Ams Evo Cam Test
Old Jun 10, 2008 | 09:30 AM
  #406
TURBevO8's Avatar
wow makes me love my HKS 272s even more! And it also suggests to me that my butt dyno was right on par with the chassis dyno used in these tests.
Those Kelford 272s look like a sweet *** set of cams though. Maybe someday...
Old Jun 10, 2008 | 09:45 AM
  #407
navysandsquid's Avatar
Me too WoOt!
http://www.youtube.com/watch?v=dSkDP_TUqSg
I love the Lope
Old Jun 10, 2008 | 10:28 AM
  #408
RyeLou's Avatar
Originally Posted by navysandsquid
Me too WoOt!
I love the Lope
You like your Kelfords on the stocker I take it?
Old Jun 10, 2008 | 10:33 AM
  #409
Ludikraut's Avatar
Wow, looks like the Kelford 272 cams are striking the best balance between spool and power.
l8r)
Old Jun 10, 2008 | 11:06 AM
  #410
Erik@MIL.SPEC's Avatar
To follow up Aby's point, the Kelford's look good power wise, but how are they at part throttle and with responsiveness in general?
Old Jun 10, 2008 | 12:30 PM
  #411
jbrown's Avatar
Awesome, now a whole bunch of people are going to go buy Kelford 272 cams for their cars which have different intake manifolds, different exhaust manifolds, different turbos, different bottom ends, and most importantly different head work from Martin's car. And all of this without any way to properly degree the cams in the first place.
Good Luck Fellas!
Old Jun 10, 2008 | 12:33 PM
  #412
Aby@MIL.SPEC's Avatar
wow- the kelfrds look the best. they are very similar to the oems down low & make the bacon up top.
anyone wanna buy some used cosi m2's?
Old Jun 10, 2008 | 12:44 PM
  #413
Big Boost's Avatar
Good Luck Fellas!
+ 100 very, very good point!!! Not that this testing is bad, but that you have to look at everything you have.....
Old Jun 10, 2008 | 12:58 PM
  #414
Exciting News's Avatar
Good Luck Fellas!
Or they'll go to Kelford's website and see they have a variety of cams for a variety of applications.
Although I now anticipate "Kelford ftw!" responses by clueless noobs to the unending "What are the best cams" threads...
Old Jun 10, 2008 | 01:24 PM
  #415
Ludikraut's Avatar
Good Luck Fellas!
Ummm, and this isn't a concern with any of the other cams available on the market?
At least in my case, I have an almost identical build to Martin's car, so most of the (educated or pure) guesswork has been eliminated for me.
I just looked at Kelford's website, and I like how they've laid out their cam selections, along with a simple description for each. And $624 for a custom cam grind? Nice!!!
l8r)
Old Jun 10, 2008 | 01:25 PM
  #416
turbo271's Avatar
Exactly why I wish someone started a thread on cams for a stock turbo with just standard bolt ons and a good tune.
For all we know all these cams could have completely opposite for a stock application. (Not really but you guys know what I mean)
Still, this is the best cam thread on here yet. Thanks AMS!
Old Jun 10, 2008 | 01:36 PM
  #417
jbrown's Avatar
Yeah, thanks tons for all he hard work Martin and AMS, I am appreciative, just hopeful people will have sense enough to temper the results based on the fact that their car may be COMPLETELY different.
Obviously the semi-conservative cams (HKS 272, BC Stage 2, FP4R, GSC S2) will be somewhat consistent, but the radical designs will vary tremendously on high HP builds.
Old Jun 10, 2008 | 01:56 PM
  #418
9sec9's Avatar
Looks like the FP5R's made more power up top over the Kelfords, but the Kelfords made better upper-midrange. 55=K+10, 60mph = K+5, 65mph=K+5, 70=K+4,
75=K+1, 80=FP+7, 85=FP+11, 90=FP+6. These are best guess numbers based on graphs.
added: Not sure if the start being 1.4 mph soonerstart helps the Kelford during the pre-spoolup or not, but the Kelfords look good down low if it doesn't.
Old Jun 10, 2008 | 02:16 PM
  #419
CamMan's Avatar
272 Cam test
Obviously the magazine and AMS can't build every setup to test, but in my view they have chosen a very common build.
When people are shopping for cams they really need to consult the engine builder, tuner and cam maker to get the correct choice.
The 272 of ours that Martin tested is the 8th iteration of our 272 degree EVO cam, (no one puts more effort into EVO cam R&D than we do) we decreased the seat to seat duration and added more area at higher lifts and this gave us the balance that we have been looking for (good idle, spool and top end)
Because of the low total duration it also works well with smaller turbos than what was tested here.
Big UP'S to Import Tuner mag and AMS for a very good job, and to Motovicity along with their dealer network for supporting our range of products.
Kevin Ban
Managing Director
Kelford Cams
New Zealand
Old Jun 10, 2008 | 02:38 PM
  #420
Ludikraut's Avatar
Kevin Ban
Managing Director
Kelford Cams
New Zealand
Kevin, being that I am in the market for a new set of cams, could you elaborate on the difference between your 272 and 280 cams for the Evo 8? Also how do your 272 cams compare to HKS 280 cams?
I am running the same setup as Martin, the only difference is that I am running a 50 trim turbo instead of the 35R. I am specifically interested in a road racing application ... in other words good power, but not so aggressive as to put excessive wear and tear on my valvetrain (supertech).
Thanks,
Markus
