help me decide! FP RED or Twin-scroll hta
Old Aug 15, 2009 | 12:48 AM
  #61
William254's Avatar
thats how we do work!!!
Old Aug 15, 2009 | 12:50 AM
  #62
nikkadanny's Avatar
Originally Posted by William254
nikkadanny,is it twin scroll
lol my fault..
Old Aug 15, 2009 | 12:51 AM
  #63
ASAPPerformance's Avatar
still here, just very sleepy....good night evom late night crew
Old Aug 15, 2009 | 04:24 AM
  #64
riceball777's Avatar
fullrace HTA t4 twin scrool 35r is the only way to go. 20psi by 4k rpm on the stock motor. amazing power with faster spool than a standard single scrool 30r kit.
Old Aug 15, 2009 | 04:59 AM
  #65
Mellon Racing's Avatar
I'd like to try a TS 35R kit...I haven't seen anyone really push it hard yet.
Old Aug 15, 2009 | 11:29 AM
  #66
bolio's Avatar
Same here, after years of these kits being out, I still haven't seen a trap speed on a T4 TS35r to prove up-top power and compare to the T3 drag monsters, just some dynos.
Old Aug 15, 2009 | 12:08 PM
  #67
slowr_evo's Avatar
x2
Old Aug 15, 2009 | 09:36 PM
  #68
William254's Avatar
me to well mellon if it all works out.... u'll get ur chance!
Old Aug 16, 2009 | 06:31 AM
  #69
cij911's Avatar
Riceball -- Why would you get a TS35 and only run 22 psi ?? I know you'd have a much faster car with a more stock like turbo...You're only making 350 ft lbs (at the hubs) at 5500, whereas I am making more at 3800 rpm....I don't think your setup sells the TS35 route, I'd go with a Red...
Old Aug 16, 2009 | 07:03 AM
  #70
btownsoccer22's Avatar
Originally Posted by cij911
Riceball -- Why would you get a TS35 and only run 22 psi ?? I know you'd have a much faster car with a more stock like turbo...You're only making 350 ft lbs (at the hubs) at 5500, whereas I am making more at 3800 rpm....I don't think your setup sells the TS route, I'd go with a Red...
Would also like to know to. But can you run more then 22psi on 91 octane?
Old Aug 16, 2009 | 07:06 AM
  #71
cij911's Avatar
^^ I am in Cali too and my point is if you're not going to run higher boost, there are much better street turbos than a TS35....The kit is gorgeous, but would really shine on 30+ psi...So for me, if I were only going to run 22psi, I'd go with a much smaller turbo and get a much broader power curve.
Old Aug 16, 2009 | 10:54 AM
  #72
CoMoEvo's Avatar
are you gonna be running a stock 2.0L outside of cams?? i would definitely consider the power levels of the fp red, cheaper in price, compared to the hta twin scroll 35r.. yes the 35r will beat the evored in numbers, top end power, with the sacrafice of a lil' more lag on the 35r.
i think you need to consider the consequences of both set ups on your motor/ drivetrain especially if this car is a daily driver.
^this into consideration, i would opt for the evored.. just my $0.02
Old Aug 16, 2009 | 02:28 PM
  #73
RockmanX's Avatar
Ported Fp Red + 2.3 Motor+ basic bolt on = Street demon
Nuff said
Old Aug 16, 2009 | 02:32 PM
  #74
William254's Avatar
im considereing red still with a full race mani,kelford 272s,crower springs/retainers,e85...
rockman i kno thats a good setup, i read a thread about that on here,,, it was called like ultimate street monster or some crap but i am on STOCK 2.0!!! not 2.3L i will not stroke it for a long time so on a stock internal 2.0L on E85 whats better???
Old Aug 16, 2009 | 06:27 PM
  #75
William254's Avatar
bump for more info on red and twin scroll still cant decide...
