cam gear settings
Old Jul 31, 2013 | 01:40 AM
  #166
robin-evo6rs2's Avatar
2.0 long rod..
BR hta3582r kitt
S2 cams
Gsc beehive kit
Whats the timing for this?
Thanx
Old Jul 31, 2013 | 06:07 AM
  #167
Ted B's Avatar
0/0
Old Jul 31, 2013 | 06:37 AM
  #168
memphis raynes's Avatar
Built 2.0L
Ams v-band kit with PT 6466
HKS 272 cams
What shoul I be at?
Thanks!
Old Jul 31, 2013 | 06:43 AM
  #169
Ted B's Avatar
You need to be looking for a new cam/valvespring set, because the HKS 272s are not up to the task. Until then, try -2/-2, but it's of little use.
Old Jul 31, 2013 | 07:03 AM
  #170
I already have have supertech springs/retainers.. What cam would you recommend?
This is my daily driver with occasional trips to the track..
Thanks!
Old Jul 31, 2013 | 07:07 AM
  #171
Ted B's Avatar
GSC S2, straight up. In your situation, daily driving characteristics should not be compromised, and you should be able to find another 40-50whp(!) in the tuning.
Old Jul 31, 2013 | 07:20 AM
  #172
Dang bro! I am going to order a set today..
With the S2 cams, what should I be running on the cam gears?
Thanks!
Old Jul 31, 2013 | 07:33 AM
  #173
Ted B's Avatar
0/0 - straight up
Here's a worthwhile link:
https://www.evolutionm.net/forums/ev...ml#post5631514
With Martin's (AMS) car conservatively tuned at 418whp with factory cams, HKS 272 made 456whp - an increase of 9%. In comparison, the GSC S2s cranked out 484whp - an increase of almost 16%, while maintaining a good idle and sacrificing little down low.
Old Jul 31, 2013 | 09:38 AM
  #174
thanx
Old Jul 31, 2013 | 09:43 AM
  #175
EVO 4 life's Avatar
+1 thanks guys
Old Aug 1, 2013 | 02:47 AM
  #176
JSPturbo's Avatar
hello. For this cams:
http://www.briancrower.com/makes/mit...rd/bc_0114.pdf
which is the best combination?
2.0L Forged, BC Springs, 20g turbo.
Thanks!
Old Aug 1, 2013 | 05:46 AM
  #177
Ted B's Avatar
I can't help you with those cams. AMS found them not to agree with the published specs (see the link I posted above), so that makes adjustment a blind guess. What I can tell you is they did not make good power until they were adjusted. Sorry.
Old Aug 2, 2013 | 01:20 AM
  #178
DKC6691's Avatar
Cossworth Cam Settings?
What exhaust cam setting would you reccomend for my IX.
Here is my setup
Cosworth M2, Supertech dual valve springs, valves.
2.0 LR 685 HP 485 TQ
HTA 3582 T3 single scroll
Would I see any added spool if I retarded the exaust cam?
Do you think advancing the cam would net noticable horsepower?
Old Aug 2, 2013 | 06:53 AM
  #179
Ted B's Avatar
Cosworth's unwillingness to provide detailed cam specs (at least online) prevents you from getting a solid answer. Based upon what I know, the short duration of that exhaust cam lends reason to retard it by a degree or so, but only testing will provide an answer. Regardless, the MIVEC settings will have a greater impact on power.
Old Aug 19, 2013 | 01:13 AM
  #180
Vitamin's Avatar
I have hks 272 cams and hks camgears
3" exhaust from turbo,
walbro 255
hks mushroom filter
Evo9 turbo ( 49378-01571 )
Hks hardpipe intake
Evo9 Bov
Hks 272 cams and gears
New intercooler
ngk sparkplugs
My tuner setup the camgears for most hp
I think it is
intake is retarded 8* and your exhaust is advanced 4*
I make 371hp
Not to happy with that
What u think about my cam gear settings?
