Clutch not engaging or broken trans
Old Sep 22, 2009 | 01:58 PM
TheMadScientist's Avatar
Alright so I was out practicing launching the other night and went to launch and the car did nothing went nowhere.
I can put the car in gear and start it. The car is in gear and doesn't move. I can shift to second without using the clutch while the car is running and the car does nothing. If I rev it up in like third I can very faintly here something moving and in fifith what ever it is, is moving faster. However the car still seems to shift fine and there are no grinds going in to the gears and I still have pedal pressure. It's very confusing help me out guys. Thanks.
Also the clutch is a RPS twin carbon
Old Sep 22, 2009 | 02:03 PM
evoix16's Avatar
I would have to say clutch or tob
Old Sep 22, 2009 | 04:40 PM
bambooi's Avatar
It sounds like to me the clutch is not engaging and somehow it is stuck disengaged especially if you can shift while the car is on without using the clutch.
Old Sep 22, 2009 | 10:08 PM
Need help!!!
The only thing about the clutch not engaging is why? I still have strong pedal pressure. I just can't figure it out. I'll have to drop the tranny I guess.
Old Sep 22, 2009 | 10:11 PM
xspsi4's Avatar
sounds like the tob.
Old Sep 22, 2009 | 10:21 PM
mr-derer2's Avatar
TOB popped off. this happens. turbotrix has a fix for this problem. i have it on my car and never had a problem. its like $190 installed.
Old Sep 24, 2009 | 01:33 PM
I thought if the TOB popped off or if the clip broke, the clutch wouldn't disengage. Currently the clutch won't engage. I can shift through all the gears without the clutch pushed in while the car is running and the car goes nowhere.
Old Sep 24, 2009 | 03:06 PM
sho669's Avatar
thats how mine was when i blew the t-case...grinding noise was fairly noisy in all gears though. easy enough to check the t/o bearing though just look through the boot on the trans.
Old Sep 25, 2009 | 05:42 PM
AF-Evo8's Avatar
the clutch is stuck in the engaged position, and since you were launching its possible that you heated it up enough to fuse the clutch to the flywheel so to speak
Old Sep 26, 2009 | 11:13 AM
THUB's Avatar
I thought that if you still had pedal pressure, the clutch clip was still there. It sounds to me like he's getting rpm to go through the trans properly, except something behind it isn't putting power to the wheels. (t-case)
FX11
31
Feb 12, 2019 08:54 PM
mrmiller
Mar 14, 2016 04:06 AM
Harumsevo
Jul 30, 2013 05:19 PM
RaysEvoX
Nov 7, 2009 03:34 PM
AlainD
17
Apr 29, 2009 03:21 PM
