Buschur Racing doing a start to finish EVO8 build, need input.
Old Jan 22, 2009 | 09:32 AM
  #106
leecavturbo's Avatar
the stock clutch is out of the question with wanting some decent go out of it.
great its almost settled then .stock ecu, stock frame, tarmac destroyer
altho i'd like to see it have turbo choices for short circuits/street or long circuits etc really loving the V band turbo and manifold items recently out that make turbo swapping childs play
Old Jan 22, 2009 | 09:35 AM
  #107
crcain's Avatar
Originally Posted by SloRice
Really...you think the push style exedy triple is easier to drive than a standard pull style exedy twin. hmm interesting info.
I'm not sure if it was the AMS hydraulic throw out bearing or the push style pressure plate that did it... but clutch pedal was much lighter. I had the HD twin before which had a pretty stiff pedal... I don't know what type of push style pressure plate AMS specs with their triple push conversion. Maybe a lighter clamping one?
But yeah the triple push was easier to slip and a bit less harsh engagement with lighter pedal feel than my twin HD. The triple was a good amount more noisy than the twin. But keep in mind I found the twin to be awesome and easy to drive. But the triple push was just a bit better.
Sorry for the OT. Looking forward to Buschur in 2009! Hoping for more testing threads which are always my favorite.
Old Jan 22, 2009 | 12:00 PM
  #108
DragNRacing's Avatar
I bought the Magnum with the intention of doing TA, but due to costs it was out of the question. I make more money than your average EVO owner and still can't afford to do it so that tells me the majority of other owners out there most likely cannot afford it either. When you factor in tires, fuel, and travel cost alone, it can easily be a $4000 weekend. Now if you break or worse crash, that number can skyrocket. I probably don't even have to mention our current economic factors which only add to that situation for most. So although road racing is the ultimate rush I have done in the car, it just isn't realistic for alot of us in my opinion. The alternative for me has been Solo (autox) and Rallycross (dirt/ice). It is not nearly as hard on a car and one can often get through a whole season on a set or two of tires and brake pads. Wheel bearings are probably the only other real common maintenance item I have seen. Having a fun car on the street is important too, so a class that allows a good amount of mods including those to the engine and turbo would be ideal since you also arleady stated that you plan to build the motor but keep a full interior. This would put you in the SM Solo class. This is the most popular mod class at our local region events and seems to be growing each year.
The Solo rules can be found here http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf. The Street Mod rules start on page 100 but build off some of the other class rules too. I remember you saying how much fun you had doing autox and these events are nationwide and even international for that matter with ghymkana. Rally would be cool too but not for a full interior car and the normal persons budget.
I definitely would like to see how a Buschur 2.3L would do with the BBK and E85 since you mentioned pump gas. I think this would be a great combination for the street and Solo too. If the engine ever expires in the Magnum, I would like to do the 2.3 with the planned BBK and Q16 for the XP class that I plan to compete in.
Old Jan 22, 2009 | 12:30 PM
  #109
Mellon Racing's Avatar
Originally Posted by psphinx81
david, i would love to see u build a monster on the stock ECU.
im pushing a lot of power on it, and hope to touch on 600whp this year. mellon obviously does it too. i would love to see u stay away from the AEM and push the limits on the stock ecu with us guys!
I think David said he's doing the stock ecu on the X this time around since it's been proven you can go pretty fast without the AEM EMS
Originally Posted by SpeeDeviL
Yeah your right about the head, intake manifold and the TB, I was like why not do something different, but why not with stock ecu, Mellon made 700whp on the stock ecu
that was 701awhp on DLL and I haven't hit the track yet. It went 10.41@135 when DLL said 600awhp previously on 93 octane. I think there's more than 700awhp in it, I haven't touched timing yet
Originally Posted by awdwannabe
just borrow mellon's car and paint it white.. lol j/k
No, but really this is something to look forward to. What about once you get your cores and everything.. just keep it stock??
Stock block and internals
Stock ported IM and TB
Stock ECU
Your new suspension, and just go from there.. basically a true stock blocked Evo, rather than a "built" evo. To show what the 4g63 is capable of for a real budget build. Of course an up-graded turbo.. fuel and all that, but just keep the heart of it as it came from the factory.
lol awd, now you're being silly but thanks for the laugh.
Old Jan 22, 2009 | 12:47 PM
  #110
bboypuertoroc's Avatar
Veteran: Army
Originally Posted by antilag_200
what I would like to see is something like this
take a 2.4 block, put a 1.6 turbo colt crank in it, making it a 1.8 liter destroker of doom, then massage your transmission to be able to shift at 12k. now you have an evo that would behave like an F1 car
Now THIS would be interesting.
Old Jan 22, 2009 | 12:58 PM
  #111
Dragracer187's Avatar
whatever it will be please use a twinscroll
Old Jan 22, 2009 | 01:11 PM
  #112
broeli's Avatar
I also think a Solo II SM built Evo would be a good idea. The typical Evo owner can relate to autox and an Evo modded at the SM level more than anything else.
Old Jan 22, 2009 | 01:32 PM
  #113
andrewzaragoza's Avatar
i'd say build a dd road race car.
br 2.3L
br stage3 head
272 cams
fp red / bbk full
stock ecu on pump
road race suspension setup.
Old Jan 22, 2009 | 01:56 PM
  #114
Lumpskie's Avatar
Originally Posted by LoKiEvo
Realistically I think you should make the car stay completely emissions legal. Show people that you can still go fast and follow the law. The car should keep all emissions components EGR, CAT, EVAP, etc. Also i think it should be done on a stock ECU.
I like this idea, with a budget cap... at least at the beginning. You could do a 10k cap, then maybe later raise the budget limit. Or you could just choose budget stages along the way. I also like the idea of a car designed for auto-x and HPDE type events... something you drive there and back again!
Old Jan 22, 2009 | 03:19 PM
  #115
rxw's Avatar
rxw
I'd like to see Buscher try some twinscroll stuff.
2.3, T4 TS HTA3582 with all the trimmings..... that would make a very nice street car IMHO.
Old Jan 22, 2009 | 03:29 PM
  #116
Johnboy1065's Avatar
^^^that's kinda like Ted B.'s setup...I've always thought Buschur was more a fan of the single scroll T3 setups...I could be wrong though...I have been wrong before lol
Old Jan 22, 2009 | 03:41 PM
  #117
vwjeff's Avatar
That is garbage... David wont do TS.
He has already stated what he will use.... things he has tested in the past and what he knows will work no?
Old Jan 22, 2009 | 03:50 PM
  #118
RLLN247's Avatar
I want to see an automatic !!! There I said it.
Old Jan 22, 2009 | 03:52 PM
  #119
rxw's Avatar
rxw
Settle down Jeff, I was only stating what I would like to see. If he doesn’t want to do/try its no skin off my nose, just another option.
Old Jan 22, 2009 | 04:04 PM
  #120
Guerillah's Avatar
build it with stock ecu and QUIET. Be sure it hauls *** too (10's).
