DIY Transmission Re-Build Tips
Old Oct 7, 2014 | 02:02 PM
  #181
Dave W.'s Avatar
Originally Posted by lopillo_evo
I took mine off and I'm thinking on taking it apart. The issue is that everytime I press the clutch while driving it makes a rattling noise. Any input on this? Could've been the clutch? It shifts smoothly while cruising no grinds or anything
I'd look at the clutch first, it's easy to take off since the trans is off. A rattling noise could be the springs in the clutch disc wearing down and coming loose. You can also easily check the trans input shaft for excess freeplay- try to move the shaft side to side and feel for any looseness. It should be tight but still spin freely when in neutral. You can also shift into all gears and spin the input shaft by hand while feeling for any roughness, clunking, or any unusual resistance. Check the TOB while you're in there.
Old Oct 7, 2014 | 07:09 PM
  #182
lopillo_evo's Avatar
Veteran: Army
Thanks Dave I will and let you know
Old Oct 10, 2014 | 08:41 AM
  #183
scheka's Avatar
Hi, have a evo 6 5speed tranny now. Does the timken bearing fit on it? And whats about preload? 0.10 still perfekt? Want to rebuild complete with synchrotech carbon synchros
Old Oct 11, 2014 | 10:53 PM
  #184
Veteran: Army
Dave so I inspected the input shaft and there is no play whatso ever, it spins freely little bit of noise but is dry, gears pop good and smooth. I didn't check the tob and I'm not too worried about because I bought a hob with a quatermaster clutch I know is noisy I've driven my buddy's Evo which was he's clutch btw and I love it don't mimd the chatter neither the dog barking sound every time you take off lol
Old Nov 29, 2014 | 02:51 AM
  #185
scheka's Avatar
Hi,
can somebody tell me where i can buy the timken traped roller bearings?
greetings from germany
Old Dec 1, 2014 | 08:30 AM
  #186
elhalisf's Avatar
Originally Posted by scheka
Hi,
amazon is a great place to buy them from.
Old Dec 23, 2014 | 10:32 AM
  #187
xteekayx's Avatar
This is a great thread, i just dropped off my 6-spd to a local shop, i highly doubt he will check any clearances ...
I guess i'll have to gear up for the next rebuild :/... is there a thread like this one but that solely concentrates on the 6-spd transmission for any tips and tricks? I searched but i did not find anything, it seems like everyone switches over to 5-spd. I would love to keep my 6-spd but make it better ...
elhalisf - can you start a thread regarding a 6-spd? hehe, seems like you have a sense of what you are talking about
Old Dec 25, 2014 | 10:56 AM
  #188
kaj's Avatar
kaj
Shep is doing them again. also, a few of us are building trans coolers. i think that's going to be the most help.
Old Dec 25, 2014 | 12:03 PM
  #189
Dave W.'s Avatar
+1 on trans cooler for the 6 speed. Do it right with a pump and filter.
+1 on sending it out. If you try to DIY a 6 speed rebuild you're just asking for trouble. They're more difficult than the 5 speed and the spacer tolerances are different than the 5 speed.
Old Dec 25, 2014 | 01:50 PM
  #190
kikiturbo's Avatar
went trough a 6spd rebuild and it is not tricky at all... however the availability of parts is questionable...
+1 on the cooler ..
Old Dec 26, 2014 | 07:22 AM
  #191
xteekayx's Avatar
Awesome, great to hear that! Do you have any pictures with any tips and suggestions? Does anyone have the manual for the 6-spd?
I build engines as a hobby, i doubt i can't tackle 6-spd evo tranny when i had done the getrag 6 spd tranny out of a 3000gt vr4 before. Just need the right info and the manual ...
+1 on the cooler ..
Old Dec 26, 2014 | 07:28 AM
  #192
xteekayx's Avatar
Also, do you have any links to diy pump and cooler set up for the 6spd?
+1 on the cooler ..
Old Dec 28, 2014 | 08:18 AM
  #193
kaj's Avatar
kaj
isn't it part of the service manual? i honestly haven't looked LOL
Old Mar 1, 2015 | 08:30 AM
  #194
flabber's Avatar
tranny info
Bumping an old topic here ,but it will help future guest
did u guys install tapered roll bearings on the inout shaft only or was it bith input and output put shafts .
iam goin to tackle this gob soon ,so teying to as much research as possible.
Old Mar 1, 2015 | 02:21 PM
  #195
elhalisf's Avatar
output shaft already has tapered bearings, so just the input shaft.
