How much power will my setup make [Mega Merge]
Old Sep 26, 2013 | 10:15 PM
  #1066
JaYr_EvO9's Avatar
Originally Posted by JohnBradley
lol
Old Oct 2, 2013 | 11:38 AM
  #1067
evo_yoshi15's Avatar
Waz Guys I Was Wondering The Same Question As Everyone I'm JsT Trying To Get An Idea FOr My 1St Basic Tune This Is Wat I'm Running And I Plan To Run DuaL Map
Injen Upper/Lower Piping
Invidia Catback
Rre Test Pipe
Turbo Xs Downpipe
1000Cc Injectors
Evo 9 Bov
Evo 8 Turbo
02 Dump
Buscher Fmic 3.5
Old Oct 3, 2013 | 10:27 AM
  #1068
timasse's Avatar
Hello can you guys give me an idea of how much hp/whp I will make once i buy and install all these mods?
What I bought for my car so far:
- Cold air intake aem with K&N "shroom"
- Glowshift pillar pod
- Prosport boost gauge
- Prosport Oil pressure gauge
- Swift Spec R Springs
What I plan to buy for the car:
- Wideband + sensor
- Electronic boost controler
- MAP Sensor
- Cable Tactrix
- Evoscan
- O2 housing + downpipe
- Cat back full exhaust
- Gaz pump
- Ets intercooler kit
- Injectors
- Cams
- Tune
Not sure about cams and injectors
Old Oct 3, 2013 | 11:01 AM
  #1069
Raptord's Avatar
- Wideband + sensor
- MAP Sensor
- Cable Tactrix
- Evoscan
- Gaz pump
- Injectors
- Cams
- Tune
Assuming 91 oct pump gas, I'd guess 330-340 dynojet.
Old Oct 5, 2013 | 10:03 AM
  #1070
ReaperX's Avatar
Well I guess I will play this game once.
Mods at current power level: 328 VD / 335 Dynojet
Perrin filter w/ Maf Adapter
Aeromotive Stealth 320lph Fuel Pump
FIC 950cc Injectors
Megan DP, TP, CB
ETS LP2 LICP
EVO IX DV
Grimmspeed 3-Port
E-85 @ 25psi peak Stock 9.8 Turbo
5* timing @ 5k, 14* timing @ 7500
New Mods:
GSC s2's w/ springs and retainers
ARP Headstuds
What range should this put me in?
Old Oct 7, 2013 | 08:16 PM
  #1071
SSMCL9's Avatar
ARP head studs
BC valves, springs, retainer
Kelford 272
ATP stg 3 turbo kit
3 turbo back
greddy fmic
what whp would i get after a tune with the fic injectors and with out?
AEM EMS S2
walboro 255
stock injectors / FIC 1050 ( not installed)
Old Oct 14, 2013 | 04:45 AM
  #1072
LaurenBBY's Avatar
HKS Hi-Power Exhaust straight piped/no cat
K&N Typhoon Intake
Walbro Fuel Pump
HKS BOV
Stock Evo 9 Turbo
ARP Head Studs
272 Cams
1200cc Injectors
Manual Boost Controller on 28 psi
E85 gasoline
Old Oct 18, 2013 | 07:57 PM
  #1073
SSMCL9's Avatar
No one?
Old Oct 18, 2013 | 08:26 PM
  #1074
detroit pistins's Avatar
Originally Posted by SSMCL9
ARP head studs
Kelford 272
ATP stg 3 turbo kit
3 turbo back
greddy fmic
AEM EMS S2
walboro 255
What size turbo is included in their "stg 3"... what boost and fuel will u run?
side notes:
-aem standalone wont make u more power
-bigger fuel pump and injectors will help support the additional air you will be pushing but that depends on how much boost you 're planning on running.
-I had BC valve springs at some point and they broke ... almost cost me my build so I wont recommend them.
Old Oct 18, 2013 | 08:27 PM
  #1075
K&N Typhoon Intake
Walbro Fuel Pump
HKS BOV
Stock Evo 9 Turbo
ARP Head Studs
272 Cams
1200cc Injectors
E85 gasoline
I would guess 400whp on a VD.
Old Oct 21, 2013 | 08:02 AM
  #1076
SSMCL9's Avatar
side notes:
Thanks for the info. The turbo is gt3076
Old Oct 21, 2013 | 08:04 AM
  #1077
SSMCL9's Avatar
Runing 91 at 20psi
Old Oct 21, 2013 | 08:23 AM
  #1078
30r on 20 psi with 91 oct is tough to tell what it will make but my guess is not much. you need more boost/better fuel. If you are living in TO, can you source 94 octane?
you may hit 340whp VD.... but not sure!
Old Nov 7, 2013 | 02:54 AM
  #1079
PhantomBlackEVOX's Avatar
Veteran: Army
FP Red numbers!!?!??
Hey everyone I am currently having an FP Red turbo put on my evo 8 and am wonder what my number will look like on 93 Oct. I'm also having GSC S2 cams and 1100cc injectors put in.
Any help or idea would be great!
Other mods
AMS 3" turbo back exhaust
AMS 3.5" intercooler with 2.5 upper and lower piping
Wolly 255
HKS intake
Exedy hyper twin plate
Old Nov 7, 2013 | 03:11 AM
  #1080
EvoEi8ht's Avatar
You will definitely be hitting 400+
