did u call me before?? call me back if you did. sorry i missed the call.....
ill buzz u back at lunchtime..
Old Dec 10, 2007 | 05:05 AM
  #95
deadbeatrec's Avatar
thats an insanely fast spool.
Old Dec 10, 2007 | 06:22 AM
  #96
crcain's Avatar
Scorke, your basically saying a map that knocks is good.
My point is, I'm not saying a tuner should say here, run 40 psi held, all day long on 93. I'm just saying that a tuner should map for a lot of boost. That way if your boost goes up a little bit your not all the sudden knocking. If you look at the logs of Dan's map, for sure he could run more boost on pump, by just pulling timing more. Would it be faster? Maybe not. Would it make the pump gas map safer? I think so which is my point.
And on top of that, Dan could have made a run at 28 psi on pump on the dyno and Dan could have made the decision on what boost he likes to run on pump. Not because he is forced to cuz the car knocks.
Now, I believe Dan's been mailed in flashed, and maybe the pump gas map is not complete yet. So I'm not saying this all applies to Dan in particular, I'm just saying generally.
My argument saying Dan was on a race map was a bit rigid. In reality he was not on a pump map, and not a full race map. Only Dan and his tuner know how aggressive the cells at 27 psi are mapped. Which is the part of the map he would have been in. Not the pump safe area.
Old Dec 10, 2007 | 06:24 AM
  #97
crcain's Avatar
Dan what is your base fuel pressure? (fuel pressure when vacuum hose off)
Bump on this question of fuel pressure.
I'm curious because my friends car with revolvers, 2 litre, green, ported mani's and tb, autronic, rc1000's, etc runs about same injector duty cycle on pump for that boost level. Little bit better spool too.
Old Dec 10, 2007 | 06:37 AM
  #98
LilRico's Avatar
evodan2004, I'm very happy to see your update and successes as well with the TS set-up. I can't wait to install mines. Too bad for you, JestR is my neighbor, so I'm going to specifically tell him "To make me way faster then you"... Succkaaa
Great spool, your car looks great, sounds good, and slow down a bit because you're buying all the mods I want. Last thing I need is to hear from you saying I'm biting on you..
Old Dec 10, 2007 | 08:10 AM
  #99
CBRD's Avatar
Dan,
when are you coming out to the shop, get charlie here on the same day..
ill cover the dyno time.
cb
Old Dec 10, 2007 | 08:17 AM
  #100
Zeus's Avatar
sorry i got steamed.... lol
how are you. i ment to send you a pm with link but i forgot. my bad. i cant wait too see the results from 30 to 35r ether. should be a nice comparo. i would like to pm you later and talk to you about something i been thinking. ttyl.
No problem... looks like I'm about to have to get involved again anyway as people are straying way off you thread again.
Free free to PM or email me ANY time. Sometimes I'm a little slow getting back these days, but you would not believe the amount of contacts I receive daily... I'll answer/chit chat as I can
On a side note... can you email me your video links. For some reason they are being filtered for me, and I don't have time to hunt them down in the source right now. Thanks!
Old Dec 10, 2007 | 08:18 AM
  #101
EvoDan2004's Avatar
I just spoke to jogn. He said a small fee and I won't have any worries. Hahahaha. J/k
I'm going to a 35r and a few other goodies after that. We can internet race each other.
Old Dec 10, 2007 | 08:27 AM
  #102
HighwayStarX's Avatar
I got to see this car in person at a meet not to long ago and i am in love =]
Old Dec 10, 2007 | 08:38 AM
  #103
EvoDan2004's Avatar
Of course he will have faster spoolup. Also cam timing I'm sure is not the same.
Old Dec 10, 2007 | 08:40 AM
  #104
Geoff Raicer's Avatar
dan -- thanks for doing all this testing, hopefully ill be in NJ for christmas when you are doing the 35R test!!
also, i think i convinced my dad to get my mom an evo8 for christmas which means merry christmas to me haha
Old Dec 10, 2007 | 08:58 AM
  #105
EvoDan2004's Avatar
Ok ill pm u when I get home and I can get that emailed to u. Its a cool vid. Ill chat with u later bro and sorry u have to waste ur time on deleting useless posts and garbage.
