How much power will my setup make [Mega Merge]
Old Jul 11, 2011 | 10:18 PM
  #781
tscompusa2's Avatar
Originally Posted by marcusE
tscomp, just wanted to say THANK you in advance. I stumbled upon some of your youtube videos reguarding Cold E85 start ups with built 2.3 and also catch can information. Thanks for being informative and able to help others with their 8's and 9's. I'm new to the 4g63 and cant wait to get started on the route to 400-500whp numbers.
no problem glad they are helping some people. i wanted to upload a better one but it was to long for youtube, so i have to chop it up and upload it in pieces, which i didnt get a chance to do yet.
Old Jul 11, 2011 | 10:28 PM
  #782
RallyBud's Avatar
Originally Posted by RallyBud
2006 Evo MR: Duel MAP E85 / 91 tune
Will be tuned for 29 and 24 lbs of boost respectively.
AEM Intake system
AMS Large Front Mount Intercooler
AMS LICP
AMS UICP
AMS Turboback Exhaust
Invidea o2 Housing
H.O.A. Imports 3 Port Boost Solenoid
Synapse Synchronic DV
PTE 1200cc Injectors
Walbro 255lph High output fuel pump
I would appreciate any guesses. Thanks!
Rick
Bump. I'll know the answer here in a month. But, "thought" someone may have a guess??
Old Jul 11, 2011 | 10:46 PM
  #783
tscompusa2's Avatar
should be about 400 on e85 with the evo 9 turbo even with the stock cams on e85 as long as the weather permits it.
on 91 im not sure, maybe 360-370ish?
a healthy evo 8 running 93oct with hks 272, piping, bov, pump, intake, exhaust can put down 350-360whp.. so you figure the evo 9 turbo is what a good 7lb/min bigger then the evo 8 turbo? that alone is good for 50whp over just in turbo alone.
Last edited by tscompusa2; Jul 11, 2011 at 11:21 PM. Reason: forgot to list oct rating
Old Jul 11, 2011 | 11:24 PM
  #784
tscompusa2's Avatar
Originally Posted by 1evo2h8
Br 2.0 longblock
ETS 3586
2120 fic
BR double pumper
BR race fmic
Sparktech ignition
Kelford 272
1 bad *** tuner.
Let's sum it up and just say all supporting mods.
Just a guess would be cool.
e85? should crack over 650 even in tx heat on a dynojet if the setup is bottleneck free.
btw you mean fic 2150, no such thing as 2120
Old Jul 14, 2011 | 05:50 PM
  #785
lonestarevo83's Avatar
Jam 2.3 stage 2 longblock
Eagle crank
H beam Manley rods
Wiseco tough skirt pistons
acl bearings
arp girdle mains
arp rod bolts
hot tanked
jet coated
Balanced and Blueprinted
stock compression
Jam rebuild head stock everything except hks 272's ( bought it from a guy this way, I would have got the P&P while being built)
AMS VSR Intake manifold
Boomba TB
GT3582 BB
AMS 3.5 front mount
AMS licp
AMS uicp
Spoolin up COP
Kracka Crankcase valves
HKS 3"Exhaust
Aeromotive stealth 340lph
Aeromotive FPR
FIC 2150's
Aeromotive fuel rail
Want a map switch tune for e85 and 93...
Next step is transmission and driveline..
Shep tranny
upgraded t case
rear diff
and already have a twin disk exedy..
Please any suggestion on a better setup would be great. New to the game so trying to get as much knowledge as I can..
thanks
JRP
Old Jul 14, 2011 | 09:32 PM
  #786
tscompusa2's Avatar
Eagle crank
H beam Manley rods
acl bearings
arp girdle mains
arp rod bolts
hot tanked
jet coated
stock compression
Boomba TB
GT3582 BB
AMS 3.5 front mount
AMS licp
AMS uicp
Spoolin up COP
HKS 3"Exhaust
Aeromotive FPR
FIC 2150's
Shep tranny
upgraded t case
rear diff
thanks
JRP
over 500 on 93 and over 600 on e85 is what you should expect on a dynojet.
if you dont have a programmer cable you should invest in one along with evoscan. send me a pm or email and i can get you them both for cheap or click on the red link in my signature or send me an email.
that PUMP is not gonna support full potential on e85 not even close id get the buschur double pumper. for clutch exedy twin hd is fine.
cams id look at gsc s2, kelford 272, fp5r, etc
Old Jul 21, 2011 | 01:23 PM
  #787
evo8FnF's Avatar
What numbers will this set-up gets me on a Mustang Dyno or DynoJet?
