MAPerformance BS
The EXEDY does not look blown. It does look about 4 months used though.
Maybe he popped his TOB clip, could not get the part by itself so ordered a new one and swapped the discs and floater out.
This sounds pretty likely.
Is there any part# stamped on each clutch? is this part# also printed on the box? Maybe MAP has the clutch's part# so it can be compared to what he got. I know that would help MAP prove they are legit. On another note, even though it is very unlikely, it could be that some fedex employee owns an evo, saw the EXEDY box (pretty obvious) and swaped it with a clutch he had lying at home.... very unlikely I know, but we have to look at this situation from all possible angles guys.
MAP should be cleared of any wrong doing.
all i am hearing is "quack quack quack"
No one can explain the used/missing parts
Blew his clutch in May, and tells us he had his stocker still in it. Almost 5 months driving on a blown clutch? No way.
Circumstantial albeit, but it explains a lot more than what I have read in this thread.
Ever seen what Fed Ex and UPS guys have to go through before they leave work?
At some one trying to hide a clutch under their shirt!
In one of his posts he says he blew the stocker, then went to mitsu to get a new OEM clutch, at least that is what I understood, maybe he can prove this, I mean he must show proof that he got an OEM clutch installed after may, that should help him.
I have never dealt with MAP, but from reading a bit I can tell they are a great company, and I will do bussiness with them should the opportunity arise.
that is impossible, so nevermind about the whole Fedex being at foult
