Forced Performance Evo Red Turbo data
Old Jul 20, 2008 | 02:32 PM
  #526
Levar's Avatar
Veteran: Army
FPRed...YES!
Absolutely subscribed!
I've read through this entire thread and like most of you I'm excited yet not ready to rush in guns blazing. I was one of those guys looking at getting the 76r for my upgraded option but then this FPRed came on the scene and changed everything. Regardless if it's on Joe's car or a built car, there's enough information out there to make an informed decision about the FPRed. I believe that if a person uses what's been working then it's a no-brainer. The problem (from nay-sayers) is when people try to duplicate efforts (sorry for the military talk) with knock-off parts or parts that haven't been proven or have a sub-par tuner and then make a post about how the FPRed is a bunch of hype. I do like the idea of being in the FPRed's sweet spot as I'm one of those 7200 RPM shifters myself.
Originally Posted by 9sec9
Trent's spoolup and ours appears to cross each other at 4500 RPMS. If that holds true, for our purposes, we actually gave up nothing to gain the topend of the manifold.
Where can I go to do some reading about the manifold?
Originally Posted by ForcedPerformance
I'll just come out and say it. Leave the BC272 cams in the boxes, dont bother. Same for HKS 264, HKS 272. They are all little puppy cams.
I've read and compared cams a lot once the AMS testing started. I'm going with the Kelford 272's once the FPRed gets to my door. My only question is do these require springs/retainers? Regardless if they do or not, I think having them would be good for comfort.
Old Jul 20, 2008 | 03:01 PM
  #527
Shacochis06's Avatar
^^you never know tho the Kelfords might be to aggressive of a cam for the red...only testing well tell
Old Jul 20, 2008 | 03:02 PM
  #528
03whitegsr's Avatar
The HTA wheels are CNC machined from a 2000 series Aluminum alloy, very tough, high strength material, even at 400F. Much stronger for instance than a 6000 series alloy.
BOOST ON!
Robert Young
What material is used in the Borg Warrner, Turbonetics, and PTE billet wheel turbochargers?
Old Jul 20, 2008 | 03:15 PM
  #529
Erik@MIL.SPEC's Avatar
If you can use Evo 8 Cosi M2's on a Green with good results, Kelford 272's or GSC S2's should be fine IMHO.
Old Jul 20, 2008 | 07:26 PM
  #530
SHIFTT IX MR's Avatar
This question has probably been asked, but what are the key differences between the FP EVO turbos(white, red, and green) ? For example, what are the Pros and Cons of each, and with what applications would each be better suited for.
Also, what are the flow rates of each turbo?
I have tried this search numerous times, no luck.
Thanks.
john
Old Jul 20, 2008 | 07:37 PM
  #531
Liqquid's Avatar
Thanks.
john
This thread may help you out
https://www.evolutionm.net/forums/sh...d.php?t=357576
Old Jul 20, 2008 | 07:38 PM
  #532
prostcj's Avatar
  #533
Liqquid's Avatar
Old Jul 20, 2008 | 07:40 PM
  #534
prostcj's Avatar
You beat me to it. Didn't take much of a search to find it.
Old Jul 20, 2008 | 07:56 PM
  #535
JKav's Avatar
Originally Posted by GrocMax
Well, maybe, but the OEM's ALL grind or mill that area for balancing.
...with a large-radius bit to avoid inducing stress risers.
Old Jul 20, 2008 | 08:00 PM
  #536
JKav's Avatar
Originally Posted by Talonboost
Now if these things are ground to final geometry, that is an operation I would like to see some video of. I've seen grinding of cylinders, spheres, flats, surfaces of revolution, and ruled surfaces, but I highly doubt that the final blade shape on this thing is all ruled surfaces.
Gary
The blade "faces" themselves are left as-cast. The shroud contour (the part of the wheel that dictates the running clearance to the housing) is ground, as are the bearing surfaces and (sometimes) the threads on the shaft.
Old Jul 20, 2008 | 08:06 PM
  #537
03whitegsr's Avatar
Why cast your logo into a part of the wheel that will never be seen and risk structural integrity?
It's probably a moot point, but just thought I would ask.
I've never seen the back of the wheel after grinding, but even if a large radius bit is used, unless it was a very fine surface finish, or an additional process used to reduce surface roughness, it would be creating stress risers anyway.
Old Jul 20, 2008 | 08:40 PM
  #538
JKav's Avatar
OEM wheels have a geometric balance band defined as part of the backdisk of the wheel, along with a minimum radius to the bit used to make the balance cuts. In volume production the balance cut is performed robotically.
Old Jul 21, 2008 | 10:24 AM
  #539
Talonboost's Avatar
If this is true, that the blade contours are used as cast, then I guess I would call it a cast wheel rather than a billet wheel. Then Jeremy was probably about right when he said "nobody ... mills turbine wheels out of a billet".
It's fine with me either way. I can see how it would be difficult and expensive to mill the blades out of a high temperature steel alloy. Much harder than milling compressor blades from an aluminum billet.
Gary
Old Jul 21, 2008 | 10:42 AM
  #540
tony gibson's Avatar
I'm gonna recant that after breaking a stock spring early saturday AM. No evidence of loft, bounce or surge but its obviously happening if a spring breaks. Keep the RPM's lower than we did with stock springs, cumulative spring surge effects over time will weaken them. I wanted to find the limits, and did.
How about 7500-8000rpm? Thats where I will be shifting depending on the gear.