2005 EVO 8 GSR (stock turbo & injectors)
Perrin intake kit
Cobb downpipe & catback
Megan testpipe
Helix O2 housing
Ported OEM exhaust manifold
Walbro 255
AGP LICP
3port EBCS
tuned to 23~24psi on 93 octane
Old Jul 26, 2011 | 11:10 AM
  #788
Rough_draft's Avatar
heres my simple setup wondering what i should be knocking at
03 evo viii
hallman mbc at 24psi
turbo xs uicp/licp
turbo xs front mount
bc 272
turbo xs 3" tbe
stock inj
stock pump (to my knowledge)
i know i couldve went with "better" cams but i couldnt pass on the price
Old Jul 26, 2011 | 12:01 PM
  #789
Mellon Racing's Avatar
350+ on 93 octane or equivalent or as much as 400 on race gas/e85 and high boost
03 evo viii
turbo xs uicp/licp
bc 272
turbo xs 3" tbe
stock inj
Old Jul 27, 2011 | 03:35 AM
  #790
2hot2handle's Avatar
Stock 10.5
GST open element cone filter
Tanabe DP
UR TP
Apexi Gt Spec Exhaust
APS BOV
Ported o2 & mani
HKS Step 2 Cams
Aeromotive FP
FIC 1250's
AEM Gears
ETS IC
ETS Lower IC pipe
ECU boost control to about 24psi
CA 91 octane. NO E85........... yet.
Old Jul 27, 2011 | 03:53 AM
  #791
Sirnixalot's Avatar
Here is a bastard setup for my Evo3
2.3L 8.5:1 CR
Mild head work (3angle valve job, port match, bowl blend, full OEM Evo 8 valve train)
HKS 272* 10.3mm lift intake and 264* 9.8mm lift exhaust cams
Custom short runner twin scroll manifold
Evo X turbo with 20g compressor side
Custom 3" intake with K&N filter
24x12x3.5 AGP race bar and plate intercooler with 2.5" piping
3" TBE with divorced wastegate 1.75" dump tube
FIC 750's
Walbro 255
Evo 8 ecu conversion
what are the odds on getting 400whp on 93oct?
Old Aug 4, 2011 | 09:06 PM
  #792
BlackOpsEvo's Avatar
Registered User
Here's my future set up:
Evo 9
FP Black
Kelford 272's
FIC 1680s
BR Double Pumper
FP Intake
BR TBE w/HFC
Stock MAF, Stock ECU
Stock block
3 Port bcs
e85/91oct
Anyone know what my #s will be? Mustang dyno, 1/4 mile time, 1/8 mile time?
Old Aug 8, 2011 | 09:25 AM
  #793
oldskoopimpn's Avatar
Ok got a few more things:
ETS intake kit
ETS LICP V2
Hallman pro RX
Walbro 255
HKS Crarbon TI exhaust
test pipe
AMS downpipe
FIC 1450 bluemax's (Thanks Mellon)
Tuned on 92 and E-85
Thanks in advance
Old Aug 9, 2011 | 01:23 AM
  #794
Registered User
Bump for meeee!
Old Aug 9, 2011 | 11:06 PM
  #795
EVILutionVIII's Avatar
Veteran: Air Force
Looking to get a rough power estimate:
Buschur 2.3, 10:1
Crower springs/retainers
HKS 7460R
Buschur FMIC
U/LICP
Intake
Megan exhaust manifold and O2 housing
HKS 272s
AEM cam gears
GReddy TBE w/ cat delete
Precision 880s
Walbro 255
JDM Map
Grimspeed BCS
Stock MAF and ECU
93 Pump
