AMS Dyno Graph, What Mod Would You Do Next?
Old Jun 5, 2008 | 07:11 PM
  #31
YzBrad99's Avatar
Originally Posted by mtevoracer
Congrats man alot of the numbers on here are guys tuned to the max. At AMS they tune your car with Safety in mind. In 5000 miles you can check your sparkplugs and they will look just like you put them in there. Enjoy that stock turbo. Get to the track and post times!
New Exedy Twin Disc and ill be right at the Drag Strip with timeslips posted also!
Old Jun 5, 2008 | 09:00 PM
  #32
hokiruu's Avatar
Whoever asked what the OP's actual use/motorsport goals for the car are deserves a cookie and thanks. Until then this thread was a great way to get grossly conflicting information.
I know you were pretty set on race gas, but if you are open to it: regarding fuel and the results you'll get from it for the money, I agree that E85 is one of your best options. With that in mind:
Of course the clutch like you said
1000-1200cc injectors
re-flash for both E85 and E70
maybe rod bolts
WB02 on board if you don't already have it, since in places like Chicago I am pretty sure they switch it to E70 in the Winter
Maybe one of the fuel content gauges some of us lucky ***** got from Serbia so you will be sure when to load the other map and turn the boost down a little
With only that little bit in mods, you'll probably see at least a 70whp increase on the DJ from the E85 tune, and have a pretty safe setup.
Old Jun 6, 2008 | 07:07 AM
  #33
Ludikraut's Avatar
Originally Posted by YzBrad99
My goals are having a 400whp car on AMS's dyno with 93 shell. Im thinking about getting the FP Green Ported 10.5 Turbo, Ported Exhaust Mani, Larger Injectors.
That's going to be a difficult target to hit. You might get close with:
- FPGreen @ 24psi
- 680cc (or similar) injectors
- GM 3 PORT boost control solenoid
- Tune boost using ECU (ditch the MBC)
- IndyEvo ported stock intake manifold
- WOT (aby@milspec) 65mm TB
- Buschur ported exhaust manifold
- AMS (headgames) ported head
Even with my buildup (AMS 3071, then 50 trim), it took a while to get to the 400 whp mark on AMS' dyno with a 93 octane tune. Granted, I've got a VIII, so it should be easier for you to get there, but it's not that easy on pump gas.
l8r)
Old Jun 6, 2008 | 12:41 PM
  #34
YzBrad99's Avatar
- FPGreen @ 24psi
l8r)
Oh i know its definately not going to be easy and cheap. I'm pretty much well prepared for that. The only thing i dont see me doing right now is the ported head because of the price ($2010.00). Its a bit outta my price range, i can afford the FP Green, Upper IC pipe, ported exhaust mani, injectors, retune. How much does those GM 3 ports run?
Old Jun 6, 2008 | 12:48 PM
  #35
turbo271's Avatar
I think I remember P&L Motorsports telling me its like $80 or something close.
Chukee_R
Mar 2, 2009 07:12 AM
YzBrad99
16
Apr 30, 2008 12:55 PM
YzBrad99
Sep 7, 2007 10:11 AM
YzBrad99
Aug 4, 2007 12:38 PM
