How much power will my setup make [Mega Merge]
Old Aug 1, 2010 | 12:09 PM
  #391
RockmanX's Avatar
Originally Posted by Insanity Evo
Hmmm, if I were to get a larger intake plenum like say...a magnus intake manifold, wouldn't this add to hp and reduce tq? Maybe a good solution to the whole torque issue? haha
no mangus intake is one of the best intake manifolds nope. your tuner is going to keep your safe i hope but again you will hit the tq wall before you know it with a black. you should beable to clear 500 barely but again anything over 420tq your playing with fire. Have people gotten more SURE but they know the risk and are prepared to buy anew block the secon they shoot a rod . I dont play childrens games well so i went built block i dont have time to be tip toeing around the issue of that i rather tune what whatever they can pull on my current oct level
Old Aug 2, 2010 | 05:19 AM
  #392
FJF's Avatar
FJF
Originally Posted by FJF
OK, guys, I want to play. How much power will I make and where?
My car - IX with TBE (w/HFC), MBC, Buschur FMIC, and tune
Without installing any additional parts, sans a fuel pump and injectors, how much power will the car make with a BBK Lite, a BBK Full, and a HTA Green? Just as importantly, where will the power be made and which setup will have the better transient response? Thanks!
No one wants to take an educated shot as to the gains on 93? I've looked at all posted dynographs, prorated the results, and I'm love to hear from the forum. What do you guys think?
Old Aug 2, 2010 | 05:38 AM
  #393
BLKCarbonEVO's Avatar
Yes, the Magnus v5 will def help you hit a higher hp number while helping to keep your tq numbers tolerable on the stock motor. I would tune to about 420-430tq and whatever hp you make is what you make. A good rule of thumb is to keep your boost around 30psi and timing 14-16* depending on fuel. You don't want to run crazy boost because the tq will start to climb faster over 30psi and keeping the timing low will help reduce the cylinder pressure. All of that = healthy rods
On my car, when we put on the Magnus v5 I was able to to make an extra 20+hp while keeping the tq levels the same as it was with the stock manifold. Once you start turning up the boost, when you get a built engine, the Magnus will really start to shine! Out of all the mods on my car, the Magnus is one of the best mods I have found. If you have a good set of cams (ie GSC S2s), Magnus v5, and an 02 dump you will make loads of power. I made 540hp/430tq on the stock motor with my FP Red on pump+meth. With a proper setup you should be able to see 560/430 on the black with proper fuel
Good Luck!
Mikey
Old Aug 2, 2010 | 05:43 AM
  #394
gsrboi80's Avatar
On the Stock injectors and OEM fuel pump you'll have to keep the boost and RPM down. Obviously those turbos flow more than the stocker and hold better boost as well. You'll def start to lean out on the top end
Might gain 20 hp with any of them if I had to guess but you'll def be limited
Old Aug 2, 2010 | 05:49 AM
  #395
FJF's Avatar
FJF
Sorry, I should have explained it better; the fuel system would be ungraded, but everything else stays the same.
Old Aug 2, 2010 | 06:49 AM
  #396
gsrboi80's Avatar
I don't see another 50-60hp out of the question on pump from either the Full or the HTA Green with a solid tune. The Lite will probably end up short of that.
That HFC might hold ya back from the closer to 400whp depending on which one it is but nothing wrong with being GREEN .
Old Aug 2, 2010 | 09:39 AM
  #397
FJF's Avatar
FJF
Thanks! A few more questions:
I think we can deduce with some measure of safety that the Lite would have the least lag, but would it have the better transient response, as well? What about the powerband? Does the Full gain on the Lite all only at the higher revs (ie. +6K) or is there a befit through the range? How does the HTA Green figure into all this? What are the actual differences in spool?
Old Aug 18, 2010 | 06:07 PM
  #398
Real X's Avatar
Hey guys, new on here.. Don't slaughter me lol.. Trying to do some research on Evo 9's as I am possibly looking to buy one.
How much power do stock turbo/Intake/TBE/tuned evo 9's make?
What kind of setup would it take to make 400whp reliably for a daily driver?
Old Aug 18, 2010 | 06:12 PM
  #399
xcelr8's Avatar
^^^search harder!!! Joking
probably with 23lbs on pump dynojet Im thinking 330whp
Old Aug 18, 2010 | 06:19 PM
  #400
Real X's Avatar
thanks man lol
What's the most popular setup for 400whp?
There's just so much aftermarket and so many different setup's I'm seeing so Idk what is reliable and what has worked well lol
Old Aug 18, 2010 | 07:31 PM
  #401
xcelr8's Avatar
buy a fp red or black and you should be able to hit that marker on pump. You ll also need bigger fuel infectors,
Old Aug 19, 2010 | 01:35 PM
  #402
Mellon Racing's Avatar
Red would be the easiest way to get there without spending too much and keeping spool nice
Old Aug 23, 2010 | 11:25 PM
  #403
jnebs's Avatar
2006 evo ix mr
Cbrd bbk full
tbe
cai
licp
uicp
ams 3in fmic
1000cc injectors
walbro fuel pump
forge rs bov
gsc s2 cams
beehive springs and retainers
ported intake manifold
gt spec exhaust manifold
on 93 octane
What horsepower and tq do you think i would be around. I just want some rough numbers. I will be pushing 380 whp without the bbk full. Wondering if i went with the bbk where i would be thanks.
Old Aug 26, 2010 | 03:08 AM
  #404
Betty's Avatar
2005 Evo VIII
TBE
RC 1000CC
255 fuel pump
LICP
Intake
E85
Getting tuned soon, this will be my first tune and just wanted a rough estimate. Thanks!
Old Aug 26, 2010 | 08:53 AM
  #405
Originally Posted by Betty
2005 Evo VIII
TBE
RC 1000CC
255 fuel pump
LICP
Intake
E85
375 would be a good goal
