How much power will my setup make [Mega Merge]
Old Jun 14, 2010 | 01:38 PM
  #301
Hardware's Avatar
Originally Posted by leonevox
400 on a mustang are tough to get with fpred and pump gas. Even with larger fmic and testpipe, u should net around 350 on mustang.
Thanks guys for the replies. I don't mean no disrespect Leon, but I hope you are wrong. If I get a 7hp increase from spending another $1600 I'm going to be pissed. haha. Only time will tell.
Old Jun 15, 2010 | 02:42 AM
  #302
Total D's Avatar
Hey guys, Im currently in Iraq deployed with the military. Its been years since I've been on but this is in the works as we speak. Suppose to be complete in September for when I get back home for 2 weeks before I ship off for the remaining of my deployment. Got to have her done for my trip from Louisiana to Atlanta, Ga. for the Petite Le Mans event. Not driving in the event just go to watch it lol.
Here is my setup....;p
Head:
Supertech full valvetrain, stock valves
new valve stem seals
brian crower 272 cams
Block:
Stock
Fuel:
Walbro x3
1600c injectors
Resistor box
SS lines and fittings
Aeromotive FPR
Dual feed fuel rail with center return
Turbo:
BW S374R 1.10 AR, 83MM turbine wheel, Race cover
Twin gated, divided manifold
38mm turbosmart wastegate x2
Sard Racing BOV x2
4" full turbo back exhaust.
Engine management:
AEM V1
5bar map
Iat
HKS DLI
HKS EVC5
Well be good to come and learn more since lots of things changed since I left the community. Well Hope you guys take care and see some of you when I get back in the states.
JJ
Old Jun 17, 2010 | 07:27 AM
  #303
Hardware's Avatar
Head:
Block:
Stock
Fuel:
Walbro x3
1600c injectors
Resistor box
Aeromotive FPR
Turbo:
Sard Racing BOV x2
Engine management:
AEM V1
5bar map
Iat
HKS DLI
HKS EVC5
JJ
Thanks for Serving bud. Looks like a nice build, but I can't give input on what you should put down.
Old Jun 17, 2010 | 07:38 AM
  #304
stryfetew's Avatar
Should make some good numbers I'd say high 400s 500s.. You are going to be limited with BC 272 cams though, i'd swap them out for either Kelfords or GSC S2s
Old Jun 17, 2010 | 08:08 AM
  #305
leonevox's Avatar
Head:
Block:
Stock
Fuel:
Walbro x3
1600c injectors
Resistor box
Aeromotive FPR
Turbo:
Sard Racing BOV x2
Engine management:
AEM V1
5bar map
Iat
HKS DLI
HKS EVC5
JJ
look like your setup will be on e85 with 3 walbros. I would say u will be around 450-550whp dynojet, depending on boost level. Switching to gsc and kelford also help.
Old Jun 17, 2010 | 08:59 AM
  #306
BLKCarbonEVO's Avatar
Why are you running 3x 255s? You would be just fine with 2. Also I don't know that much about BW turbos... How many lbs a min is it rated for? You will be limited with your cams and the stock block. You prob won't be over 550.
Mikey
Old Jun 17, 2010 | 09:53 AM
  #307
leonevox's Avatar
1 inline and a double pumper i quess. How many horses are u trying to get bro? Is this a bulleyes turbo? Heard they are pretty efficient.
Old Jun 17, 2010 | 11:43 AM
  #308
05VIII's Avatar
what do you guys think i can make?
hta3582
1250 bluemax
double pumper
hks 272's
bc valve springs
ams front mount
ets upper and lower piping
full 3inch turbo back with test pipe
stock block
stock ecu
what will it make on 93?
what will it make on e85?
Old Jun 17, 2010 | 10:08 PM
  #309
05VIII's Avatar
bump
Old Jun 17, 2010 | 10:17 PM
  #310
RockmanX's Avatar
hta3582
1250 bluemax
double pumper
hks 272's
bc valve springs
ams front mount
stock block
stock ecu
all other bolt ons? how much psi?
Old Jun 18, 2010 | 06:05 AM
  #311
05VIII's Avatar
what other boltons? i cant seem to think of anything else for power??
im running 28psi rite now on 93, what should it be making around that psi? on a mustang dyno it read 365? seems really low to me
im not sure what psi i will run on e85, what do yall recommend? how much power increase will it be switching to e85?
oh yeah, im running sparktech COP non cdi
Old Jun 18, 2010 | 07:22 AM
  #312
Mellon Racing's Avatar
hta3582
1250 bluemax
double pumper
hks 272's
bc valve springs
ams front mount
stock block
stock ecu
on a dynojet my customers typically see 475-525 on a 35R with 93 octane and your basic mods with e85 550-600 (enough to break a rod if you don't keep torque in check)
stingy mustang dyno numbers would be significantly less.
Old Jun 18, 2010 | 08:46 AM
  #313
RockmanX's Avatar
there you go HOW GOES YOUR CAR MELLON?
Old Jun 18, 2010 | 11:43 AM
  #314
the engine is ready to ship to me, they just need to build a crate and I need to come up off the wallet
Old Jun 18, 2010 | 02:35 PM
  #315
RockmanX's Avatar
pm me details about it price whats changed etc im interested
